Help with Grob Needed
Old January 10th 04, 04:24 AM
Scott
Default Help with Grob Needed
We're having some difficulty getting repairs done on our grob 103. we have
an aileron with a diagonal crease in it from the trailing interior edge to
the leading outside edge of the aileron. Anyway, Grob America here in Ohio
has taken our wings, but with pessimistic views. They have said they've had
trouble with talking to Grob on what needs to be done. I was wondering if
anyone out there has any contacts directly to Grob to get something done. Or
if anyone knows anyone out there with information on what to do and what
needs to be done, whether it is to be replace fixed or whatnot. Thanks in
advance to anyone who can help.
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old January 10th 04, 02:53 PM
JJ Sinclair
Scott,
More information, please. How was the aileron damaged and exactly what is the
damage? Ailerons can be repaired as long as the total weight and trailing edge
weight doesn't exceed the specs.
JJ Sinclair
Old January 10th 04, 04:18 PM
Scott
We're not sure how it was damaged. It looks like it took time to develop.
The only damage is the stress line ,I had called it a crease, it's on the
bottom only and it is a line popped out. Almost as if someone took a steel
rod with a lot of pressure from the insides and drug it in the manner I
described before. Grob America hasn't been not wanting to work on this at
all because of delays/no help from Grob Germany. They told us to just keep
flying it. We flew it most of the summer with this damage, but our A&P wont
sign it off unless this is fixed. The only thing we can see the damaged
coming from is turning hard while flying to fast. We just want to be able to
fly it this spring.
"JJ Sinclair" wrote in message
Scott,
edge
JJ Sinclair
Old January 10th 04, 05:45 PM
JJ Sinclair
If memory serves me right, the lower skin is made up of 3 layers of thin cloth
(92110) and has no foam core. Where this thin skin meets the stronger top skin,
a gelgoat crack may develop. I would grind away some gelgoat in the crease area
and see if the glass fibers are broken. If not, you are safe to keep flying it,
its just a cosmetic repair. If the fibers are broken, I would ask Blufton to
repair it. Note, after repairs one must weigh the aileron and then suspend it
on its hinges and check for trailing edge weight to be within specs. Additional
counter balance may be added to the area forward of the hinge line as long as
total aileron weight is not exceeded.
JJ Sinclair
Old January 11th 04, 02:42 AM
Steve
The Grob 103 Twin II Repair Instructions Manual I have, dated
September 1981, says the lower surface of the aileron is 2 layers
92125 diagonal. No core material. All the rest of what JJ said, I
would say is good and true.
Does this mark run the full span of the aileron, or at roughly 45
degrees to the aileron? You said it goes from the trailing interior
edge to leading outside edge of the aileron. It could simply be a
crack in the finish at the edge of an overlap joint of the outer layer
of glass structure.
Steve Leonard
Old January 11th 04, 05:07 AM
Scott
That is correct about the line.
"Steve" wrote in message
om...
of glass structure.
Steve Leonard
Help, Need Complete Front Canopy for Grob 103 Carl Buehler Soaring 0 December 28th 03 02:15 AM
Grob 103 bulletin becomes AD Mike Borgelt Soaring 0 October 3rd 03 12:47 AM
Grob Repair BTIZ Soaring 3 September 30th 03 04:14 PM
how many pounds thrust needed ? cdubya Soaring 10 September 14th 03 04:28 AM
E2-C wheel bearings needed CaptAro Restoration 1 July 19th 03 04:32 AM
