Exhaust system on Cessna 172
Just got the word from the A&P that the exhaust system
on my 1976 M model 172 needs overhauling because of cracks and leaks. I'm compemplating replacing it with a Power Flow Systems tuned exhaust rather than having the stock OEM system overhauled. The A&P is guessing the overhaul cost will be about $1k. The PFS system ranges from $3425 to $3875 depending on short-stack versus "classic" (long pipe hanging outside the cowling) and polished versus ceramic coated. Comments? Your experiences? Is it worth the extra $2K or so? Any place to buy a PFS at a discount, or is ordering from the factory the best / only option? Thanks. Ronnie |
Ronnie
Save your money... Repair the stock system... denny |
Ronnie wrote:
Just got the word from the A&P that the exhaust system on my 1976 M model 172 needs overhauling because of cracks and leaks. I'm compemplating replacing it with a Power Flow Systems tuned exhaust rather than having the stock OEM system overhauled. I've had my PFS on my Cherokee 140 for something like 7 years. It definitely helps the climb performance and general engine smoothness. In the past, I've always advised people the following: If you have a good exhaust system, I wouldn't trash it to put on a PFS. If your exhaust system is on it's last legs, then it's worth considering. It seems like you're in the latter category. Whether it's "worth it" is subjective. I really wanted to add to my climb performance. You're probably in the same boat. You'll have to decide if it's worth the extra cash. --- Jay -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Jay, what effect does the PFS have on your cruise speed and fuel flow?
-- Best Regards, Mike http://photoshow.comcast.net/mikenoel I'm a uniter, not a divider. - GWB, 1999. "Jay Masino" wrote in message . .. Ronnie wrote: Just got the word from the A&P that the exhaust system on my 1976 M model 172 needs overhauling because of cracks and leaks. I'm compemplating replacing it with a Power Flow Systems tuned exhaust rather than having the stock OEM system overhauled. I've had my PFS on my Cherokee 140 for something like 7 years. It definitely helps the climb performance and general engine smoothness. In the past, I've always advised people the following: If you have a good exhaust system, I wouldn't trash it to put on a PFS. If your exhaust system is on it's last legs, then it's worth considering. It seems like you're in the latter category. Whether it's "worth it" is subjective. I really wanted to add to my climb performance. You're probably in the same boat. You'll have to decide if it's worth the extra cash. --- Jay -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
Mike Noel wrote:
Jay, what effect does the PFS have on your cruise speed and fuel flow? No perceivable change in cruise. It's been a long time since I accurately checked my fuel burn, but if I remember correctly, it did reduce it some small but noticeable amount. --- Jay -- Jay Masino "Home is where My critters are" http://www.JayMasino.com http://www.OceanCityAirport.com http://www.oc-Adolfos.com |
"Mike Noel" wrote in message
... Jay, what effect does the PFS have on your cruise speed and fuel flow? Without re-pitching the prop, there should be no change in cruise. At the same RPM, you're pulling the same amount of air through the prop. The noticable change should be in take-off performance, where your RPM would be higher than before. |
Not hearing any convincing arguments in
favor of the extra money, the decision was made to overhaul the stock OEM exhaust system. Ronnie "Ronnie" wrote in message t... Just got the word from the A&P that the exhaust system on my 1976 M model 172 needs overhauling because of cracks and leaks. I'm compemplating replacing it with a Power Flow Systems tuned exhaust rather than having the stock OEM system overhauled. The A&P is guessing the overhaul cost will be about $1k. The PFS system ranges from $3425 to $3875 depending on short-stack versus "classic" (long pipe hanging outside the cowling) and polished versus ceramic coated. Comments? Your experiences? Is it worth the extra $2K or so? Any place to buy a PFS at a discount, or is ordering from the factory the best / only option? Thanks. Ronnie |
favor of the extra money, the decision was made to overhaul the stock OEM exhaust system. Ronnie, ask your A&P if he's using Dawley Aviation, in Burlington, WI, to overhaul your exhaust system. They're excellent people to deal with, and reasonably priced. (Well, reasonable for aviation...) Also, if you live anywhere near Wisconsin, picking up the finished product yourself will you save you some significant crating/shipping charges. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In article .com,
"Jay Honeck" wrote: Ronnie, ask your A&P if he's using Dawley Aviation, in Burlington, WI, to overhaul your exhaust system. They're excellent people to deal with, and reasonably priced. (Well, reasonable for aviation...) second Also, if you live anywhere near Wisconsin, picking up the finished product yourself will you save you some significant crating/shipping charges. But your A&P will lose out on the peanuts!!! -- Bob Noel Looking for a sig the lawyers will hate |
Hi Jay,
I'll ask him. I only live near Wisconsin for a week in the later part of July every year :-) (OSH) Otherwise, I'll bet the shipping from there to Austin, TX will be less than the gas my Aztec would burn to go pick it up :-) Ronnie "Jay Honeck" wrote in message oups.com... Not hearing any convincing arguments in favor of the extra money, the decision was made to overhaul the stock OEM exhaust system. Ronnie, ask your A&P if he's using Dawley Aviation, in Burlington, WI, to overhaul your exhaust system. They're excellent people to deal with, and reasonably priced. (Well, reasonable for aviation...) Also, if you live anywhere near Wisconsin, picking up the finished product yourself will you save you some significant crating/shipping charges. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Similar Threads | ||||
flying low...military video | gatt | Piloting | 60 | January 8th 07 01:43 AM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Enstrom Helicopter Exhaust System | Jim | Aviation Marketplace | 0 | December 28th 04 02:28 AM |
FS: Cessna exhaust fairing Speed mod | Roger Pinnell | Aviation Marketplace | 0 | November 23rd 04 04:48 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Products | 1 | November 4th 03 12:57 AM |
