Army ends 20-year helicopter program
Old February 25th 04, 04:19 AM
Thomas Schoene
Kevin Brooks wrote:
"Thomas Schoene" wrote in message
ink.net...
Granted
they may not have done as badly as press reports suggest, but these
wars showed that the idea odf the deep penetration striek by
helicopters independant of ground forces was probably not a viable
option.
That is one hell of a leap based upon the results encountered during a
single mission where the SEAD support was intentionally withheld. A
lot of green suiters (outside the aviation community) thought that
the emphasis on the deep attack mission was bit overdone, but to
condemn the entire concept as "not viable" based upon one mission?
That's a bit much.
As I've said in another post, it's not just one mission. Afghanistan
(especially Op ANACONDA) certainly cast some doubt on current attack helo
doctrine.
But I did sort of misdirect my comments here. I really should have said
that these ops suggested that Comanche wasn't going to offer enough
improvement in Army aviation's capability to perform these missions. As a
fairly large helo (smaller than Apache, but not that much smaller), Comanche
wasn't going to be dramatically less vulnerable to the sort of threats that
were actually being encountered. But it was going to be a lot more
expensive. Its main improvement for the performance of these missions seems
to have been in sensors, which surely can be retrofitted to Apache for less
money.
It's also hard to understand why a scout needs an armament that's
only slightly lighter than the attack helo it's supposedly scouting
for,
You think the cavalry scout helos are there only to operate in
support of the attack helos? Nope. Cavalry units can be tasked to
independently screen and guard at the division level;
Granted. But why do they need a unique helo for this? Can't a cavalry
aviation formation have attack helos the same way a cavalry ground formation
has tanks?
or why
you need a scout at all when the attack helos have potent
surveillance radars like Longbow.
So the attack helos can concentrate on their mission (killing bad
guys), while the cavalry scouts perform their mission (screen, guard,
reconnoiter, etc.).
In which case, the scouts don't need heavy armament. If you were going to
have a heavily armed scout, it seems like the Apache could have done that
job, too with the main differences being in crew training and doctrine
rather than the airframe. Given the shortcomings of the Kiowa Warrior, I
get the impression that Apache units have been pretty much self-scouting in
many cases anyway.
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old February 25th 04, 05:24 AM
Kevin Brooks
news
ink.net...
Granted
option.
That's a bit much.
doctrine.
How did Anaconda do that? There they used the attack helos as CAS platforms
in a rather demanding environment (helos don't like really high altitude
operations that much). They performed their mission and took ground fire;
one helo was lost after it had to set down during the transit back home
(another Apache took an RPG round and stayed in the fight). So what
universal conclusion can you reach based upon Anaconda results? Or for that
matter based upon any other attack helo usage in Afghanistan?
Comanche
that
seems
less
money.
I'd agree with the conclusion that Commanche did not offer enough gain to be
worth its increasingly ridiculous cost. As to retrofitting sensors on
Apache, another poster has already addressed the concerns that will have to
be overcome if that route is followed. That would be sort of a reverse move
for the Army, though-- IIRC they just finished pulling the AH-64's from the
Cav units a few years ago in favor of the AH-58D.
for,
formation
has tanks?
The AH-58D became the standard Cav scout/light attack aircraft for the DIV
Cav squadrons years ago, and the Apaches reside in the attack battalions at
both DIV and Corps level, except for the airborne and light divisions, which
have AH-58D's in their *attack* units (the 101st AASLT DIV retained the
Apache). You are somewhat mixing your unit definitions a bit, too--cavalry
units, be they corps or division level, are combined arms teams that already
include *both* ground and air components (at DIV level the mix is three
ground troops and two air troops, while at the corps level the regiment is
made up of three ground squadrons and an air squadron). Yes, you can
*augment* the cavalry unit's firepower by attaching some number of Apaches
to it (if, for example, you wanted your DIV Cav unit to conduct a cover
mission, which is normally beyond its capabilities). The current "unique
helo", the AH-58D, is quite capable of performing the normal range of
cavalry duties, and can perfrm adequately in the light attack role--why
would you want to pull Apaches away from their normal attack duties and try
and turn them into cavalry platforms?
or why
reconnoiter, etc.).
Uhmmm...look up what is involved with both screen and guard missions. Both
involve the potential of direct combat (guard moreso than screening). Then
there is that pesky fact that we have *only* AH-58D's assigned to the light
and airborne divisions...
Again, you are going to be pulling them away from their primary role of
being killing platforms. The 58D is a little smaller (a good thing for the
sneak and peek role) and is easier to get into theater via airlift. It
apparently performs quite well in the scout role, so why remove attack
assets from the force structure to replace them?
in
many cases anyway.
Not sure what "shortcomings" you would be referring to in the case of the D
model. And you have sort of made a point that goes against your earlier
claim that the scouts are there "only" to support the attack helos. In
actuality they support the entire force; they *can* and often *do* support
the Apaches, but not always, and not exclusively.
Brooks
Tom Schoene
Old February 27th 04, 07:48 PM
Tarver Engineering
"Hobo" wrote in message
"George Z. Bush" wrote:
Why do I feel that they'd rather spend the money on some other project,
like
Star Wars, that they'd like rather than this one that the Army has said
all
along that it needs?
I think unmanned vehicles can serve the reconaissance function much
better than an ultra-expensive helo. The whole concept of a stealthy
helo which can fly unnoticed and collect information has problems. Helos
are noisy and produce a lot of heat and it is hard to make them radar
stealthy. The fact that the whole thing got so expensive pushed it over
the edge.
Now the Army has plenty of money to do that.
FA: 3 MASH Model Kits- Medical, Swamp, Helicopter - Ends Tomorrow Disgo Aviation Marketplace 0 February 21st 04 02:35 PM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
Army fears skilled helicopter pilots will fly away Otis Willie Military Aviation 0 January 11th 04 11:48 PM
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) Matt Wiser Military Aviation 0 December 7th 03 08:20 PM
French block airlift of British troops to Basra Michael Petukhov Military Aviation 202 October 24th 03 06:48 PM
