747-400 questions
Two things bothering me lately:
1. Sometimes when I autostart 2 and 3 after starting 1 and 4, I get an alarm as I pull the start switch or when I pull the start button. However, there's no message on the MFD or anything, so I can't figure out what they aircraft is complaining about. I haven't been able to find a reason in the documentation. Does anyone know what would cause an annunicator to go off when I start 2 or 3? 2. Is there any way to turn off all heading modes in the MCP? That is, neither SEL nor HOLD nor LNAV nor anything else. The idea being that I could use the autopilot to hold altitude but I could still steer the aircraft by hand. Right now I can turn by hand, but the autopilot will turn me back to the previous heading as soon as I release the controls. 3. If I throttle up to 70% and engage TOGA to take off, per the documentation, the autothrottle seems to set the throttle mighty low. This happens when I'm lightly loaded and I still reach rotation speed and all. Is this normal behavior of the autothrottle if rotation speed is low on a lightly loaded aircraft, or am I doing something wrong? If I don't touch the throttles and just press the TOGA switch, I seem to get full throttle (although then I also get an excessive pitch up and climb rate sometimes). What mistake(s) am I making? 4. How can I find an optimal throttle setting for taxi? It seems I'm always either accelerating or decelerating. I'm also surprised at how far I have to advance the throttles just to get moving (and then once I'm moving, I have to throttle back to avoid constant acceleration). This is all in the PMDG 747-400, not the default one. -- Transpose mxsmanic and gmail to reach me by e-mail. |
747-400 questions
Mxsmanic wrote:
Two things bothering me lately: 1. Sometimes when I autostart 2 and 3 after starting 1 and 4, I get an alarm as I pull the start switch or when I pull the start button. However, there's no message on the MFD or anything, so I can't figure out what they aircraft is complaining about. I haven't been able to find a reason in the documentation. Does anyone know what would cause an annunicator to go off when I start 2 or 3? 2. Is there any way to turn off all heading modes in the MCP? That is, neither SEL nor HOLD nor LNAV nor anything else. The idea being that I could use the autopilot to hold altitude but I could still steer the aircraft by hand. Right now I can turn by hand, but the autopilot will turn me back to the previous heading as soon as I release the controls. 3. If I throttle up to 70% and engage TOGA to take off, per the documentation, the autothrottle seems to set the throttle mighty low. This happens when I'm lightly loaded and I still reach rotation speed and all. Is this normal behavior of the autothrottle if rotation speed is low on a lightly loaded aircraft, or am I doing something wrong? If I don't touch the throttles and just press the TOGA switch, I seem to get full throttle (although then I also get an excessive pitch up and climb rate sometimes). What mistake(s) am I making? 4. How can I find an optimal throttle setting for taxi? It seems I'm always either accelerating or decelerating. I'm also surprised at how far I have to advance the throttles just to get moving (and then once I'm moving, I have to throttle back to avoid constant acceleration). This is all in the PMDG 747-400, not the default one. Anthony (aka mzsmanic; alias simpilot). In another post you stated (and I quote), "I do not make spelling mistakes". The most cursory perusal of this, your most recent post, reveals that again you have misrepresented yourself. Please correct your errors, apologise for your previous lie, and hope for some empathic souls to take note of your pathetic existence so that they may bring themselves to provide an answer to your misguided question. Rip |
747-400 questions
On Feb 24, 6:34 pm, Mxsmanic wrote:
Two things bothering me lately: 1. Sometimes when I autostart 2 and 3 after starting 1 and 4, I get an alarm as I pull the start switch or when I pull the start button. However, there's no message on the MFD or anything, so I can't figure out what they aircraft is complaining about. I haven't been able to find a reason in the documentation. Does anyone know what would cause an annunicator to go off when I start 2 or 3? 2. Is there any way to turn off all heading modes in the MCP? That is, neither SEL nor HOLD nor LNAV nor anything else. The idea being that I could use the autopilot to hold altitude but I could still steer the aircraft by hand. Right now I can turn by hand, but the autopilot will turn me back to the previous heading as soon as I release the controls. 3. If I throttle up to 70% and engage TOGA to take off, per the documentation, the autothrottle seems to set the throttle mighty low. This happens when I'm lightly loaded and I still reach rotation speed and all. Is this normal behavior of the autothrottle if rotation speed is low on a lightly loaded aircraft, or am I doing something wrong? If I don't touch the throttles and just press the TOGA switch, I seem to get full throttle (although then I also get an excessive pitch up and climb rate sometimes). What mistake(s) am I making? 4. How can I find an optimal throttle setting for taxi? It seems I'm always either accelerating or decelerating. I'm also surprised at how far I have to advance the throttles just to get moving (and then once I'm moving, I have to throttle back to avoid constant acceleration). This is all in the PMDG 747-400, not the default one. -- Transpose mxsmanic and gmail to reach me by e-mail. Consult the operations manual published by Boeing. Every operator of a 747-400 is issued a copy with purchase of the airplane... |
747-400 questions
advance the throttles just to get moving (and then once I'm moving, I have to throttle back to avoid constant acceleration). That's how it is in real airplanes. BT |
747-400 questions
BT writes:
That's how it is in real airplanes. Good; I like realism. But is there any technique to finding the right throttle setting? The 747 seems particularly prone to this (as compared to a 737). -- Transpose mxsmanic and gmail to reach me by e-mail. |
747-400 questions
747-400 questions
Mxsmanic wrote: writes: Consult the operations manual published by Boeing. Every operator of a 747-400 is issued a copy with purchase of the airplane... Actually, that depends on the contract. However, I don't have access to Boeing's manuals. I guess there are no 747 pilots here. -- Transpose mxsmanic and gmail to reach me by e-mail. Guess you need to buy a Mac Flight game yagu |
