#21
A turbo Arrow has THREE things that will be problematic. The engine,
the turbo and the gear. Frankly, I would suggest you look at a fixed gear airplane with a Lycoming 320, 360 or 540 engine, normally aspirated. Turbo's overstress and overheat these air cooled small aircraft engines. Turbos also break frequently. Want more power? Just get a bigger normally aspirated engine. Retract gear is an enethema. I have seen so many gear ups, about 1/2 and 1/2 on reason (forget and broke). First plane? Cherokee if you want low wing, Cessna if you want high wing. Fixed gear and Lycoming engine. Just a few words of advice from a 5 year airplane owner. As for far away inspections. Call a mechanic (NOT the owners mechanic). Tell him you want him to spend TWO hours looking at the plane. Have him do a compression test and look at the logs. Then have him phone you with a report. The other stuff can be inspected by anyone (usually). Ask the owner if everything works, condition of upholstry paint etc. Do an appraisal on TAP's appraiser. This is the asking price. Get the N number and have AOPA do a title search. Now if all that checks out, you can go visit. |
Similar Threads | ||||
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 07:28 PM |
GWB and the Air Guard | JD | Military Aviation | 77 | March 17th 04 10:52 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
High Altitude operations (Turbo charge???) | Andre | Home Built | 68 | July 11th 03 11:59 PM |
