#11
Flapped Glider Recommendations...
"noel.wade" wrote in message : SNIP I would be curious to hear more information about how the LS fittings are "semi-automatic". I've seen guys with PIKs and ASW's fishing around behind their seat for control hookups and it just didnt look like any fun! :-P Noel, The flapperons (LS3) or the flaps (LS3-a) connect by aligning a pin on the side of the fuselage into a receptacle in the edge of the flap(peron). On the LS3-a you also need to connect the ailerons (L'Hottellier fittings) under the turtledeck and pin them or engage the safety sleeves. This is probably what you remember seeing people work on. However, with just a small amount of practice, one can do them by feel only, safety them, and test them in a _very_ short time. If it takes me longer than 25-30 seconds (TOTAL! Including safetying and testing) then I am not paying attention. The first time I did it, it seemed like it took me 15 minutes to do it. The second time it took only a couple of minutes. After a few more times, well under a minute. So, at least on an LS3-a, it just is not an issue. Larry Goddard Former LS3-a driver |
Thanks for the LS info, Larry!
Ray - Great, but how do I find out how "nice" the trailer is without flying around the country and looking at each one of them? :-P Everyone says they have a "good" trailer - but the definition of "good" seems to vary a lot based on who's selling and who's buying! heheheh... I totally agree, though. Our club used to have a Russia and it got a bad reputation for never being flown. The club got rid of it before I joined. People said it was good to get rid of it, but with a little bit of probing I found out that people LOVED it in the air - they just HATED dragging it awkwardly out of the trailer. This is another place where my Russia has spoiled me - its a custom-built trailer where the wings are on sliding tracks, and the front and rear doors capture the wing roots & tips to keep the whole thing secured for trailering. LS drivers: What do you think about the fact that the airbrake and flap handles share space? Johnson's review dinged both the 3 and the 3a for this. How much does it annoy you? Are you ever concerned that you'll have to put the flaps down at high speed (contrary to the POH) in order to get the spoilers out? Thanks a bunch, take care, --Noel |
On Jan 7, 8:03*pm, "noel.wade" wrote:
snip Since I also help friends rig an Apis or two, then watch G102s and PIKs and an Open Cirrus struggle to get hooked up, I'm a bit gunshy about heavy and non-automatic-hookup aircraft. *Perhaps unnecessarily so? SNIP It's taken a few goes to get the hang of making the connections in my glider, but it really doesn't take long though I do get someone else to check it after I've taken it to the launch point. It has hoteliers with sleeves so the trick is to be able to do three things at once with one's hand. I guess it helps I've got a smaller hand than the average guy, plus the hatch has a camming device to hold it on so no need to tape it for that purpose. However, the elevator is self-connecting. I was told that there have been a lot of accidents with mis-connected elevators, including one where the owner rigged correctly and went away. Someone else took the elevator off for some reason and put it back unconnected. The owner winch launched, realised there was a problem and at the top of the launch bailed out, thankfully successfully. I've also been told that the person that fiddled with it has since gone on to become an aircaft accident inspector! |
On Jan 7, 1:51*pm, "noel.wade" wrote:
Thanks for the LS info, Larry! Ray - Great, but how do I find out how "nice" the trailer is without flying around the country and looking at each one of them? :-P *Everyone says they have a "good" trailer - but the definition of "good" seems to vary a lot based on who's selling and who's buying! heheheh... I totally agree, though. *Our club used to have a Russia and it got a bad reputation for never being flown. *The club got rid of it before I joined. *People said it was good to get rid of it, but with a little bit of probing I found out that people LOVED it in the air - they just HATED dragging it awkwardly out of the trailer. *This is another place where my Russia has spoiled me - its a custom-built trailer where the wings are on sliding tracks, and the front and rear doors capture the wing roots & tips to keep the whole thing secured for trailering. LS drivers: *What do you think about the fact that the airbrake and flap handles share space? *Johnson's review dinged both the 3 and the 3a for this. *How much does it annoy you? *Are you ever concerned that you'll have to put the flaps down at high speed (contrary to the POH) in order to get the spoilers out? Thanks a bunch, take care, --Noel Noel, I've been flying a LS 3a for a year and so far the flap/spoiler operation has not been an issue. I have yet to be in a position to where I felt the need to depoly the spoilers at high speeds. I can self rig the ship in about 30 to 40 minutes. I use pins to safety the airleron connections and that does take the most time. My hands get a little sweatty here in the Arizona sun. MIke |
Do not forget the PIK-20 that comes in different versions. It has a similar airfoils as the previously mentionned gliders and performs almost as well as a LS-4. They are available at or below $20K and are, to me, the best value for the money. They also do not have a gel coat finish with the accompanying problems of old age.
Mine is a 20B with the carbon spar option, which saves about 30 Lbs per wing. There is no self rigging but is easy and fast to set up. I fly in Eastern Canada with conditions similar to what you describe, most of the time, and I have a ton of fun. It climbs as well as anything we have in the club with the main difference being the pilot. I still have many years of fun learning ahead of me. Richard F. Quote:
I can self rig the ship in about 30 to 40 minutes. *I use pins to safety the airleron connections and that does take the most time. *My hands get a little sweatty here in the Arizona sun. Thanks for the info! How are the spoiler hookups - similar to the ailerons? --Noel |
: I can self rig the ship in about 30 to 40 minutes. I use pins to safety the airleron connections and that does take the most time. My hands get a little sweatty here in the Arizona sun. Thanks for the info! How are the spoiler hookups - similar to the ailerons? --Noel Sorry for omitting that earlier, Noel, The spoilers are automatic as well. There is a rotating shaft with 2 pins in the side of the fuselage that inserts into a receptacle on each wing. Wing will not go on unless this is properly positioned. Larry |
My LAK 12 has a combination of automatic and manual control hook-ups.
The maual ones fit easily and are a pleasure to use - tha automatic ones rely on the wings (flaps) and elevators being lined up perfectly before the final push. If everything in not perfectly lined - the links tend to damage the sockets into which they fit and the whole wing does not go on - not an ideal situation. Modern automatic hookups look fantastic but poorly designed ones are no easier than manual hook- ups. Clinton LAK 12 |
Noel:
For starters, you can tell a good trailer if it says Cobra, Komet, Eberle or Pfeiffer on it. There are some dogs within these makes but it is a good starting point. As has been pointed out, if the trailer sucks (you are exhausted +/- bleeding +/- damage to glider after rig or derig), it really takes the joy out of flying and you begin to weight the hassle: fun ratio every time you think about flying. |
The top names that spring to mind a *Mini-Nimbus, Mosquito, LS-3.
(And yes I've read the Moffat article, Johnson Reports, and done a crap-load of research online about these planes) I notice you havn't got the ASW 20 on your list? The combination of performance, quality and general ease of use would put this aircraft near the top of my list within the budget you are considering. Just wish my LAK was as easy to rig and de-rig as an ASW 20 - even without automatic control linkages. Clinton LAK 12 |
Similar Threads | ||||
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider | [email protected] | Soaring | 5 | November 19th 06 11:08 PM |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
Schweizer 1-35 and other flapped sailplanes | Jack | Soaring | 39 | August 22nd 05 08:57 PM |
CHT recommendations | Dude | Owning | 3 | December 26th 04 05:07 PM |
MFD recommendations | Richard Kaplan | Products | 13 | January 27th 04 04:04 PM |
