IPAQ connection problems
Old May 9th 04, 05:10 PM
Mark Brown
Default IPAQ connection problems
Hi,
I posted a while back about having trouble connecting
and Ipaq 3950 to a volkslogger. I took the advice
on board but still cant get it to work. I downloaded
the TTY programme from the winpilot website and ran
it, the ipaq doesnt appear to be receiving any data.
Before I send the cable back as a dud can anyone shed
any light on the 'correct' setting for NMEA output
from the volkslogger?
Also for info, i have made sure all other programs
are closed the IR is turned off so nothing should be
interfering with the connection, however sometimes
i get a message saying that the serial port is allready
in use. This makes me think that cable is sending
data but the ipaq just isnt getting it properly. Any
light anyone can shed on this matter will be gratefully
received.
Many thanks
Mark Brown
Old May 9th 04, 05:29 PM
Chet
Mark,
About the only thing I can suggest is to check all the setting again! Make
sure you have no programs running on the Ipaq (to the extent of resetting
the Ipaq and ONLY installing WinPilot). Lastly, play with the declare
switch. I found that in the wrong position, you will get a message from
WinPilot.
I'm using a cable I purchase from Craggy Aero and WinPilot/Volkslogger./B50
and after I wired it up, it worked the first time. Perhaps you do have a bad
cable.
"Mark Brown" wrote in message
Hi,
received.
Many thanks
Mark Brown
Old May 9th 04, 10:13 PM
RHP
Mark
The Volkslogger NMEA setting is - - XX - - - -.
The tty should show the raw data even if the NMEA is incorrect, but
won't if the wiring is incorrect.
Give me a call maybe I can help you.
Richard
www.craggyaero.com
530-905-0062
Mark Brown wrote in message ...
Hi,
received.
Many thanks
Mark Brown
Old May 11th 04, 01:46 AM
Henryk Birecki
From your description some things are not clear, so I'll suggest you
check that you do not have pins 2 and 3 switched on the cable.
If this is not the problem you may want to try downloading a program
called VLtoIGC from Cumulus-Soaring. This is an iPaq (PDA) utility to
download flights and backup Volkslogger data base. It works around
some iPaq serial port driver problems that may be impeding your iPaq
to PDA connection.
Henryk Birecki
Mark Brown wrote:
Hi,
Old May 11th 04, 04:26 AM
RHP
Sorry Mark
The tty program for troubleshooting the connections can be downloaded
from the WinPilot Site http://www.winpilot.com/Faq.asp
Item 1
Richard
www.craggyaero.com
Hi,
received.
Many thanks
Mark Brown
Vatsim Connection Problems Anthony Acri Simulators 1 April 15th 04 09:12 AM
iPAQ connection to Filser 5000 Slave Rod Soaring 2 April 14th 04 11:01 PM
Volkslogger to Ipaq connection Mark Brown Soaring 3 April 14th 04 06:17 AM
LX5000-Winpilot connection problems Marc Teugels Soaring 1 January 18th 04 10:42 AM
iPAQ h2210/h2215 Review Paul Remde Soaring 0 September 3rd 03 03:45 AM
