homemade external/internal antenna for handheld.
The subject sort of tells most of what I'm looking for. I have an
Aeronca and would like to increase the trans/recep of my handheld. There was an article by Weir a couple of years ago in Kitplane, I think, on how to make one. Help? Thanks Mark in third world Wyoming. |
I purchased a commerially available antenna base and had it mounted to a
piece of the aluminum where the left wing meets the fuselage. A doubler plate was riveted to provide extra strength. A length of stainless steel rod cut to mid-frequency length was inserted to serve as the antenna. This was on a 7AC. The antenna coax entered the cabin at the leading edge/canopy junction. gorgon wrote: The subject sort of tells most of what I'm looking for. I have an Aeronca and would like to increase the trans/recep of my handheld. There was an article by Weir a couple of years ago in Kitplane, I think, on how to make one. Help? Thanks Mark in third world Wyoming. |
("john smith" wrote)
I purchased a commerially available antenna base and had it mounted to a piece of the aluminum where the left wing meets the fuselage. A doubler plate was riveted to provide extra strength. A length of stainless steel rod cut to mid-frequency length was inserted to serve as the antenna. This was on a 7AC. The antenna coax entered the cabin at the leading edge/canopy junction. Did this arrangement have some strong points and some weak points - reception wise? How were the results, overall? Montblack |
"Montblack" wrote: ("john smith" wrote) I purchased a commerially available antenna base and had it mounted to a piece of the aluminum where the left wing meets the fuselage. A doubler plate was riveted to provide extra strength. A length of stainless steel rod cut to mid-frequency length was inserted to serve as the antenna. This was on a 7AC. The antenna coax entered the cabin at the leading edge/canopy junction. Did this arrangement have some strong points and some weak points - reception wise? How were the results, overall? What can I say, it worked like a ..... Champ! Rx and Tx with an ICOM A2 and A20 on low power (1/2W) was sufficent for most operations. I could talk air-to-air with friends 35nm away. Can't do that with a rubber duck! |
You could have saved yourself half the price of the "commercially available
antenna base" by using a bulkhead BNC female connector, mounting it to the same piece of aluminum and feeding one side with connector/coax to the radio and the other side with a BNC connector on the other side with a brass brazing rod of your choice in diameter for the radiating rod. Would this be a good Kitplanes column? I know I've made passing reference to this lashup before, but perhaps not in enough detail. Jim "Montblack" wrote in message ... ("john smith" wrote) I purchased a commerially available antenna base and had it mounted to a piece of the aluminum where the left wing meets the fuselage. A doubler plate was riveted to provide extra strength. A length of stainless steel rod cut to mid-frequency length was inserted to serve as the antenna. This was on a 7AC. The antenna coax entered the cabin at the leading edge/canopy junction. Did this arrangement have some strong points and some weak points - reception wise? How were the results, overall? Montblack |
Jim,
That article has already been done by a local RV-4 builder several years ago. I published it in the Puget Sound RVators. WING TIP ANTENNA INSTALLATION by Greg R***** Puget Sound RVators I have heard of a few stories told of people who tried communications antennas installed inside the wing tips on their RV's. All of these stories told of how it did not work and was abandoned. These stories all had two things in common. They were all told to me second, third or fourth hand and they all included many theories as to why antennas located in the wing tip should not work well. The two primary theories were "it has to be vertical" and "it will be blocked by the airplane". During my job as an avionics technician and my 25 years of antenna building "for the fun of it" as an amateur radio operator, I have learned to take antenna theories as a rough starting point only. There is nothing like a successful installation to show that antennas are a bit of a black art! With all this said, I would like to describe the simple communications antenna installation that I have been successfully using on my RV-4 for the past 60 or so hours. This antenna is easy to construct, is very cheap (mine cost coax only, as I had everything in my junk box) and works well for me. It consists of 4 parts: a length of RG-58 coax cable, one SO-239 coax connector, one PL-259 coax connector and one coat hanger. The coax and connectors are available from your local Radio Shack and you can raid the hall closet for the hanger! The SO-239 is a female, bulkhead type, coax connector and requires one large hole and 4 mounting screw holes. I placed this connector at the very forward end of the outboard wing rib (mine is on the right wing, either wing would work as well). The center of the coax is soldered to the center pin of the connector. The shield should be tied to one of the flange mounting screws using a terminal lug and a piece of sleeving to prevent