engine monitor wiring harness install
Old October 10th 06, 04:49 PM posted to rec.aviation.owning
Jim Burns[_1_]
Default engine monitor wiring harness install
How are your engine monitor probe leads and wiring harnesses secured? Adel
clamps on the rocker box covers? Tie wrapped to your ignition leads? Tie
wrapped to the intake tubes? Adel clamps to the lower case/sump bolts?
I'm interested to hear about your installations. What you like and dislike
about the install location of the wiring harnesses and any problems
resulting from heat and or ignition or alternator interference. Do you have
service loops to allow you to swap probes or do you disconnect/reconnect
probes when you have a problem?
Thanks as always,
Old October 11th 06, 01:09 AM posted to rec.aviation.owning
[email protected][_1_]
On Tue, 10 Oct 2006 10:49:15 -0500, "Jim Burns"
sig snip
This might get a little long, apologies in advance.
Tie-wraps really aren't the thing to use forward of the firewall.
Limited usage on wire bundles is OK, but waxed lacing cord works much
better in the long run.
A tie-wrap WILL eat into engine mounts, intake tubes, baffles, engine
cases etc. etc. over time. The life of the tie-wrap is pretty much
directly related to temp, if they are away from exhaust/cylinders,
they hold up OK on wiring, but waxed cord lasts the life of the
engine+.
Adel clamps and Koroseal lacing are the best way to go for securing
everything else. It takes a little practice to get the hang of tying
off Koroseal-stretch it too tight, it will break, too loose and things
move around. Koro seal withstands engine oil/petroleum products quite
well, and can stand most under-cowl temps, but too close to an exhaust
stack will cook it.
Depending on the engine type (I'm assuming we are talking AzTruck,
with intake and exhaust both on the same side of the cylinder), wire
runs need to be adapted to what you've got with regard to
intake/exhaust configuration, position of CHT wells on the cylinders,
baffle/cowling configuration etc. Bottom line is keep the wires secure
and as far away from the e-stacks as possible/practical
I would personally stay the heck away from spark plug gasket-type CHT
probes if possible. Regular spark plug maintenance takes it toll on
them.
You need to look your exhaust over and plot a course for EGT probe
positions. They need to be the same distance from the head, but often
can be rotated around the stack to a good spot to get to your wiring,
allow access for other maintenance, etc.
Often, cylinder head-located wiring runs are possible both outboard
(in relation to the crankshaft) and inboard of the rocker box. There
are typically bosses/threaded holes that might be used for baffle
attachment. Using an Adel on the outboard side is pretty
straightforward. Using them on the inboard side requires sourcing
fully threaded coarse thread bolts to extend beyond the "back" side of
the boss, using a lock washer and plain nut to secure the clamp.
Again, proximity to the e-stacks is an issue. Rocker box screws are a
last resort, they work in a pinch, but IMHO not too well.
Have used regular Adels on intake pipes, but on an Aztec they might be
pretty close to the e-stacks. I useta have a pile of clamps (might be
Piper, might be Lycoming, sorry, been too long) that had a relief to
clear a primer line, the ones for injector lines have a bigger relief.
They work extremely well for securing wiring to the intake pipes.
As you indicated, sump bolts.studs work well as an attach point to run
Adels/wires along the lower "inside" of a Lycoming. Just be careful to
replace any lock washers removed with new, maybe throw a thin washer
in here and there, and re- tighten any engine fasteners removed
carefully. BTW, if your stash of Adels have -3 holes in them and you
need to put a -4 bolt/stud through it clamp that sucker in a vise and
run a Uni-bit through it and don't worry about. BTDT again, and again,
and again, never had a problem.
Have never personally experienced any electrical interference issues
(call it EMI/whatever) with analyzers and alternator wiring, but that
doesn't mean that it couldn't happen. If I was doing the work myself,
I'd probably dummy up the runs along the alternator wiring with some
tie-wraps and do a ground run with the analyzer powered up and watch
the numbers.
I'd probably tentatively shoot for EGT on the outside bottom of the
cylinder heads and CHT along the sump and out the intakes, but you're
a lot closer to an Aztec engine installation than I am.
I'm not big on service loops or doubled-up wiring forward of a
firewall (unless it's darn close to the firewall, and not much else),
it's more crap in the way to get chafed/cooked/cut/boogered up during
service. I wouldn't screw around with probe swapping either-probes are
too cheap and labor (and the potential to screw up a "good" probe
trying to find a "bad" one. Keep new or proven serviceable spares (one
of each type installed), then once you install it, you can leave
it-worst case, you just swapped a probe out of your stock from a
serviceable one from your engine.
Running CHT's & EGT's (and Tanis heaters, for that matter) is just
like re-plumbing or re-wiring a standard engine install. It's kind of
a Zen deal. Once you seen what works and what doesn't work, you just
get a feel for it. Just don't get ticked if your master wiring plan
gets change by somebody that walks up and says "Um, wouldn't it make
sense to run those wires on the inside of that thingie there".
For the most part wires need to be SECURE from the firewall to the
point they transition to the engine (with a sort of "loop" or extra
material to allow the engine to shake) and then secure until they get
to the probe.
The bottom side of the cylinder will get awfully crowded with intake,
exhaust, spark plug, CHT probes, EGT probes, not too mention the
lovely little rod that ties the baffles together, just keep it as
"clean" and simple as possible.
Hope at least a little of this helps;
TC
Old October 11th 06, 03:39 AM posted to rec.aviation.owning
Jim Burns
No need to apologize TC, you're a wealth of info!
