Looking for a parachute, wing stand and a one-man rigger
Old February 4th 20, 08:25 PM posted to rec.aviation.soaring
Charles Dutch
Default Looking for a parachute, wing stand and a one-man rigger
Before I go into the retail market, I thought I'd check the used market. I'm looking for a;
1) Chair-style parachute (Softie Long, or a Strong 305 Cross-Country are two that are at the top of the list)
2) Wing stand
3) One-man rigger with a narrow wing cradle.
Old February 4th 20, 09:58 PM posted to rec.aviation.soaring
John Foster
2) Wing stand
For a wing stand I know some folks (me included) who use these from Home Depot. I glued a rubber mat to the surface to give a little extra padding as well.
https://www.homedepot.com/p/RIDGID-F...9934/100618242
Old February 4th 20, 10:06 PM posted to rec.aviation.soaring
Knowing your location and ship helps......
1-shipping can be expensive at least due to size of box.
2-what works for a 1-26 may be ill suited for a big winger....
No, I have neither for sale.....
Old February 4th 20, 10:57 PM posted to rec.aviation.soaring
Charles Dutch
On Tuesday, February 4, 2020 at 4:06:45 PM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
Location - North Alabama. I've got experience with the MM Fabrication Wing-rigger, and he has different saddles for the wing thicknesses. What works for a Grob 102 is likely too big for a LS-X, Ventus-X, etc.
Old February 5th 20, 01:14 AM posted to rec.aviation.soaring
Steve Bralla
2) Wing stand
You can glue felt (McMaster-Carr) into a thick wing cradle to fit the thin wing.
Old February 5th 20, 06:03 AM posted to rec.aviation.soaring
Frank Whiteley
Before I go into the retail market, I thought I'd check the used market.. I'm looking for a;
2) Wing stand
I've used these, even with LAK-12 wings. However, I perhaps over-tightened one of the elevation locking handles (LAK-12 wing is heavy after all) and the handle broke. Other than that, they are pretty stout, fold flat and are stable on flat ground. However, I prefer more positive locking systems in general for regular use and these when doing other things.
YMMV
Frank Whiteley
Old February 5th 20, 11:37 AM posted to rec.aviation.soaring
Martin Gregorie[_6_]
2) Wing stand 3) One-man rigger with a narrow wing cradle.
padding as well.
https://www.homedepot.com/p/RIDGID-F...-Work-Support-
AC9934/100618242
other things.
It should be easy enough to drill a hole for a locking pin once you know
the best height setting. Is this a good idea, or would it weaken the
upright too much?
Martin | martin at
Gregorie | gregorie dot org
Old February 5th 20, 03:20 PM posted to rec.aviation.soaring
Cookie
Yes, Home Depot....in the aviation department....glider wing stands...
I understand that some wood workers actually use these glider wing stands as an out-feed for a table saw...go figure...
Get a piece of Styrofoam insulation...2" think...attach to wing stand with double tape...carve to fit the curve of your wing....top off with Gym mat....rubber mat....
Cookie
2) Wing stand
Old February 5th 20, 04:44 PM posted to rec.aviation.soaring
Dan Marotta
My LAK-17a required two height settings, low for pushing the wings home
and high for setting the pins.Â* I simply marked those settings with a
Sharpie.Â* I don't think drilling holes for safety pins would weaken the
uprights very much, but I would drill the holes for the set screws to
fit into.Â* Maybe even thread them.
I've helped rig a LAK-12 several times and, though heavy, the wing tips
aren't that bad.Â* The roots, on the other hand...
padding as well.
AC9934/100618242
other things.
upright too much?
Dan, 5J
Old February 6th 20, 06:28 AM posted to rec.aviation.soaring
Frank Whiteley
padding as well.
AC9934/100618242
other things.
upright too much?
Dan, 5J
230lbs/panel. Locking pin should be doable.
Frank
Parachute rigger in Germany [email protected] Soaring 2 September 10th 18 09:31 AM
Wing Rigger Dan Marotta Soaring 2 September 3rd 16 02:54 PM
Looking for a parachute rigger around New York City... PAGA Soaring 6 December 24th 15 04:20 PM
Parachute Rigger near Ionia Allen Duncan Soaring 2 July 8th 15 12:18 AM
Looking for a used wing rigger / one man rigger .... [email protected] Soaring 0 November 6th 13 06:02 PM
