Approach Question
Old August 24th 08, 11:28 AM posted to rec.aviation.ifr
Thomas Borchert
Default Approach Question
Vor-Dme,
First off, please tell me if this is the right forum for newer-minted IR
pilots to discuss approach questions?
Absolutely. Welcome!
If so, have a look at this one :
http://204.108.4.16/d-tpp/0808/00382G22.PDF
GPS22, KSCH. I believe there is an error in the hold in lieu of PT, which
cannot be both "1-min" AND "4NM, but perhaps there is a good reason why
it is charted this way.
Weird, that "4 nm".
My real question though concerns the IAF waypoints. Why are OTOLE and
GALWA charted as fixes or reporting points, and not as GPS waypoints?
Hmm. My guess would be that they are regular intersections also defined by
non-GPS navaids. One would need an enroute chart to see that.
If
entering using OTOLE as IAF, is one required to fly the hold in lieu of?
I would say yes, since it doesn't say "NoPT" for OTOLE.
Thomas Borchert (EDDH)
Old August 24th 08, 01:05 PM posted to rec.aviation.ifr
BillJ
VOR-DME wrote:
Greetings,
GALWA charted as fixes or reporting points, and not as GPS waypoints? If
Why are OTOLE and
They are both intersections, i.e. fixes.
Old August 24th 08, 01:07 PM posted to rec.aviation.ifr
BillJ
VOR-DME wrote:
Greetings,
Why are OTOLE and
You don't hold at OTOLE if being vectored, or if cleared for straight in
approach.
Old August 24th 08, 02:00 PM posted to rec.aviation.ifr
Thomas Borchert
Vor-Dme,
PT or NoPT?
Well, where on the chart does it say "NoPT" for that case?
Old August 24th 08, 03:58 PM posted to rec.aviation.ifr
Andrew Sarangan
On Aug 24, 5:36 pm, VOR-DME wrote:
In article , says...
Why are OTOLE and
Yes, they are, and they both show on the en-route chart.
Dumb of me not to have seen that.
approach.
As with any approach, if being vectored, it's NoPT.
But what if "Cleared for the GPS22, cross OTOLE at or above 2400. . ."
PT or NoPT?
ITOLE IAF would require you to fly the PT. I don't see a no-PT for
that segment anywhere on the chart.
Old August 24th 08, 04:42 PM posted to rec.aviation.ifr
Mike[_22_]
"Thomas Borchert" wrote in message
Vor-Dme,
Weird, that "4 nm".
The only thing I can make out of it is perhaps it's saying by 4nm of OTOLE
you should start your turn even if it's less than a minute.
Old August 24th 08, 08:20 PM posted to rec.aviation.ifr
VOR-DME
Greetings,
Old August 25th 08, 07:30 PM posted to rec.aviation.ifr
Sam Spade
VOR-DME wrote:
Greetings,
The 1 minute is a NACO charting error. The Jeppesen chart doesn't show
that.
The Jeppesen chart shows OTOLE as a flyby waypoint and GALWA as a
flyover waypoint. Thus, more NACO charting issues.
The course-reversal (hold-in-lieu "HIL") is mandatory unless you arrive
via an NoPT route. This particular hold violates critera because HILs
haven't been permitted at GPS FAFs for perhaps 7 years now. They can
cause box sequencing problems.
This approach should have been changed during an FAA biannual review but
they are way behind their policy requirements.
Old August 26th 08, 03:56 AM posted to rec.aviation.ifr
David Kazdan
And perhaps they were drinking "decent" wines while preparing the chart,
rather than worrying about "descent" angles.
David
Sam Spade wrote:
VOR-DME wrote:
Greetings,
IR pilots to discuss approach questions?
which cannot be both "1-min" AND "4NM, but perhaps there is a good
reason why it is charted this way.
If entering using OTOLE as IAF, is one required to fly the hold in
lieu of?
that.
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 03:54 AM
Another approach question Andrew Sarangan Instrument Flight Rules 5 November 7th 04 05:44 PM
GPS approach question Matt Whiting Instrument Flight Rules 8 November 1st 04 10:51 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
where to ask question about approach? J Haggerty Instrument Flight Rules 1 August 17th 04 06:30 AM