No spark plug gasket type CHT's, I've got the bayonet type.
Yes we're talking about the Aztruck.
The cleanest route actually looks like it may be tucked up along the
sump/case joint and lying above the intake tubes. This places the wires a
good distance from all exhaust pipes but makes accessing the wires and
installing the Adel clamps a contortionists worst nightmare... maybe with
the bottom cowl off.
EGT probes look like they will be best installed with tips pointing forward
, probe lead extending aft at a slight outward angle allowing to drill the
holes without dropping the exhaust. This would leave plenty of room for the
covered lead to then turn inward and upward towards the case for securing.
Once I get back to the engine mounts, it's a piece of cake. There are some
notes about not running the leads against the alternator run, but the info
is very limited.
Thanks for your time, it's very much appreciated.
Old October 11th 06, 12:21 PM posted to rec.aviation.owning
On Tue, 10 Oct 2006 21:39:30 -0500, "Jim Burns"
is very limited.
Heh, didn't take much time to type, I need the mental exercise anyhow.
With regard to your "lower" wire runs-will be a good time to take
another look at your rocker drain hose/clamps. FWIW whenever I
allegedly hung a "new" engine I typically threw away the factory drain
hoses and clamps and used chunks of MIL6000 hose and nicer quality
clamps. It eliminated a lot of goofing around with them later.
I would suggest keeping the EGT clamps anti-seized up, and leave them
attached to the harness (disconnecting the clamps from the stack) when
dropping the exhaust. Not sure what your practice is, we dropped the
exhaust every 100 hours to renew gaskets/hardware, kroil on all the
ball joints, anti-seize on the slip joints, ensure that the front
crossover was still intact & not ready to escape through the nose
bowl.
After you've dropped the bottom cowls a hundred or so times, you get
where you don't think twice about it...
Been out of the PA-anything game for awhile, but am always willing to
help out with questions from owners/pilots that give a ****.
Regards;
TC
Old October 11th 06, 02:31 PM posted to rec.aviation.owning
Jay Honeck
Ours is a mix of both types, where appropriate.
And, just like TC says, the zip ties have grown brittle and broken in
the areas that get extremely hot. I've replaced about half of them,
and the analyzer has only been in the plane four years.
I may have to buy some of that waxed lace stuff.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 11th 06, 03:31 PM posted to rec.aviation.owning
Jim Burns[_1_]
I know what you mean about the drain hoses and clamps.
Our left engine is nearing TBO and the drain hoses have been a recent pita.
Since we did the lower cowl mod STC, it's only a 5 minute/1 man project to
drop the lower cowl and they've been off and on quite often. In fact, it
made replacing the alternator and quick drain valve a simple project rather
than a royal pain. Thanks for the tip on the MIL6000. I'll pick up a
length of it so I can replace some of those drain hoses that have become
hard and brittle.
Old October 11th 06, 03:37 PM posted to rec.aviation.owning
Jim Burns[_1_]
Ahead of the firewall, when I do use zip ties, I use the high temp 205
degree C Mil spec tie wraps. They aren't cheap but seem to last quite a bit
longer than the generic Menards nylon.
"Jay Honeck" wrote in message
Adel
Tie
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old November 19th 06, 02:36 AM posted to rec.aviation.owning
Frank Ch. Eigler
Hi -
Regarding Jim Burns' engine monitor installation, it's probably too
late to take the following advice into consideration, but just in
case: When installing the CHT / EGT probe wiring, consider trimming
and routing the individual cylinder probes' wires to central harness
connection points near the middle cylinder on each side. The idea is
that this would allow diagnosis of weird engine monitor indications by
swapping harness/probe connections between cylinders rather than
something more speculative and intrusive like replacing individual
probes.
This is a good thing if one's engine monitor starts giving spooky,
then worrysome, then eventually absurd indications. It goes doubly if
the monitor does something like that on both engines, ugh! Such a
sensor connection swap has allowed us to contra-indicate actual engine
mechanical problems during a still-ongoing episode.
- FChE
Old November 20th 06, 02:26 PM posted to rec.aviation.owning
Jim Burns[_1_]
Great idea Frank, but yep, probably too late... kinda.
I installed service loops in the nacelles to allow me to pull the slack
forward and essentially allow me to do as you suggest. As far as routing, I
routed everything inside of the intake tubes, using Adel clamps to secure
the alternator and/or starter cable to the sump bolts, then the CHT/EGT
leads are double adelled to the cable. This made for a very compact and
neat install. I disposed of a whole bushel basket full of old brittle cable
ties that had been installed over the years. My A&P inspected everything
yesterday and gave me a smile and a big thumbs up.
The left engine oil galley plug came out relatively easy. I built a little
"dam" out of rope caulk so it would hold a pool of Kroil in the plug. I
kept it saturated for 3-4 days before trying to remove it. Then when the
time came, I heated the case with a propane torch, tapped in a hex head
socket, first tightened, then reheated, and finally turned it out. No
stripping, no EZouts.
Next step is to install the indicator. I've already moved the FF indicator
and the #2 altimeter to allow me to install the indicator in an appropriate
hole. Hopefully I'll have it finished by the end of the week.
Thanks for your ongoing suggestions Frank!
"Frank Ch. Eigler" wrote in message
Chevy LS2 and Trans??? any real issues besides weight MrV Home Built 82 November 18th 05 03:11 AM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Gyrocopter Speed Mark Rotorcraft 36 August 16th 05 11:28 PM
ROP masking of engine problems Roger Long Owning 4 September 27th 04 07:36 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
