source for clips or sleaves for Hotelier linkages
On Wednesday, June 24, 1998 at 1:00:00 AM UTC-6, Al wrote:
Lets just say ...."Adaquate" as per Rolls Royce discussing anything mechanical in their sales brochures. Regards Al Armand A. Medeiros wrote: Al wrote: Thanks for all the input guys.. I am now the proud owner of a plethora of clips courtesy of Tim at Wings & Wheels. Regards Al. What kind? Chinsy little things that are .004" to large or good ones like original equipment? Just curious.... AAM Sorry to resurrect this old thread, but my Google-Fu is weak, and in all my searching online I have not been able to find a source for these clips. I'm facing needing to comply with the AD 94-001, and can't find a source for the clips. Anyone have one? It is for a standard airworthiness certificated glider. |
Quote:
I use a medical forceps to work in the ones that are further away from the access . They seem to go easier after a few assemblies . Not cheap but better than pins falling out of your hand into the fuselage . |
I use a hemostat for handling the clips as a gentle squeeze locks them
and I can even let them dangle on the end of the clip's retention string. I got a bag of 50 chrome plated clips for the Hotelier fittings in my glider.Â* I measured the diameter of the spring wire and made a search.Â* Here's an example of what you can get from Grainger: https://www.grainger.com/product/GRA...p-Safety-3LX83 On 7/28/2019 11:21 AM, Delta8 wrote: John Foster;996365 Wrote: On Wednesday, June 24, 1998 at 1:00:00 AM UTC-6, Al wrote:- Lets just say ...."Adaquate" as per Rolls Royce discussing anything mechanical in their sales brochures. Regards Al Armand A. Medeiros wrote: - Al wrote:- Thanks for all the input guys.. I am now the proud owner of a plethora of clips courtesy of Tim at Wings & Wheels. Regards Al.- What kind? Chinsy little things that are .004" to large or good ones like original equipment? Just curious.... AAM-- Sorry to resurrect this old thread, but my Google-Fu is weak, and in all my searching online I have not been able to find a source for these clips. I'm facing needing to comply with the AD 94-001, and can't find a source for the clips. Anyone have one? It is for a standard airworthiness certificated glider. Williams in California . I ordered some clips a couple months ago they are available in right and left hand. They are not easy to install through a ASW 20 access hole but are easily tested . Push the button down if it depresses all the way it's not installed correctly . I use a medical forceps to work in the ones that are further away from the access . They seem to go easier after a few assemblies . Not cheap but better than pins falling out of your hand into the fuselage . -- Dan, 5J |
On Sunday, July 28, 2019 at 1:55:17 AM UTC-5, John Foster wrote:
On Wednesday, June 24, 1998 at 1:00:00 AM UTC-6, Al wrote: Lets just say ...."Adaquate" as per Rolls Royce discussing anything mechanical in their sales brochures. Regards Al Armand A. Medeiros wrote: Al wrote: Thanks for all the input guys.. I am now the proud owner of a plethora of clips courtesy of Tim at Wings & Wheels. Regards Al. What kind? Chinsy little things that are .004" to large or good ones like original equipment? Just curious.... AAM Sorry to resurrect this old thread, but my Google-Fu is weak, and in all my searching online I have not been able to find a source for these clips. I'm facing needing to comply with the AD 94-001, and can't find a source for the clips. Anyone have one? It is for a standard airworthiness certificated glider. Hi John F, I'm familiar with the Phoebus, You will find that the only cheap securing device that clears the tubes in the fuselage is safety wire. Even the smallest pins, R or otherwise will not clear, as the control rods do not stay exactly in the center of the tube. Wedekind sleeves may work, but require 'plunger/wedge'LL'hotelier ends and I'll bet your phoebus has 'rotating cams' replacing the 'rotating cam LL'hoteliers with the 'plunger/wedge' might be close to $1800 then you have to buy the Wedekind sleeves. For What its worth, when you drill the cam plate make sure you have a ball end in the LL'hotelier as the location of the hole is critical. I have also heard of a Schempp-hirth pin/clip but I have never seen one in real life. Best of luck, Scott |
On Monday, July 29, 2019 at 8:46:10 AM UTC-5, Scott Williams wrote:
On Sunday, July 28, 2019 at 1:55:17 AM UTC-5, John Foster wrote: On Wednesday, June 24, 1998 at 1:00:00 AM UTC-6, Al wrote: Lets just say ...."Adaquate" as per Rolls Royce discussing anything mechanical in their sales brochures. Regards Al Armand A. Medeiros wrote: Al wrote: Thanks for all the input guys.. I am now the proud owner of a plethora of clips courtesy of Tim at Wings & Wheels. Regards Al. What kind? Chinsy little things that are .004" to large or good ones like original equipment? Just curious.... AAM Sorry to resurrect this old thread, but my Google-Fu is weak, and in all my searching online I have not been able to find a source for these clips.. I'm facing needing to comply with the AD 94-001, and can't find a source for the clips. Anyone have one? It is for a standard airworthiness certificated glider. Hi John F, I'm familiar with the Phoebus, You will find that the only cheap securing device that clears the tubes in the fuselage is safety wire. Even the smallest pins, R or otherwise will not clear, as the control rods do not stay exactly in the center of the tube. Wedekind sleeves may work, but require 'plunger/wedge'LL'hotelier ends and I'll bet your phoebus has 'rotating cams' replacing the 'rotating cam LL'hoteliers with the 'plunger/wedge' might be close to $1800 then you have to buy the Wedekind sleeves. For What its worth, when you drill the cam plate make sure you have a ball end in the LL'hotelier as the location of the hole is critical. I have also heard of a Schempp-hirth pin/clip but I have never seen one in real life. Best of luck, Scott here's a helpful article; http://aviation.derosaweb.net/wedekind |