it from touching the center pin. (See sketch) I have Aeroflash strobe power supplies mounted in each wing tip. Although the whip passes close to the high voltage lead from the power supply to the strobe I experience no interference. Those with central strobe power supplies that have high voltage leads down the entire length of the wing may have a pulsing interference problem if the coax is routed near the strobe wire for very far. I have had very good luck with this installation and it shows very little blocking for stations off the opposite wing. In fact, this has proved to be no problem at all. If you have any questions regarding this installation, feel free to call me at 206-353-****. For those who would like to see the installation, sorry, it's hidden in the wing tip! RST Engineering wrote: You could have saved yourself half the price of the "commercially available antenna base" by using a bulkhead BNC female connector, mounting it to the same piece of aluminum and feeding one side with connector/coax to the radio and the other side with a BNC connector on the other side with a brass brazing rod of your choice in diameter for the radiating rod. Would this be a good Kitplanes column? I know I've made passing reference to this lashup before, but perhaps not in enough detail. Jim "Montblack" wrote in message ... ("john smith" wrote) I purchased a commerially available antenna base and had it mounted to a piece of the aluminum where the left wing meets the fuselage. A doubler plate was riveted to provide extra strength. A length of stainless steel rod cut to mid-frequency length was inserted to serve as the antenna. This was on a 7AC. The antenna coax entered the cabin at the leading edge/canopy junction. Did this arrangement have some strong points and some weak points - reception wise? How were the results, overall? Montblack |
I wonder if I could take a SO-239 to BNC male adapter, solder the coat hanger rod into the SA-239 and use the setup instead of the rubber ducky antenna on my Icom A23. Will it work?
Thanks a bunch, Victor Quote:
("RST Engineering" wrote)
You could have saved yourself half the price of the "commercially available antenna base" by using a bulkhead BNC female connector, mounting it to the same piece of aluminum and feeding one side with connector/coax to the radio and the other side with a BNC connector on the other side with a brass brazing rod of your choice in diameter for the radiating rod. (John Smith wrote) "A length of stainless steel rod cut to mid-frequency length was inserted to serve as the antenna. This was on a 7AC. The antenna coax entered the cabin at the leading edge/canopy junction." 1. With a standard handheld, what would the average length be (approx) for the rod(s)? 2. Should the rod be insulated, at any contact points within the wing? If yes, with what? 4. If no, does the rod cantilever away from the BNC connector, without ever touching anything else inside the wing? 5. Does the length of the coax (running to the radio) matter, significantly? 6. Is there a benefit to having one wing 'tuned' to receive and the other wing 'tuned' for transmitting? g Montblack |
"Montblack" wrote in message ... 1. With a standard handheld, what would the average length be (approx) for the rod(s)? It is a function of rod diameter. With an infinitely small diameter wire, the length for each rod would be about 23.2" for a geometric (*) band center of 127 MHz. With a half-inch diameter rod, that would reduce to 20.2 and in between is in between. (*) The geometric center of the band is the square root of the (bottom end of the band times the top end of the band). 2. Should the rod be insulated, at any contact points within the wing? If yes, with what? Electrically, no. Mechanically, probably. A nylon cable clamp would work well. 4. If no, does the rod cantilever away from the BNC connector, without ever touching anything else inside the wing? It can. However, vibration will eventually take its toll. 5. Does the length of the coax (running to the radio) matter, significantly? It does not matter at all. An old wive's tale says that there is a "magic" coax length. Put an orange in the center of your house and start running around the outside. You can see differences in the orange depending on what window you look through, but you never get any closer to the orange no matter where you are relative to it. 6. Is there a benefit to having one wing 'tuned' to receive and the other wing 'tuned' for transmitting? g Why? They are both on the same frequency. Jim |
RST Engineering wrote: Would this be a good Kitplanes column? I know I've made passing reference to this lashup before, but perhaps not in enough detail. Jim, Not being on the mailing list of the Puget Sound RV8ers I think such an article in Kitplanes would be a great idea as do probably many other non RV builders. Thanks and I'll look for it in future issues. Don. |
Similar Threads | ||||
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
Homemade Antenna | Carl J. Hixon | Home Built | 2 | October 27th 04 08:54 AM |
ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 03:27 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
comm's RX antenna | acepilot | Home Built | 5 | March 3rd 04 05:34 PM |
