ASW 27 wing tip wheels
Old August 22nd 18, 05:52 PM posted to rec.aviation.soaring
Default ASW 27 wing tip wheels
Does anyone have experience with wing tip wheels on an ASW 27 ?
I am thinking about installing wing tip wheels on my ASW 27 (actually about 6-9 inches inboard of the wing tip). I was wondering if anyone has done this and how did it work for them. Did it change the handling characteristics? I am willing to accept a small decrease in performance (I expect it to be too small to notice).
Old August 22nd 18, 06:25 PM posted to rec.aviation.soaring
JS[_5_]
I've seen some custom wheels built on to the existing tip skids, two varieties.
The "Walter Quitt" wheels that Rex Mayes put on my 29 are great. Don't seem to do anything to performance, but help with ground handling. Williams Soaring Center sell the kit for I think $175 a pair.
Just uploaded a photo to the "Miscellaneous" photo album of the ASW27 Yahoo group (group link below).
https://groups.yahoo.com/neo/groups/ASW27owners/info
Old August 22nd 18, 07:18 PM posted to rec.aviation.soaring
Hank Nixon installed wingtip wheels on my ASW 24 last winter when we refinished the wings. They're almost identical to the tip wheels on the 201 Libelles; i.e., small wheels half buried in the tips. UH made a mold for the sockets that get recessed in the wingtips so I would check with him. However I believe the 27 wing thickness is somewhat less than the 24, and the available depth within the tip was one of the constraints we had to work with.
They work very well on landing (and takeoff, I suspect, though I haven't dropped a tip this year) and when moving the ship around on the ground. They're exactly what I wanted when I posted here last winter about this idea.
When we eyeballed the faired-in wheels with the original rubber tip skids, it appeared that the wheels were no less aerodynamic, considering profile and cross-sectional area. The other type of tip wheel that is completely enclosed in a fairing that sits on top of the wing skin wouldn't be quite as slick, although I suspect the impact on performance would be minimal.
Chip Bearden
Old August 22nd 18, 08:04 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
I've made 3D printable tip skids that screw into the existing tips skids - once you've filed a flat spot on them and then screwed in a couple of nut inserts into the existing, flattened tip skid. They accept a rollerblade bearing as a wheel which can be replaced if they get worn. They are two-part so you can have the attach bolts be captive, requiring a smaller Allen wrench and smaller hole in the skid. They are also left and right handed - canted a few degrees outboard so the wheel rolls flat when the wing is tipped over to the ground.
Here's a link to a screen shot of the CAD drawing. These are presently installed on two ASW-27B's
https://drive.google.com/open?id=1FS...Rt5nwGFtdzfEdl
Andy Blackburn
9B
Old August 23rd 18, 07:45 PM posted to rec.aviation.soaring
OHM Ω http://aviation.derosaweb.net
The ASW27 Yahoo group is a great resource.
I installed the wheels made by Rex Mayes. Works well. I like that they are attached using double faced tape (I use a good thick 3M product) which can "break away" without worrying about taking a chunk of the wing with them. My $0.02.
John OHM Ω
Old August 23rd 18, 09:48 PM posted to rec.aviation.soaring
Dan Marotta
That's a very good point.Â* When a friend landed out in his new V3 in
rough ground, he lost both wing tip wheels and a good bit of the skin of
the under sides of the wings.Â* We found the wheels with the skin
attached to the bolts and embedded nuts.Â* He promptly replaced his tip
wheels with a pair which were glued on with contact cement after the
wing tips were repaired, of course.
John OHM Ω
Dan, 5J
Old August 23rd 18, 09:55 PM posted to rec.aviation.soaring
One other possibility is to use nylon bolts. They should shear away if a wing comes down on rough ground.
Old August 23rd 18, 09:59 PM posted to rec.aviation.soaring
Andy Blackburn[_3_]
On Thursday, August 23, 2018 at 1:45:25 PM UTC-5, OHM Ω http://aviation.derosaweb.net wrote:
John OHM Ω
I've had a few requests for a printable file.
Because the design is in two parts that are screwed together with short 8-32 bolts, it ought to come apart before ripping the wing off. ;-) You can even use nylon bolts if you want a even lower break-away force. Here's an updated link that includes the .stl file for printing and a picture of one installed.
https://drive.google.com/open?id=1Vr...0ILPkMcdEJ8C63
PM me if you are making a set and need a hardware list to complete assembly..
This is being provided for free without any guarantees or warranty.
Andy Blackburn
9B
Old August 23rd 18, 10:39 PM posted to rec.aviation.soaring
JS[_5_]
John OHM Ω
Andy Blackburn
9B
Just found out about another supplier of tip wheels, this one in Australia.
www.gliderwheels.net
Old August 24th 18, 05:05 PM posted to rec.aviation.soaring
Matt Herron Jr.
John OHM Ω
Andy Blackburn
9B
I use Andy's wheels on my 27, and am quite happy with them. Clever design. I recommend printing the parts from Nylon as it is very tough.
Matt
Junkers G.38 pics [06/12] - First prototype at Berlin Tempelhof Airport showing spatted tandem main wheels, the aileron section of the 'double wing' and—most unusually—retractable oil and water radiators.jpg (1/1) Miloch Aviation Photos 0 February 16th 18 03:11 PM
Cessna CitationJet/M2 pics [06/12] - CJ2 planform view, showing its straight wing and uncovered main wheels.jpg (1/1) Miloch Aviation Photos 0 January 2nd 18 03:26 PM
WTB 1-34 wing tip wheels [email protected] Soaring 1 March 4th 13 08:44 PM
FS: Wings&Wheels Wing Stand James Hamilton[_2_] Soaring 0 September 12th 09 01:15 AM
Books on Military Rotary Wing to Civilian Fixed Wing Transition? Greg Copeland Piloting 5 May 2nd 07 03:23 AM
