LXNAV introduces New ADI Air Data Indicator
Old November 8th 20, 08:28 PM posted to rec.aviation.soaring
John Ackerson
Default LXNAV introduces New ADI Air Data Indicator
I sure hope they launch a 80mm version!
Old November 8th 20, 09:59 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
John Ackerson wrote on 11/8/2020 12:28 PM:
Contact them, tell how much you'd like that! The only difference would be a bigger case and
display, which they already have for the S100, S80, and V80.
Old December 12th 20, 04:54 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I've been asked a lot whether the new LXNAV Airdata Indicator has a built-in backup battery. It doesn't. I'm glad because I'm not a fan of built-in backup batteries. They sit in unused for many months and then charge for the glider's main battery - reducing the main battery's ability to power everything else.
I have 2 recommended solutions for making sure the LXNAV Airdata Indicator is available when you need it.
- Use redundant main batteries that you can easily switch between. I use a Battery1/OFF/Battery2 switch in our glider.
- Use a AA battery pack and change the batteries once a year.
The Goddard-Cable-S3-Backup-Sw-1 wiring harness includes a battery pack for 8 AA batteries. It has an ON/OFF/Backup panel-mountable switch for manually switching from main battery power to the AA backup batteries. It is compatible with the LXNAV S3 variometer, LXNAV ADI (Airdata Indicator), and LXNAV G-Meter. I just finished testing it with the ADI and it ran with the backlight at full brightness for 11+ hours. You can see details he
https://www.cumulus-soaring.com/stor...s3-backup-sw-1
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
Old December 12th 20, 05:56 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
http://www.craggyaero.com/air_data_indicator.htm
Can also be used with LXNAV S3, and Air-Avionics Air Control display Altimeter.
Craggy Aero S3/ADI Backup Battery Pack Holds 8 AA batteries ON-OFF Panel switch will power the V3/ADI for approx 15 hrs.
Switch has 2 positions Main Glider battery, Backup battery.
Richard
www.craggyaero.com
Old December 14th 20, 01:30 AM posted to rec.aviation.soaring
2G
On Saturday, December 12, 2020 at 8:54:52 AM UTC-8, Paul Remde wrote:
Hi,
Good Soaring,
Paul Remde
There is certainly nothing inherently wrong with backup batteries; I ordered that option for my Garmin G5 PFD. The backup is a lithium battery that holds its charge well. Most importantly, I have vital flight data in the event of a main power failure.
Tom
LX Navigation Introduces the New LX 9090 Zeus Dave Springford Soaring 10 February 15th 12 05:04 PM
Craggy Aero Introduces the Ultimate Flight System Richard[_1_] Soaring 18 August 14th 08 04:56 AM
Rep Rangel introduces Draft Bill (for Iran?!): [email protected] Naval Aviation 17 June 5th 06 11:37 AM
AVSIM Introduces New List Server Tom Allensworth Simulators 4 July 12th 04 01:16 AM
Air Force Academy Introduces Sweeping Changes, Looks to Future Otis Willie Military Aviation 1 October 8th 03 07:40 PM
