CoPilot for Palm Pilot ??
Hi guys,
Just got me a Palm pilot and have downloaded some software for it. I'm particularly interested in using it for loading etc.. Ive come across a program called "CoPilot" and it seems pretty good (for a freebie). Anyone else use this program, i'm having trouble setting it up for use with R22 and R44 aircraft.. Any other loading software anyone recommends ??? thanks, Jad |
Any other loading software anyone recommends ??? I use co-pilot all the time, and it's terrific. What problems are you having adding the R22 and R44? (helicopters or homebuilt planes?) Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
In a previous article, jad said:
Ive come across a program called "CoPilot" and it seems pretty good (for a freebie). Anyone else use this program, i'm having trouble setting it up for use with R22 and R44 aircraft.. What sort of trouble? I don't know if it's an issue, but CoPilot doesn't do left-to-right weight and balance, and I read somewhere that left-to-right is important in helicopters. Have you discovered the waypoint generator at http://navaid.com/CoPilot/ yet? -- Paul Tomblin http://xcski.com/blogs/pt/ Any sufficiently advanced technology is indistinguishable from magic. -- Arthur C. Clarke |
do left-to-right weight and balance, and I read somewhere that left-to-right is important in helicopters. You can dummy it up though. Create an aircraft R22A, and put in left-right stations as if they were front-back stations. Do both calculations (relying on the front-back for total weight envelope) and if you are ok for both "aircraft" you should be good to go. Jose -- Money: what you need when you run out of brains. for Email, make the obvious change in the address. |
Similar Threads | ||||
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Sport Pilot pilots not insurable? | Blueskies | Piloting | 14 | July 12th 05 05:45 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
