#11
ILS DME strength?
I haven't checked thru the detail, but FAA Flight Inspection publishes its
data sheets online. You can search for the navaid and display the data from the last inspection. http://avnwww.jccbi.gov/datasheet/ Gerry wrote in message oups.com... I have noticed very similar issues with the ILS DME at APA. I either get nor reading or it bounces all over the spectrum until I get quite close. Switching over to several other VOR frequencies in the vicinity creates no such problems. I can only assume that DMEs co-located with ILSs are significantly less strong. |
Similar Threads | ||||
Garmin 430 and Comm Strength - Solved! | Marco Leon | Owning | 0 | December 17th 04 05:15 PM |
Garmin 430 and Comm Strength - Solved! | Marco Leon | Piloting | 0 | December 17th 04 05:15 PM |
If I make it stronger | Jdandy | Home Built | 9 | August 30th 04 08:22 PM |
Bomber Command strength | Drazen Kramaric | Military Aviation | 2 | July 22nd 04 07:09 AM |
Tubing strength | Ernest Christley | Home Built | 0 | January 16th 04 11:43 PM |
