ASW-27B ballast tank ventilation
Old October 21st 04, 04:12 AM
Andy Blackburn
Default ASW-27B ballast tank ventilation
Anyone out there have good plans for the factory-recommended
ballast tank ventilation system? I've heard of (but
haven't seen) designs that include humidity sensors
so they know automatically when to turn off.
Thanks!
9B
Old October 22nd 04, 03:08 PM
Karl Striedieck
John Seymour and I installed tank drying mechanisms in our 27B's. My ship
dumps via hoses into the fuselage and out the belly like a 20, but John's is
standard factory setup like yours.
We use a "computer" fan we got from Digi-Key (800-digi key). There are so
many fans in the catalog I can't remember which one, but anything that moves
air will work. Part number 381-1073-ND looks about right.
Get some "bilge" tubing (the white, flexible plastic stuff that looks like
trachea tube) and stick in the water dump holes on the bottom of the wing
and run it to a home-made manifold on the fan. I use a 110V to 12V cube in
the trailer to run mine, but John simply puts an old glider battery on and
runs it flat each time.
When I'm leaving a contest I hook the fan up to the trailer lights. When I'm
at home I use the 110/12 cube.
I have one of Kellerman's Kestral weather instruments which incorporates a
humidity sensor. From experience I've found that in Eastern humidity it
takes about 24 hours to clear out the residual water. Out West it would be
faster.
Obviously you want to leave the fill caps off.
Karl Striedieck
"Andy Blackburn" wrote in message
Thanks!
9B
Old October 24th 04, 01:44 PM
Quebec Tango
You may also want to have a look at my setup. See my posts in thread
http://www.gliderforum.com/thread-view.asp?threadid=677
John Godfrey (QT)
mailto:quebectango at adelphia nospamdot net
"Karl Striedieck" wrote in message
is standard factory setup like yours.
moves air will work. Part number 381-1073-ND looks about right.
I'm at home I use the 110/12 cube.
faster.
Karl Striedieck
Thanks!
9B
Old October 24th 04, 05:31 PM
Jack Wyman
I have a similar system for my Diana wings. I used flexible plastic
tubing, about 1-inch OD in 6-foot lengths with integral end fittins.
It's available from U.S.Plastics in Lima, OH.
Jack Wyman
fuel tank plumbing pwm Home Built 18 January 27th 05 04:54 AM
Night bombers interception in Western Europe in 1944 Bernardz Military Aviation 205 July 22nd 04 05:31 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 20 August 27th 03 09:14 AM
First flight tests of systems to mitigate fuel tank explosions Peter Duniho Piloting 1 July 16th 03 10:49 PM
