#41
Autogas Tips and Tricks
"Orval Fairbairn" wrote in message news In article , "Blueskies" wrote: "john smith" wrote in message ... In article . com, Jay Honeck wrote: Sorry Dan, but I can't let this lay. You are spreading dangerous and misleading misinformation. Jay, just because your engine works well with it does not mean others will. There are many variables. That is why there is an STC for each aircraft/engine combination. Exactly right, and if Cubdriver used autogas with a STC then it should work as published, no issues with operation. However, if there is not an STC then all bets are off. I would be surprised if there was not a STC for the old Cubs however.... The old Cubs were designed to run on WW-II "combat gas," which was the mogas issued to run Jeeps, trucks, tanks, etc. The STC equipment for the Cub is a clip fastened to a pushrod housing and a note on the gas cap. Thanks! And that means that all testing has been done using 87 "octane" mogas and the engine operated completely normally with no new or additional operating limitations. Cubdriver said "More serious for me, sitting in the back seat, was that the engine was prone to quit. The worst moment was flaring on landing, when the airstream stopped driving the prop, the prop stopped driving the engine, and the engine stopped. Most pilots claim that the engine runs better on mogas, but this was not my experience." This issue is likely a mis-adjusted engine mixture or a bad carb than an issue with mogas usage... |
#42
On 1 May, 04:25, Orval Fairbairn wrote:
In article , "Blueskies" wrote: "john smith" wrote in message .. . In article . com, Jay Honeck wrote: Sorry Dan, but I can't let this lay. You are spreading dangerous and misleading misinformation. Jay, just because your engine works well with it does not mean others will. There are many variables. That is why there is an STC for each aircraft/engine combination. Exactly right, and if Cubdriver used autogas with a STC then it should work as published, no issues with operation. However, if there is not an STC then all bets are off. I would be surprised if there was not a STC for the old Cubs however.... The old Cubs were designed to run on WW-II "combat gas," which was the mogas issued to run Jeeps, trucks, tanks, etc. Well, not exaclty, the A65 and it's predecessors were designed before WW2 and in any case weren't designed for the military market, but there wasn't much difference in Avgas and autogas at the time anyway. The Cont. A-40, 50 and 65 were all designed with a min octane rating of 73, which required no lead whatsoever to achieve. Their compression ratio is sop low they don't get hot enough for the various ingredients of higher lead fuels to digest the mix properly, resulting in deposits on the plugs and valve stems gumming up the works anyway. 100LL has a considerable amount of lead in it still (about 4X the amount 80/87 has) and these engines don't like it one little bit. Of course, you can always dump a little Marvel Mystery oil in there, which not only lubes the top end, it helps burn off deposits... MY old Le Blond is rated for 60 Octane fuel! I'm checking into the viability of running it on carrot juice.. Bertie |
#43
The OP asked about using MoGas & this has turned into a discussion
dissing Ethanol laced fuels (which should be dissed). But if you get a candidate auto gasoline, it can be easily tested to make sure it isn't adulterated by ethanol. Mix 1 part of water with about 10 parts of sample gasoline in a test tube, shake for a couple of minutes, and see if the apparent water level has increased. If not, it does not contain alcohol. Trying to remove alcohol with water is suicidal. The resulting octane number is lowered creating the possibility of a detonation related engine failure. If your state has mandated ethanol for autos, look for an alternate source such as marinas or other specialty pumps. One problem with E-10 fuels is an engine will only deliver about 95% of full horsepower on the stuff. There is a long term hose compatibility problem & possibly the accelerator pump & needle-and-seat in the carb bowl will give trouble. The needle tip may not be compatible, and if it sticks, you might have an engine failure. Your float should already have been changed back to metal if all the carb ADs have been complied with. Your tanks are metal too. There are elastomeric seals in your fuel selector and primer, but I got 20 years of autofuel use out of my 172M without seal service or any other difficulty. Some will argue the vapor pressure of autofuel is higher (yes it generally is). But you don't have a fuel pump and your gravity-based Cessna fuel system is quite resistant to vapor lock. Your 172's brothers have a rare fuel delivery problem that is mystery-based & that's why the placard for single tank above 5000 ft msl has been added. This