FAA says homebuilders have to build the components of theirprojects off-airport
Old August 13th 14, 05:25 AM posted to rec.aviation.homebuilt
Default FAA says homebuilders have to build the components of theirprojects off-airport
On Saturday, August 9, 2014 5:57:52 AM UTC-6, Sylvia Else wrote:
On 8/08/2014 1:03 AM, Larry Dighera wrote:
FAA Says Hangars No Place For Homebuilders
Having taken a look at the legislation, I have to say that I'm far from
certain that the FAA really has the power to say how hangars are to be used.
It probably should, given that the government is subsidising them, but
to my mind the legislation doesn't go that deep. The airport plan will
show where the hangars are, and the airport owner will not be able to
pull them down and erect something else, but as long as the hangars are
there, I can't see a constraint that they be used for aviation purposes.
Charging a market rate rent when a hangar is not used for aviation
purposes appears to go against the express words of 49 USC 47107.a(13)(B).
Sylvia.
Which is why community level airports should avoid federal funding.
Old August 13th 14, 06:37 PM posted to rec.aviation.homebuilt
Orval Fairbairn
Default FAA says homebuilders have to build the components of their projects off-airport
Sylvia.
Yes and no. Federal funding helps to insulate the airport against
covetous local politicians seeking to placate their developer campaign
contributors' plans to close the airport so they can develop it.
See: Santa Monica for a prime example.
Old August 14th 14, 04:18 AM posted to rec.aviation.homebuilt
Orval Fairbairn
...much cutting...
Federal dollars are no protection from development.
See Meigs Field for a prime example.
The problem with Meigs was that they did NOT receive Federal dollars for
improvements.
Santa Monica received the airport from the Federal government under a
clause ensuring that it would remain an airport -- IN PERPETUITY, unless
the Feds released it.
Reid-Hillview, in San Jose, CA was purchased under similar conditions,
with the Feds telling Santa Clara County that they would insist on
repayment of their share of the investment, based on sale price -- not
just their initial cost. This put a damper on the greedy politicians.
Old October 1st 14, 07:35 PM posted to rec.aviation.homebuilt
Sylvia.
I agree that it brings some protections, but it also brings a boatload of use constraints. Furthermore the FAA seems unwilling and unable to reign state aviation departments who are making their own set of rules. There are several airports where flying clubs and gliding activities have been adversely impacted.
Frank Whiteley
Old October 1st 14, 07:45 PM posted to rec.aviation.homebuilt
On Tuesday, September 2, 2014 9:24:49 AM UTC-6, Bug Dout wrote:
writes:
If they can afford to. The vast majority of public airports would wither
and die with only local funding.
"The whole problem with the world is that fools and fanatics are always
so certain of themselves, and wise people so full of doubts."
-- Bertran Russell
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
The federal funds and matching funds are often for large projects which may be of questionable need to the local community. My own city/county airport has a 10,000ft runway which was largely a stepping stone project for the then airport manager who was on the career progression ladder. The next one immediately started recommending a control tower. Then a county commissioner started saying there should be a regional airport halfway between this airport and another municipal airport, a distance of 60 miles. Please. Frederick, MD, airport is another example of how (the promise of) federal money destroys airport use and access.
Frank Whiteley
FAA says homebuilders have to build the components of their projects off-airport Larry Dighera Piloting 17 September 24th 14 03:39 AM
Which Came First, the Santa Monica Airport, Or Those Who Chose To Build Their Homes Adjacent To It? Larry Dighera Piloting 16 May 7th 07 10:34 PM
Crosswind components James L. Freeman Piloting 25 February 29th 04 01:21 AM
FS: Slick ignition components (O-540) David Campbell Aviation Marketplace 0 December 24th 03 02:56 AM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 03:29 AM
