3000 h check - who? where?
Old July 11th 17, 11:15 PM posted to rec.aviation.soaring
Ivelin Kalushkov
Default 3000 h check - who? where?
Hello to everyone on the forum.
I'm fairly new to gliding - finished my ABC in Australia in the beginning
of this year but I'm originally from Bulgaria where I live at the moment
as well.
I'm looking to buy my first glider at the moment and noticing a lot of
gliders for sale near the 3000 h check (Astirs in particular as I'm
looking for one).
I know the 3000 h check is a fairly big thing but I don't know where it
could be done in Central Europe and how much would it cost?
Any help and information would be appreciated!
All the best.
Ivelin
Old July 12th 17, 08:53 AM posted to rec.aviation.soaring
Ross[_3_]
Depending where you are I can suggest Aerospool in Slovakia.
They can do everything required and are very professional.
Old July 12th 17, 11:59 AM posted to rec.aviation.soaring
What is a 3000 h check?
Old July 12th 17, 12:45 PM posted to rec.aviation.soaring
Eric Munk
Lifetime extension. Usually lots of hours, little out-of-pocket costs.
Old July 12th 17, 04:38 PM posted to rec.aviation.soaring
Scott Williams
What I understand of a 3000 hr life extension inspection;
The original manufacturer (or later the type certificate holder) has set forth a specific set of inspections which are more comprehensive than an annual inspection of airworthiness.
Sometimes some components are identified as mandatory replacement items.
Sometimes access holes have to be cut to inspect otherwise inaccessible parts, then these holes are patched.
Some makers charge a fee for serial number specific documents, some makers require this work to be done at their facility or repair station.
Your experience may differ. It doesn't sound inexpensive to me.
Good luck!
Scott
PIK 20 and 3000 hrs limit poul g Soaring 1 August 11th 09 03:30 PM
Pegasus 3000 hr fiasco Doug Soaring 3 October 22nd 08 03:08 PM
G103 3000 hr inspection [email protected] Soaring 1 November 3rd 07 08:59 PM
LS6C 3000 Hour Check John Bridge Soaring 1 July 8th 06 11:59 AM
amd64 3000 Smokeyone Simulators 0 November 4th 04 09:29 AM
