Is my static port leaking?
Old August 9th 04, 01:34 PM
Derrick Early
Default Is my static port leaking?
The plane does have an alternate static source vented inside; however, I
pushed the valve in to select the exterior port. My guess is that either
this is normal or the static pressure system has a leak.
"Ron Rosenfeld" wrote in message
On Fri, 6 Aug 2004 10:11:59 -0400, "Derrick Early"
When I close the door to my 172, the airspeed, vsi and altimeter
instruments
jump. Does this mean that I have a leak in my static line? The last check
of the system was 18 to 20 months ago. The last thing that I want is
errors
in altitude while flying IFR.
Do you have an alternate static source that is inside the cabin, and
possible in the wrong position?
--ron
Old August 9th 04, 01:38 PM
Derrick Early
Yes, this is possible. I'm trying to figure out if jumpy instruments is
normal. I think that I should make a test or have it tested.
"SFM" wrote in message
Could this just be that the static port is very close to the pilot's door
and you closing it cause a disruption of air over the outside static port?
Scott
Scott F. Migaldi, K9PO
MI-150972
PP-ASEL-IA
Are you a PADI Instructor or DM? Then join the PADI
Instructor Yahoo Group at
http://groups.yahoo.com/group/PADI-Instructors/join
Catch the wave!
www.hamwave.com
**"A long time ago being crazy meant something, nowadays everyone is
crazy" -- Charles Manson**
"Derrick Early" wrote in message
instruments
check
errors
Old August 15th 04, 01:13 AM
Bill Hale
"Derrick Early" wrote in message ...
When I close the door to my 172, the airspeed, vsi and altimeter instruments
of the system was 18 to 20 months ago. The last thing that I want is errors
A way you can evauluate this... If you are flying along and you OPEN
the alternate static port and it doesn't do anything... you have a leak.
Usually will change the altitude 50-100 feet.
Bill Hale
ADF static? question JFLEISC Home Built 3 December 28th 04 01:28 AM
What caused the VSI and ALT bouce in the IMC? cpu Instrument Flight Rules 38 May 5th 04 03:45 PM
FS: Avery Dennison Adds Static Cling Vinyls to Fasson® Rapid-Roll Dry erase easel pads that clings to most walls. M.Roy Home Built 0 February 11th 04 05:18 PM
Is a static port a precision thing? Larry Smith Home Built 8 August 12th 03 10:26 PM
Canard static port location Paul Lee Home Built 1 July 12th 03 02:55 AM
