Wanted: Used Flarmview Display
Old July 4th 19, 12:15 AM posted to rec.aviation.soaring
Default Wanted: Used Flarmview Display
Thanks, but I purchased the one from Matt.
Old July 5th 19, 06:08 AM posted to rec.aviation.soaring
Matt Herron Jr.
On Wednesday, July 3, 2019 at 1:53:28 PM UTC-7, Mike Reid wrote:
The FAA does not prohibit polarized sunglasses, but it recommends against them. Not only do polarized sunglasses affect the visibility of some instruments, they can cause blind spots through aircraft windows and glider canopies. You can see this effect by either tilting your head at different angles while looking out of the canopy, or remove your polarized sunglasses and rotate them as you look through the canopy. You'll probably find that there are areas where the canopy goes dark.
https://www.faa.gov/pilots/safety/pi...sunglasses.pdf
https://www.randolphusa.com/blog/can...ed-sunglasses/
Mike
Polarized sunglasses excel at seeing aircraft against a blue sky. They help spot gliders head-on by darkening the background sky. They are great for seeing haze domes before thermals form, or convergence lines where humidity differs. I simply reject/return instruments that conflict with polarized sunglasses. No issues with the canopy. No blind spots. YMMV.
Used GPS-Nav plus display WANTED. Any model. Juliet11[_2_] Soaring 3 March 23rd 15 08:02 PM
Display Comparison Ultimate Le 57, V7, LXNAV FlarmView Richard[_9_] Soaring 1 November 23rd 14 02:13 AM
Used CAF 303 LCD Display wanted Stephen Michalik Soaring 0 February 6th 11 09:07 PM
Wanted: Used Cambridge 303 Display P. Corbett Soaring 0 June 21st 06 04:17 PM
Wanted Cambridge GPS-NAV display Sleigh Soaring 0 July 29th 03 08:57 AM
