Thunder Ridge Airpark
Old June 9th 20, 04:24 PM posted to rec.aviation.soaring
Jim[_18_]
Default Thunder Ridge Airpark
Does anyone have information on Thunder Ridge Airpark in Utah? Is it landable for a 20 meter ship? Airnav shows the runway as only 48 feet wide, on the video online the brush looks low on the sides.
Thanks, Jim Dingess
Old June 9th 20, 05:09 PM posted to rec.aviation.soaring
Steve Koerner
You can measure runway width in Google Earth.
Old June 9th 20, 08:16 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Perhaps old age has robbed me of my sense of adventure. However, I would no sooner measure runway width with Google Earth than I would measure the same space with my wingspan. If only the FAA or private org published a book that had, you know facts, data, regarding the runway width, length, lighting, freq. Oh if only... http://www.airnav.com/airport/UT83
Old June 9th 20, 09:23 PM posted to rec.aviation.soaring
Jim[_18_]
The original post indicated that I looked at Airnav.
My home airport main runway is listed as narrower than my wingspan. The cleared area is much wider than the published width of the runway so am able to safely operate there.
Would like to know if Thunder Ridge is the same. Could fly my super cub up and take a look but it’s a long way at 90 knots.
Old June 9th 20, 09:33 PM posted to rec.aviation.soaring
Once again, when using Google Earth for airfield evaluation, CHECK THE DATE OF THE PHOTO in the Timeline. Moriarty's photo is over four years old. And it's the same for all other fields in the area.
Old June 9th 20, 10:40 PM posted to rec.aviation.soaring
Or contact the owner...
Old June 10th 20, 06:04 AM posted to rec.aviation.soaring
Jonathan St. Cloud
The FAA publishes the Airport Facilities Directory.
Old June 10th 20, 06:39 AM posted to rec.aviation.soaring
2G
Hmmm, I just measured the A/P with Google Earth and it was right at the published 48 ft. Even better, I could get an idea of the shrub growth on either side of the runway (it looks low). More importantly, there is a 140 ft elevation difference between one end and the other, which is NOT in the A/P info.
Tom
Old June 10th 20, 06:59 PM posted to rec.aviation.soaring
Dan Marotta
Take the cub and enjoy the flight!
Dan, 5J
Old June 10th 20, 08:53 PM posted to rec.aviation.soaring
2KA
I've flown over Thunder Ridge a couple of times in an airplane, and I can confirm that the brush looks pretty low -- at least from the air. It is a private field though, and really only should be considered as an emergency choice. It is generally easy (and advisable) to stay high enough in that vicinity to keep either Heber or Duchesne within gliding range. The CUP comments (generated by my website at http://www.soaringdata.info) for that airport say:
PRI (UT83)|RY 13/31:4000x48-ASPH|WILDLIFE ON RY, RY 31 NOT RECOMMENDED FOR DEP, RY 13 NOT RECOMMENDED FOR LND DUE TO RISING TRRN.|OWNER DESIRES CHARTING.|
The comments also give an owner contact and phone number.
Lynn Alley
"2KA"
CAC/PAC JF-17 Thunder pics [09/10] - JF-17 Thunder- New Chinese Pakistani Fighter.jpg (1/1) Miloch Aviation Photos 0 January 13th 19 02:52 PM
CAC/PAC JF-17 Thunder pics [02/10] - CAC PAC JF-17 Thunder Combat Aircraft.jpg (1/1) Miloch Aviation Photos 0 January 13th 19 02:52 PM
Yankee Museum Airpark Indexes [3/3] - YAM Airpark Index 3.jpg (1/1) Indrek Aviation Photos 0 August 17th 10 01:50 AM
Yankee Museum Airpark Indexes [2/3] - YAM Airpark Index 2.jpg (1/1) Indrek Aviation Photos 0 August 17th 10 01:50 AM
Yankee Museum Airpark Indexes [1/3] - YAM Airpark Index 1.jpg (1/1) Indrek Aviation Photos 0 August 17th 10 01:50 AM