747-400 questions
YaguMac writes:
Guess you need to buy a Mac Flight game I need to find intelligent people who know what they are talking about and can answer my questions. -- Transpose mxsmanic and gmail to reach me by e-mail. |
747-400 questions
Again, I'll have to explain things to MXS:
Side note: Way too many of the members of this great Usenet group agmfs have put you in there kill files and wont see this. I am crossposting this for the benefit of the RL Pilots who we have heard that you have ****ed off as well. I never intentionally cross post until now where I feel I have to inform the RL counterpart to this group about the latest events.. You've calm down lately and that is a good thing. Sorry to have to tell you this but you have annoyed way too many people with your arrogant quotes and self righteous attitude. Believing yourself to be an expert and tell people that you know something when you dont is arrogant. When you dont do something in RL and then become an expert because you see it printed by somebody else and take credit for it. Now, thats arrogant. When, this group starts to hear your ****ing people off in the RL Pilots Group because you feel a need to try to be on there level of knowledge, skill and experience. By arguing with them the things you've picked up in here and making the mistake that this is real life and then going back to them and arguing the point. Thats NOT arrogant. Thats just plain stupid. The Real Life Pilots who fly RL planes see that you do nothing, learn nothing and experience nothing but feel you have to tell them who are the real experienced people in the skies what they should know and do. That is ARROGANT! First, there are plenty of 747 Virtual Pilots here and good ones to I might add. The problem is you have ****ed off too many of them and NO ONE wants to help you. Get it, you've come to that point in time that now of all things you need this group to help you after you ****ed off just about everyone. Now do you understand? Some of us have warned you including me. Now the truth hurts, but you will probably rationalize your grave mistake so you wont fully understand the implications of what you've done. Good luck to you, where ever you go. Pushes his chair back, and stands. Waits for a second and then bows. Now turns and walks off into the Sunset to get his first cup of Jo this morning. Not4wood "Mxsmanic" wrote in message ... BT writes: That's how it is in real airplanes. Good; I like realism. But is there any technique to finding the right throttle setting? The 747 seems particularly prone to this (as compared to a 737). -- Transpose mxsmanic and gmail to reach me by e-mail. |
747-400 questions
Hi Not4wood,
"... you have ****ed off too many of them and NO ONE wants to help you. ...." I'll try though, just this once. If Mxsmanic has "calmed down", as you put it, or feels differently about things these days (and, I must say, I perceived the same thing), and wants to participate in the n/g, as all the rest of us do, then one thing he could do is change his moniker, and start afresh, safe in the knowledge that everyone would have the good grace not to trace him (even though, no matter what anyone calls themselves, you get to be able to identify people by their posts, I reckon...). Then, he would get a whole different reception... Just a thought, but, hey, I've been wrong before, mate! Regards, John Ward "Not4wood" wrote in message news:r4eEh.3727$iF.3506@trndny03... Again, I'll have to explain things to MXS: Side note: Way too many of the members of this great Usenet group agmfs have put you in there kill files and wont see this. I am crossposting this for the benefit of the RL Pilots who we have heard that you have ****ed off as well. I never intentionally cross post until now where I feel I have to inform the RL counterpart to this group about the latest events.. You've calm down lately and that is a good thing. Sorry to have to tell you this but you have annoyed way too many people with your arrogant quotes and self righteous attitude. Believing yourself to be an expert and tell people that you know something when you dont is arrogant. When you dont do something in RL and then become an expert because you see it printed by somebody else and take credit for it. Now, thats arrogant. When, this group starts to hear your ****ing people off in the RL Pilots Group because you feel a need to try to be on there level of knowledge, skill and experience. By arguing with them the things you've picked up in here and making the mistake that this is real life and then going back to them and arguing the point. Thats NOT arrogant. Thats just plain stupid. The Real Life Pilots who fly RL planes see that you do nothing, learn nothing and experience nothing but feel you have to tell them who are the real experienced people in the skies what they should know and do. That is ARROGANT! First, there are plenty of 747 Virtual Pilots here and good ones to I might add. The problem is you have ****ed off too many of them and NO ONE wants to help you. Get it, you've come to that point in time that now of all things you need this group to help you after you ****ed off just about everyone. Now do you understand? Some of us have warned you including me. Now the truth hurts, but you will probably rationalize your grave mistake so you wont fully understand the implications of what you've done. Good luck to you, where ever you go. Pushes his chair back, and stands. Waits for a second and then bows. Now turns and walks off into the Sunset to get his first cup of Jo this morning. Not4wood "Mxsmanic" wrote in message ... BT writes: That's how it is in real airplanes. Good; I like realism. But is there any technique to finding the right throttle setting? The 747 seems particularly prone to this (as compared to a 737). -- Transpose mxsmanic and gmail to reach me by e-mail. |
Similar Threads | ||||
PMA Questions | Mike Granby | Piloting | 24 | December 11th 05 11:24 PM |
PMA Questions | Mike Granby | Owning | 24 | December 11th 05 11:24 PM |
IPC questions? | Roy Smith | Instrument Flight Rules | 12 | June 1st 04 10:40 AM |
Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 06:06 AM |
Seven Questions For Michael Moore from a Blogger (was Questions for Mr. Bush, from Michael Moore) | Jim Yanik | Military Aviation | 2 | October 9th 03 09:36 PM |
