Mirror installation required?
I was recently towed by a tow plane that had no mirror installed. Two way communication was established using VHF and a club member was positioned ahead of the tow plane to relay ground signals. This was a US based club. This launch prompted me to wonder if in the US a mirror is actually required.. After researching 14 CFR and AC 43.13 2B I can not find a regulatory reference to mirror installations in the US. I see various Canadian and European references buy none here in the US. Can anyone point me to a FAR or Advisory Circular that specifies a mirror is required? I just am curious if its a smart practice or an actual requirement for towing. I'm sure this has been covered before but the proof escapes my research.
Thanks LB |
While not a "US regs expert", I am not aware of a reg.
But, I consider it a cheap "second info referral" to help all involved. From an, "ISO background", safety/quality is everyone's job...... Curious to see if a US reg shows up. |
Thanks for commenting. As a tow pilot/glider pilot I saw it as not the "best practice" and made a comment that "I think it is required" to the tow pilot the next day. But I qualified it with "I'll check it out". Now I can't find that it is required. So I may have to stand corrected.
On Wednesday, July 20, 2016 at 1:48:11 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote: While not a "US regs expert", I am not aware of a reg. But, I consider it a cheap "second info referral" to help all involved. From an, "ISO background", safety/quality is everyone's job...... Curious to see if a US reg shows up. |
Not a US regulatory requirement. 91.309 says a lot about the tow hook and the tow line but nothing about mirrors.
However a mirror may be a local organizational requirement. The Civil Air Patrol seems to require it. It is very hard for the tow pilot to see the spoilers hanging out at low altitude right after liftoff if you can't glance back at the glider. No radio will help you there to see it, unless someone on the ground sees and helps you. Turning your head to look out the back window (if even possible) while keeping the tow plane in a safe climb attitude in this situation is a bad idea. Depending on the tow plane, this is a critical situation where it is very easy to loose control of the tow plane. In the few years I have been towing, being zapped by spoilers hanging out behind me has happened to me twice. It is like trying to tow around a ton of bricks a few MPH just above stall speed barely climbing if at all. Common sense should put the mirror in any tow plane. And it should be used. Frequently. Besides, think of all the other cool reasons you could tell the uninitiated what that thing is for. On Wednesday, July 20, 2016 at 12:48:11 PM UTC-5, Charlie M. (UH & 002 owner/pilot) wrote: While not a "US regs expert", I am not aware of a reg. But, I consider it a cheap "second info referral" to help all involved. From an, "ISO background", safety/quality is everyone's job...... Curious to see if a US reg shows up. |
There is no regulatory requirement for rear view mirror installation on aircraft.
Mirror(s) might be included in required equipment list for a specific aircraft model when towing, or in other types of operations. POH or Flight Manual would explain that. Certified airplanes become non-airworthy with non-approved mirror installation. On Wednesday, July 20, 2016 at 10:28:49 AM UTC-7, wrote: I was recently towed by a tow plane that had no mirror installed. Two way communication was established using VHF and a club member was positioned ahead of the tow plane to relay ground signals. This was a US based club. This launch prompted me to wonder if in the US a mirror is actually required. After researching 14 CFR and AC 43.13 2B I can not find a regulatory reference to mirror installations in the US. I see various Canadian and European references buy none here in the US. Can anyone point me to a FAR or Advisory Circular that specifies a mirror is required? I just am curious if its a smart practice or an actual requirement for towing. I'm sure this has been covered before but the proof escapes my research. Thanks LB |
Certified tow pilots are still airworthy with a cheap hand-held vanity mirror.
On Wednesday, July 20, 2016 at 3:39:41 PM UTC-5, RobKol wrote: There is no regulatory requirement for rear view mirror installation on aircraft. Mirror(s) might be included in required equipment list for a specific aircraft model when towing, or in other types of operations. POH or Flight Manual would explain that. Certified airplanes become non-airworthy with non-approved mirror installation. On Wednesday, July 20, 2016 at 10:28:49 AM UTC-7, wrote: I was recently towed by a tow plane that had no mirror installed. Two way communication was established using VHF and a club member was positioned ahead of the tow plane to relay ground signals. This was a US based club.. This launch prompted me to wonder if in the US a mirror is actually required. After researching 14 CFR and AC 43.13 2B I can not find a regulatory reference to mirror installations in the US. I see various Canadian and European references buy none here in the US. Can anyone point me to a FAR or Advisory Circular that specifies a mirror is required? I just am curious if its a smart practice or an actual requirement for towing. I'm sure this has been covered before but the proof escapes my research. Thanks LB |
I have heard the installing the mirror can require a 337 Field approval and that has stopped some operators from installing the mirror.
The five tugs at Moriarty (that's right - 5) each have mirrors. I can't
say about the ABQ Soaring Club, but the Sundance tugs are all licensed as "Restricted" which, I would guess, is their ticket to having external mirrors mounted. I wouldn't tow without them. On 7/20/2016 10:14 PM, SoaringXCellence wrote: I have heard the installing the mirror can require a 337 Field approval and that has stopped some operators from installing the mirror. -- Dan, 5J |
What type of tow plane was it? The Pawnees that I tow with have exterior mirrors. Both the L-19 and Maules have overhead skylights and interior mirrors which are not visible to the glider but quite effective. I will not tow without a mirror!
Skip |
I've towed with a Maule, L-19, Citabria, Super Cub, Pawnee, CalAir, and
Ag Wagon. All had mirrors except for the Maule and I didn't like that. On 7/21/2016 11:15 AM, wrote: What type of tow plane was it? The Pawnees that I tow with have exterior mirrors. Both the L-19 and Maules have overhead skylights and interior mirrors which are not visible to the glider but quite effective. I will not tow without a mirror! Skip -- Dan, 5J |
Similar Threads | ||||
required LD versus required MC to make it home ?? | akiley | Soaring | 56 | September 22nd 10 07:48 PM |
Mirror Dude - Thunderbird Mirror Dude (Custom).jpg (1/1) | Glen in Orlando | Aviation Photos | 0 | April 22nd 10 09:11 PM |
Mirror Dude - Thunderbird Mirror Dude (Custom).jpg (0/1) | Glen in Orlando | Aviation Photos | 0 | April 22nd 10 09:11 PM |
f4 mirror....... | ~^ beancounter ~^ | Naval Aviation | 0 | December 6th 06 09:17 PM |
ELT Required for all SSA sanctioned contests starting 2006 ELT Required for all SSA sanctione | Steve Leonard | Soaring | 2 | September 14th 05 03:49 AM |
