'Shorter field landings?
Having recently landed a Pilatus B4 'wheels up, on a wet grass runway
(without any physical damage to the a/c!). I noted the extremely short ground run! Could this be a useful option- if you have selected a slightly small field for an out-landing (ie- leave the u/c up?) Another scenario, perhaps if you find the glider rolling along at high speed towards an obstacle, then retract the u/c! Expensive, but maybe less painful? |
On 12/08/2014 2:27 PM, Graham Drinkell wrote:
Having recently landed a Pilatus B4 'wheels up, on a wet grass runway (without any physical damage to the a/c!). I noted the extremely short ground run! Could this be a useful option- if you have selected a slightly small field for an out-landing (ie- leave the u/c up?) Another scenario, perhaps if you find the glider rolling along at high speed towards an obstacle, then retract the u/c! Expensive, but maybe less painful? There is not much room or material between you and the ground if you leave the gear up, it is an easy way to get hurt on a hidden rock etc. The general consensus is that the best option is to always land gear down, this will help absorb the impact and transfer the load to the airframe rather than your body. YMMV Luke |
At 19:51 08 December 2014, Luke Szczepaniak wrote:
On 12/08/2014 2:27 PM, Graham Drinkell wrote: Having recently landed a Pilatus B4 'wheels up, on a wet grass runway (without any physical damage to the a/c!). I noted the extremely short ground run! Could this be a useful option- if you have selected a slightly small field for an out-landing (ie- leave the u/c up?) Another scenario, perhaps if you find the glider rolling along at high speed towards an obstacle, then retract the u/c! Expensive, but maybe less painful? There is not much room or material between you and the ground if you leave the gear up, it is an easy way to get hurt on a hidden rock etc. The general consensus is that the best option is to always land gear down, this will help absorb the impact and transfer the load to the airframe rather than your body. YMMV Luke |
On Monday, December 8, 2014 11:30:05 AM UTC-8, Graham Drinkell wrote:
Having recently landed a Pilatus B4 'wheels up, on a wet grass runway (without any physical damage to the a/c!). I noted the extremely short ground run! Could this be a useful option- if you have selected a slightly small field for an out-landing (ie- leave the u/c up?) Another scenario, perhaps if you find the glider rolling along at high speed towards an obstacle, then retract the u/c! Expensive, but maybe less painful? Herniated discs can be extremely painful particularly if pinching parts of the spinal cord leading to paresthesia. I recommend using the landing gear and the big bouncy thing attached to it. |
On Monday, December 8, 2014 2:30:05 PM UTC-5, Graham Drinkell wrote:
Having recently landed a Pilatus B4 'wheels up, on a wet grass runway (without any physical damage to the a/c!). I noted the extremely short ground run! Could this be a useful option- if you have selected a slightly small field for an out-landing (ie- leave the u/c up?) Another scenario, perhaps if you find the glider rolling along at high speed towards an obstacle, then retract the u/c! Expensive, but maybe less painful? The landing gear is there to protect you. Use it for that purpose. Gliders with decent brakes commonly stop faster on the gear than off the gear. UH |
Similar Threads | ||||
(USA only) Managing 911 response to off field landings | Jim Beckman[_2_] | Soaring | 8 | August 11th 09 04:23 PM |
Soft field landings - low wing vs high wing aircraft | Justin Gombos | Piloting | 19 | May 23rd 07 05:21 AM |
Variations in soft field landings | Maxwell | Piloting | 42 | April 27th 07 05:12 PM |
Short vs Soft Field Takeoff and Landings | Ol Shy & Bashful | Piloting | 17 | November 17th 06 10:32 PM |
Rough Field Landings | [email protected] | Piloting | 38 | December 19th 04 01:42 PM |