problem was encountered back in the days of never-use- autofuel-or-you-will-crash. Actually the vapor pressure difference between autofuel and AvGas is alternatively eaten up by only about a 15 degreeF fuel temperature difference. Where is the rule saying you can't paint your wings black (vs cooler white)? Fuel delivery systems that are marginal on autofuel will usually be marginal on AvGas too. Starting will be a little different - particularily if your aircraft has been sitting for weeks. On shutdown, I first shut off the fuel & run the carb bowl empty if the plane is going to sit more than a couple of weeks. It does make restart simpler. Occasional use of 100LL might help the exhaust valves - or it may be an old wives tale. Many do say breakins of a new or fresh majored engine should involve some leaded fuel. Your plugs will easily go 100+ hours without cleaning. Your oil will not get gray from lead in the blowby. You might want to install an EGT as it seemed to me that my engine ran slightly leaner with autofuel. I found the fuel consumption of autofuel is slightly less. I think it weighs very slightly more per gallon. Autofuel does not cause warts or hemorrhoids (sp?). |
#44
On 29 Apr 2007 20:47:01 -0700, Jay Honeck wrote:
If your engine was quitting on final, I would have some serious maintenance done on your Cub -- *or* I'd carefully check the quality of your fue Sorry, but that's the way it happened, and as a result (plus the fact that the instructors didn't like the smell) that the airport yanked the STCs on its Cubs. They have operated on 100LL for the past two years, with none of the quitting problems that afflicted them in cold weather during the mogas era. I appreciate that the experience is politically incorrect, and I knew it would upset people. But it wasn't my experience, and it wasn't my Cub; I was only a renter. Scores of other pilots flew the Cubs with mogas and had the experience of engines quitting in cold weather. He restarted it by diving at the beach.) For this airport, and its two rental Cubs, mogas was a bad experience. The airport still sells mogas. I buy it for all my small engines, since this part of the state went to ethanol-diluted gasoline last fall. Say it ain't so, if you like. But it was so. Blue skies! -- Dan Ford |
#45
Cubdriver wrote:
On 29 Apr 2007 20:47:01 -0700, Jay Honeck wrote: If your engine was quitting on final, I would have some serious maintenance done on your Cub -- *or* I'd carefully check the quality of your fue Sorry, but that's the way it happened, and as a result (plus the fact that the instructors didn't like the smell) that the airport yanked the STCs on its Cubs. They have operated on 100LL for the past two years, with none of the quitting problems that afflicted them in cold weather during the mogas era. I appreciate that the experience is politically incorrect, and I knew it would upset people. But it wasn't my experience, and it wasn't my Cub; I was only a renter. Scores of other pilots flew the Cubs with mogas and had the experience of engines quitting in cold weather. He restarted it by diving at the beach.) For this airport, and its two rental Cubs, mogas was a bad experience. The airport still sells mogas. I buy it for all my small engines, since this part of the state went to ethanol-diluted gasoline last fall. Say it ain't so, if you like. But it was so. Blue skies! -- Dan Ford Were the buying the mogas in small quantities frequently or in a large tank infrequently? It is quite well-known that mogas has a summer blend and a winter blend (or blends in some areas). The winter blend has a higher RVP. If you burn summer auto fuel in cold weather, you are asking for trouble. I ran mogas in my Skylane for 6 years in fairly cold northern PA winters and never had a "quiting" problem. I had only a 50 gallon tank so I typically bought the fuel on the way to the airport so it was always both fresh and in season. Matt |
#46
If you got gasoline in season and you bred it, could you get litters of
gasopuppies? Jim "Matt Whiting" wrote in message ... I had only a 50 gallon tank so I typically bought the fuel on the way to the airport so it was always both fresh and in season. Matt |
#47
RST Engineering wrote:
If you got gasoline in season and you bred it, could you get litters of gasopuppies? No, you would get liters. :-) Matt |
Similar Threads | ||||
MoGas Tips, Tricks, Concerns, How To | Al Gilson | Owning | 129 | May 17th 06 08:20 PM |
A List to add to your bag of tricks... | jsmith | Instrument Flight Rules | 1 | April 8th 05 07:13 PM |
Pocket PC Tips & Glide Navigator II Tips | Paul Remde | Soaring | 0 | December 14th 04 08:21 PM |
"Dirty Tricks" and "Both Sides Do It" | Leslie Swartz | Military Aviation | 19 | March 29th 04 06:11 PM |
Stupid Pilot Tricks | David Dyer-Bennet | Piloting | 3 | October 19th 03 12:22 AM |
