Robot coordination
In his lab at Penn, Vijay Kumar and his team build flying quadrotors,
small, agile robots that swarm, sense each other, and form ad hoc teams -- for construction, surveying disasters and far more. If these things can keep from running into each other, why is it so hard to design and implement a system to keep sailplanes apart? http://www.youtube.com/watch?v=cfR6t...otation_459294 Boggs |
Robot coordination
On Mar 5, 11:39*am, GARY BOGGS wrote:
In his lab at Penn, Vijay Kumar and his team build flying quadrotors, small, agile robots that swarm, sense each other, and form ad hoc teams -- for construction, surveying disasters and far more. If these things can keep from running into each other, why is it so hard to design and implement a system to keep sailplanes apart? http://www.youtube.com/watch?v=cfR6t...nnotation_id=a... Boggs The jellyware in the cockpit. |
Robot coordination
On Mar 5, 2:46*pm, Grider Pirate wrote:
If these things can keep from running into each other, why is it so hard to design and implement a system to keep sailplanes apart? Avoid gaggles? |
Robot coordination
In his lab at Penn, Vijay Kumar and his team build flying quadrotors, small, agile robots that swarm, sense each other, and form ad hoc teams -- for construction, surveying disasters and far more. If these things can keep from running into each other, why is it so hard to design and implement a system to keep sailplanes apart? http://www.youtube.com/watch?v=cfR6t...nnotation_id=a... Boggs It's all preprogrammed moves, all worked out on a computer before the flight profile is uploaded to each unit. They are all synced to the same clock. T |
Robot coordination
Really? I thought they were sensing each other in some way?
Boggs |
Similar Threads | ||||
Visual coordination of turns revisited | Mxsmanic | Piloting | 50 | February 14th 07 03:57 AM |
Robot Plane Drops Bomb in Successful Test The Associated Press | Otis Willie | Military Aviation | 0 | April 19th 04 09:50 PM |
Auto Coordination | N14FA | Simulators | 5 | February 1st 04 11:55 PM |
Dutch roll coordination technique | Matthew Jurotich | Piloting | 8 | January 5th 04 02:17 PM |
