Would you go?
Old April 4th 05, 04:46 AM
kage
You can back a King Air with reverse thrust.
BTDT
Karl
"Grumman-581" wrote in message
newsw24e.133532$r55.14562@attbi_s52...
"BTIZ" wrote in message news:1Z_3e.3181$ZV5.821@fed1read05...
I'd complain to the FBO about the "hassles" and be glad that you could
push
back and get away..
good thing it was not a 12,000# King Air.
Throw a chain around the nose gear and tow it out of the way... I'm got a
Hemi...
Old April 4th 05, 05:16 AM
Grumman-581
"kage" wrote in message
I had interpreted it as they had parked a King Air in front of your plane...
Depending upon where you park, pushing your plane backwards might not be an
option...
Old April 4th 05, 05:26 AM
Morgans
push
back and get away..
That's not so bad. At the Hickory airshow a few years back, we had to move
a DC-3, so the Connie could leave, and they didn't have anything handy to
move it. We got some Explorers, and pushed it out of the way, with the
tailwheel in the grass, even!
Not something I would want to do on a regular basis! g
Jim in NC
  #24
Old April 4th 05, 03:40 PM
Dan Luke
The truck's still sitting in front of my airplane this morning (Monday).
According to a different FBO lady this morning, the brakes are locked
(emergency brake?), which is why they couldn't move it.
Much is explained, except why they couldn't have called me to let me know
what the problem was when it happened.
Dan
C-172RG at BFM
  #25
Old April 4th 05, 03:54 PM
Michael
Dan Luke wrote:
In the event, I did an extra careful preflight, took large fuel
samples,
did an extended run-up and took off with no problems. Would you
have?
I would have done the same as you. I would have made it a point to
monitor CHT's and EGT's on taxi and runup (I know what normal is for my
plane, and fuel cintaminated with jet-A will not yield normal operating
temperatures) and I would hav done a full-powe runup on the threshold
for a few seconds, again monitoring CHT and EGT. My logic here is that
I would catch water contamination by drainign a sample, but hydrocarbon
contamination is trickier.
Having said that - I would take off knowing that if something did
happen, and they had indeed parked the truck there to keep me from
taking off, the accident would be called pilot error and the monday
morning quarterbacks would blame me for launching when something was
obviously not right.
Michael
  #26
Old April 4th 05, 04:31 PM
Andrew Gideon
Have you ever seen a parking lot handle a car left w/o the keys? There are
these doohickeys which they put under each of the wheels. When "closed" or
"activated", they actually raise each wheel off the ground. At that point,
the car can be easily moved.
Obviously, a fuel truck is heavier than a car. But *someone* should be able
to tow the thing even with locked brakes.
- Andrew
  #27
Old April 4th 05, 09:27 PM
Grumman-581
The problem is not one of someone having an engine strong enough to
move the truck, but rather that person getting enough traction to be
able to do it... If the truck only had the rear brakes locked, it
*might* be possible to drag it out of the way with a 4WD pickup in
4WD-low gear... If you get some water on the pavement under the fuel
truck's tires, it might help if you can manage to transition from
static to sliding friction on the locked tires while maintaining static
friction on your pickup's tires... Moving a heavier vehicle with a
lighter vehicle takes more than a powerful engine... If you don't have
better traction, all you do is spin your wheels... If you've got
traction and a low enough gear, you can move anything regardless of
your weight...
  #28
Old April 4th 05, 11:23 PM
Andrew Gideon
might be possible to drag it out of the way with a 4WD pickup in
4WD-low gear
The device to which I refer reduces the traction of the stuck vehicle by
getting its wheels off the ground. That leaves the vehicle on the wheels
of the device, and they are not locked.
I've only seen this used on automobiles, but I'm sure there's an analog for
trucks.
- Andrew
  #29
Old April 5th 05, 12:16 AM
Grumman-581
I understand what you're talking about Andrew.. .I'm just pointing out
the problems if you don't have such a device...
  #30
Old April 5th 05, 01:25 AM
Andrew Gideon
Ah. Sorry; I thought I wasn't being clear.
- Andrew