On Monday, July 29, 2019 at 7:46:10 AM UTC-6, Scott Williams wrote:
On Sunday, July 28, 2019 at 1:55:17 AM UTC-5, John Foster wrote: On Wednesday, June 24, 1998 at 1:00:00 AM UTC-6, Al wrote: Lets just say ...."Adaquate" as per Rolls Royce discussing anything mechanical in their sales brochures. Regards Al Armand A. Medeiros wrote: Al wrote: Thanks for all the input guys.. I am now the proud owner of a plethora of clips courtesy of Tim at Wings & Wheels. Regards Al. What kind? Chinsy little things that are .004" to large or good ones like original equipment? Just curious.... AAM Sorry to resurrect this old thread, but my Google-Fu is weak, and in all my searching online I have not been able to find a source for these clips.. I'm facing needing to comply with the AD 94-001, and can't find a source for the clips. Anyone have one? It is for a standard airworthiness certificated glider. Hi John F, I'm familiar with the Phoebus, You will find that the only cheap securing device that clears the tubes in the fuselage is safety wire. Even the smallest pins, R or otherwise will not clear, as the control rods do not stay exactly in the center of the tube. Wedekind sleeves may work, but require 'plunger/wedge'LL'hotelier ends and I'll bet your phoebus has 'rotating cams' replacing the 'rotating cam LL'hoteliers with the 'plunger/wedge' might be close to $1800 then you have to buy the Wedekind sleeves. For What its worth, when you drill the cam plate make sure you have a ball end in the LL'hotelier as the location of the hole is critical. I have also heard of a Schempp-hirth pin/clip but I have never seen one in real life. Best of luck, Scott Well, I found a source for the pins, and it's local to me, of all places--Ace Hardware! 0.047" (1.2mm) dia. by 19/32" (15mm) long. When I insert them into the holes I drilled, they barely protrude beyond the diameter of the push rod, and will easily clear the holes in the wing root rib. 32 cents each. |
On Wednesday, July 31, 2019 at 10:59:45 PM UTC-6, John Foster wrote:
On Monday, July 29, 2019 at 7:46:10 AM UTC-6, Scott Williams wrote: On Sunday, July 28, 2019 at 1:55:17 AM UTC-5, John Foster wrote: On Wednesday, June 24, 1998 at 1:00:00 AM UTC-6, Al wrote: Lets just say ...."Adaquate" as per Rolls Royce discussing anything mechanical in their sales brochures. Regards Al Armand A. Medeiros wrote: Al wrote: Thanks for all the input guys.. I am now the proud owner of a plethora of clips courtesy of Tim at Wings & Wheels. Regards Al. What kind? Chinsy little things that are .004" to large or good ones like original equipment? Just curious.... AAM Sorry to resurrect this old thread, but my Google-Fu is weak, and in all my searching online I have not been able to find a source for these clips. I'm facing needing to comply with the AD 94-001, and can't find a source for the clips. Anyone have one? It is for a standard airworthiness certificated glider. Hi John F, I'm familiar with the Phoebus, You will find that the only cheap securing device that clears the tubes in the fuselage is safety wire. Even the smallest pins, R or otherwise will not clear, as the control rods do not stay exactly in the center of the tube. Wedekind sleeves may work, but require 'plunger/wedge'LL'hotelier ends and I'll bet your phoebus has 'rotating cams' replacing the 'rotating cam LL'hoteliers with the 'plunger/wedge' might be close to $1800 then you have to buy the Wedekind sleeves. For What its worth, when you drill the cam plate make sure you have a ball end in the LL'hotelier as the location of the hole is critical. I have also heard of a Schempp-hirth pin/clip but I have never seen one in real life. Best of luck, Scott Well, I found a source for the pins, and it's local to me, of all places--Ace Hardware! 0.047" (1.2mm) dia. by 19/32" (15mm) long. When I insert them into the holes I drilled, they barely protrude beyond the diameter of the push rod, and will easily clear the holes in the wing root rib. 32 cents each. When the Ace clerks ask me what I'm looking for, I always reply that I'm headed to the aircraft parts section. (usually for the metric stuff). |
Well, I found a source for the pins, and it's local to me, of all places--Ace Hardware! 0.047" (1.2mm) dia. by 19/32" (15mm) long. When I insert them into the holes I drilled, they barely protrude beyond the diameter of the push rod, and will easily clear the holes in the wing root rib. 32 cents each. So which pins did you end up using? The "bobbie" pins or other? Enquiring minds want to know Bruce |
I suggest small R clips, the safety pin type are very hard to put in.
On Thursday, August 1, 2019 at 8:09:20 PM UTC-6, Bruce wrote:
Well, I found a source for the pins, and it's local to me, of all places--Ace Hardware! 0.047" (1.2mm) dia. by 19/32" (15mm) long. When I insert them into the holes I drilled, they barely protrude beyond the diameter of the push rod, and will easily clear the holes in the wing root rib. 32 cents each. So which pins did you end up using? The "bobbie" pins or other? Enquiring minds want to know Bruce If you have Facebook, check this link out: https://www.facebook.com/photo.php?f...type=3&theater |
Similar Threads | ||||
Source for L'Hotellier Safety Clips | George Haeh | Soaring | 23 | January 29th 19 01:20 AM |
L'Hotelier Fitting Safety Pins | Dan Marotta | Soaring | 20 | October 17th 16 01:40 AM |
Complete Hotelier Connections For Sale (Brand New) $400 | Scott Alexander[_2_] | Soaring | 2 | July 19th 12 10:40 PM |
Hotelier safety sleeves | [email protected] | Soaring | 6 | August 31st 07 03:41 PM |
Lycoming throttle linkages | Evan Carew | Home Built | 0 | September 29th 04 01:58 AM |
