#31
So...about that plane on the treadmill...
"Richard Riley" wrote in message
... On Mon, 11 Dec 2006 22:06:30 -0500, "Peter Dohm" wrote: A "rolling road" gets rid of the boundry layer, and better simulates what a race car will see on the track. There was a lot of talk 30+ years ago about what a nice thing this would be; mainly to test the effectiveness of anti-lift devices for sports car racing. It's state of the art now. They said in the cars they're building the ride hight is 1/4" in front, 3/4" in the rear, since they're testing 1/2 scale in the tunnel a boundry layer would make a huge difference. Apparently the really, REALLY advanced tunnels in europe use a stainless belt that can turn in relation to the wind, and they're testing multiple cars at once to model drafting. Just the stainless rolling road costs $10 million - before you build the rest of the tunnel. Some even use a big air bearing under the belt so the full weight of the car can rest on the wheels. It's just as well that I got away from all that. I'd be really bummed that I couldn't have one of my own to play with! g And, just to keep it on topic, the only planes that could take off from a treadmill are the Osprey and the Harrier. C'mon Richard! I know that you know better than that. Remember that a moving floor treadmill moves in lock-step with the air in the tunnel, and that it does so even if the speeds can be offset and the moving floor angled to simulate a surface wind condition. Peter |
#32
... "Richard Riley" wrote in message ... [...] And, just to keep it on topic, the only planes that could take off from a treadmill are the Osprey and the Harrier. If you're going to try to stay on topic, you ought to at least try to get the answer right. At this point plenty of sources, from individuals here in this thread and the one we had a while back, as well as those cited in the comments to the blog article referenced, have clearly stated the correct answer. Anyone attempting to refute the correct answer, however futile that effort may be, at least owes it to themselves as well as the rest of us to take the time to read and understand the references that explain the correct answer. Pete It appears that the OP had it nailed from the start. This "puzzler" is a deliberately trivial, and well tested problem, which allows the problem to be restated slightly to allow the correct answer to be refuted--at least enough to convince anyone who believes that the airplane's wheels perform some function other than steering and removing friction [of the aircraft sliding along the runway] so that the airplane can accellerate and take off. It is really depressing that so many in a group of this type [seem to] have been taken in. Peter :-( |
#33
The problem is that:
"The conveyer belt is designed to exactly match the speed of the wheels, moving in the opposite direction." is a meaningless statement. It =sounds= like an English sentence, the nouns and verbs are in the right place, and it gives the impression of conveying a thought, but it has no actual meaning. Restate that sentence and you have a question that has an answer. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
#34
Variant (was So...about that plane on the treadmill...)
Ok, how about this one. Everyone knows pilots love a tailwind.
You have a giant fan mounted on a truck positioned behind the airplane. The fan blows air towards the airplane, helping it to accelerate down the runway (literally blowing it down the runway) while the truck follows, keeping up with the airplane. Pretty soon the plane will be thundering down the runway and the pilot pulls back on the yoke. Does the pilot have to wait until the airplane's speed down the runway is twice Vr before he can take off? Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
#35
"T o d d P a t t i s t" wrote in message ... But anyone who does *not* violate the stated assumption (and consequently thinks this is *not* about real airplanes and real treadmills) can argue the plane cannot take off because its speed relative to the air is zero. To get that conclusion, however, they've got to assume an engine that is so weak, it couldn't take off on a real runway, or friction so much higher than reality as to again prohibit a takeoff. Well, I choose a treadmill with zero internal friction. [If the treadmill can be the length of the runway, I can make it frictionless.] Now, lock up the brakes and advance the throttle(s) to 100%. Thrust is going to overcome drag and move the airplane forward. Nothing in Aerodynamics 101 says thrust is related to wheel rotation. The treadmill belt is going to maintain the zero rotation speed of the wheels by slipping forward instead of rearward. When the aircraft reaches takeoff speed, it flys. Problem solved. |
#36
"N2310D" wrote in message
news:YfBfh.3650$LL4.2817@trnddc04... Thrust is going to overcome drag and move the airplane forward. Not in my Cherokee. |
#37
Not in my Cherokee. Sure it will! If we can have a treadmill the size of a runway, and [which is] able to sense the rotation of the airplane's wheels; then we can require it to be both frictionless and inertia-free. There are other amusing combinations as well; but the point the central point remains: So long as the airplane is not attached to (or restrained by) anything other than the "belt" of the treadmill, it will take off and fly quite normally--without regard for humorous statements (including mine) regarding doubled wheel speed. Since the original problem statement made no assertion that the airplane would be tied down, it obviously is not, and the the problem is solved--quite simply because there was no problem. Peter |
#38
You have a giant fan mounted on a truck positioned behind the airplane. The fan blows air towards the airplane, helping it to accelerate down the runway (literally blowing it down the runway) while the truck follows, keeping up with the airplane. Pretty soon the plane will be thundering down the runway and the pilot pulls back on the yoke. Does the pilot have to wait until the airplane's speed down the runway is twice Vr before he can take off? Jose -- There is not enough beer in the world to fuel such a discussion!!!! Peter |
#39
... [...] To put this mathematically: wheel speed = treadmill speed + airspeed If we assume: wheel speed = treadmill speed then airspeed =0 Well, IMHO the problem with taking the question literally is that, as Jose says, the literal reading is meaningless. Taken literally, "wheel speed" means nothing. Or rather, it requires further interpretation. Are we talking angular velocity? If so, how can the treadmill moving in a linear fashion have equal speed? The measurements aren't even in the same units. Are we talking linear speed? If so, what's so wrong with assuming the treadmill exactly matches the speed? I do understand the point that "peter" is trying to make, but I find it no more compelling than simply interpreting the question in a more reasonable way. Both interpretations require assumption-making, so as long as one is making assumptions, it makes more sense to make the same assumptions the average human being would make. Pete |
#40
... Sure, any airplane could take off from a treadmill in a wind tunnel. But climb out is a real pain. No, it's not. Airspeed is airspeed. If the airplane can take off in the wind tunnel, it can climb (to the physical limits of the wind tunnel, of course). I was going back to the original premise of a treadmill in still air. And you were incorrect. Pete |
Similar Threads | ||||
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 08:27 AM |
