Questtions about ATC-Fligtplan
Old August 31st 04, 08:29 PM
Daniel Hofer
Default Questtions about ATC-Fligtplan
Hello
I have some questions about the ATC-flightplan and how to fill it out.
1. Field 10, standard equipment
ILS means localizer AND glideslope, right?
DME is not part of standard equipment, right?
2. Field 10
R means RNP. Do I need to write e.g. R5 for RNP5? Or is no value needed? (is
it dependent on the used ATS-routes?)
If I use R, it doesn't mean automatically G? (I fly a PA34, GNS 430 is the
only RNAV-equipment).
My instructor means the following is correct:
SRY
but I think it's the following:
SDGRY
What do you think??
3. Field 19, emergency equipment
If I have no survival equipment, is it necessary to cross out ALL fields or
only the first one ( the S)
And last question:
VHF emergency radio. Does it mean a separate COMM-receiver or only the
ability to receive on 121.5?
Hope you have some answers;-)
Thanks a lot!
Daniel
Old September 1st 04, 04:03 AM
Newps
Daniel Hofer wrote:
Hello
Wouldn't be an ILS without one.
No, but it's pretty rare to have one without it.
2. Field 10
You ain't got RNP, that's airliner and bizjet stuff. You're 430 makes
you a /G.
Old September 1st 04, 04:11 AM
john smith
Is the .ch in your email address Switzerland?
Is the flight plan for a Swiss Flight Plan form or an International
Flight Plan form?
Old September 1st 04, 06:43 AM
Daniel Hofer
Hello John
sure;-) .ch is Switzerland.
Is it a european flightplan or better, an ICAO flightplan, described in DOC
4444.
Daniel
Old September 1st 04, 08:10 AM
Julian Scarfe
"Daniel Hofer" wrote in message
Both correct.
2. Field 10
(is
Just R.
No, it does not automatically mean G.
SRY
SDGRY
What do you think??
Strictly speaking, you are correct. However, I don't think you add any
extra info for ATC with DG. Certainly I've been writing SR (I can't get
above FL245 so 8.33, Y, is unnecessary) for many years without issue. I
wouldn't take it too seriously. R tells ATC what it needs to know. The only
one (apart from S) that really matters is a Y if abouve FL245 -- without
that the FPL will be rejected.
or
All of them. Bear in mind that the FPL is a template for an AFTN text
message. Your form may be transcribed to e.g.
-E/0310 P/002 R/VE J/L D/01 004 ORANGE A/WHITE C/HOFER
If you have maritime survival equipment you want it to look like:
-E/0310 P/002 R/VE S/M J/L D/01 004 ORANGE A/WHITE C/HOFER
not
-E/0310 P/002 R/VE M J/L D/01 004 ORANGE A/WHITE C/HOFER
though most ops people will understand that if you cross out the S you mean
that you have no survival equipment at all.
And last question:
Separate emergency COM I think.
HTH
Julian Scarfe
Old September 1st 04, 08:16 AM
Daniel Hofer
Hello Julian
thank you very much for your help!
One small question: is 8.33 only used above FL245? I didn't know...
Thanks
Daniel
Old September 1st 04, 08:54 AM
Julian Scarfe
I think so.
http://www.eurocontrol.int/vhf833/
Julian
Old September 2nd 04, 03:50 PM
Mike Rapoport
Try:
http://www.fracpilot.com/Aviation_Links/icao_fltpln.htm
Mike
MU-2
Hello
2. Field 10
(is
SRY
SDGRY
What do you think??
or
And last question:
Thanks a lot!
Daniel
Old September 2nd 04, 04:54 PM
Daniel Hofer
Hi Mike
thanks!
Daniel
