#11
Experimental Airworthiness
We have an glider that has gone through the same process.
The original Airworthy Cert was for one year and then it expired, this was in 1980-1981. The owner then applied for a new Cert and it has no expiration but it does require annual "condition inspections" per the glider factory published maintenance manual and AC43 Apx D. Just based on what you have provided for information. I would say that your glider has been flying since 5/5/1984 illegally. I am surprised that all of the previous AIs signed off the condition inspection without a valid Airworthy Certification. Go to www.faa.gov and search for your aircraft records, you can get a copy of everything the FAA has on file on a CD for about $10 and it takes about two weeks to process. You can order it on line. I have done this for all of our aircraft and for aircraft we were looking to purchase but then did not because we found paperwork or other issues such as an unclean title. A loan or lien against the aircraft that was never properly released. BT "PS" wrote in message ... I just purchased a glider that has a Special Airworthiness Cert., Experimental Category, Exhibition and Racing. The "Date of Issuance" was 5/6/1983, as was the Operating Limitations and log entry. To the right of the Issuance date on the certificate is the "Expiry" which shows one year later as 5/5/1984. The operating limitations makes no mention of an expiration, in fact it has the paragraph stating that "no person shall operate...unless condition inspections are done in the preceding 12 months" (which would be for the second and future years), and it mentions condition inspections (plural) are to be recorded. The entry in the log by the same FAA Rep. makes no mention of an expiration. This would have me think that the intent of the FAA representative was to make the certificate of unlimited duration as I would expect. The FAA database also shows no problems that I can tell, such as an expired airworthiness certificate. Is this typical to have an "Expiry" date on the cert. or do I have an issue? I hate to lose my loose operating limitations by having to apply again. Can anyone explain? |
PS,
I had a similar experience. When I went for my first annual, the A&I told me I needed current operating limitations for current area. (glider came from Reno, now based in southern California). (Check Tim Mara's post). Basically I had been flying illegally for a year. Yikes! A call to the San Diego FSDO got it solved ASAP. I faxed the Reno limitations, he used it as a template, and faxed me back ones for my domicile. Sent me a new airworthiness certificate if I promised to send him the old one back! The inspector was very casual and nonchalant about the issue. He said the FAA is very concerned about high performance Experimental warbirds being flown by marginally qualified rich folks. Most FSDOs are not at all concerned about gliders and glider pilots so your paperwork should be a breeze. Good luck, happy soaring. Dean |
On Jun 30, 1:28*pm, PS wrote:
On Jun 30, 1:10*pm, wrote: On Jun 30, 12:13*am, PS wrote: I just purchased a glider that has a Special Airworthiness Cert., Experimental Category, Exhibition and Racing. The "Date of Issuance" was 5/6/1983, as was the Operating Limitations and log entry. To the right of the Issuance date on the certificate is the "Expiry" which shows one year later as 5/5/1984. The operating limitations makes no mention of an expiration, in fact it has the paragraph stating that "no person shall operate...unless condition inspections are done in the preceding 12 months" (which would be for the second and future years), and it mentions condition inspections (plural) are to be recorded. The entry in the log by the same FAA Rep. makes no mention of an expiration. This would have me think that the intent of the FAA representative was to make the certificate of unlimited duration as I would expect. The FAA database also shows no problems that I can tell, such as an expired airworthiness certificate. Is this typical to have an "Expiry" date on the cert. or do I have an issue? I hate to lose my loose operating limitations by having to apply again. Can anyone explain? Reading of text will probably show that this date is 12 months to the day from issuance. This requires condition inspection after which it would be good for 12 months to the day. read the paragrapg related to condition inspection. Duration, other than that condition, was unlimited and none had geographical limitations, to my knowledge. All of that changed when new rules were published effective 7/9/97. After that time, the current requirements to be controlled by your local district office, area limitatiions, etc., went into effect. DON'T lose your old limitations, you likely would not get them again. That said, read what the text says and comply. Good luck UH- Hide quoted text - - Show quoted text - Thanks UH, I like your interpretation best. I would feel more comfortable with this if the operating limitations more clearly stated that a condition inspection would extend the special airworthiness cert. for another 12 months. Are you saying that since the operating limitations do not state an expiration, but instead state that condition inspections are required every 12 months, that this supersedes the expiration date shown on the airworthiness certificate (which was one year from the issue date)?? Is there an FAA Order or an FAA rep. that can clarify this? FAA Order 8130.2Fchg3, Section 10, para 155b b. Air Racing. Operating an aircraft to demonstrate its flight characteristics or capabilities in connection with sales promotions for the aircraft is not considered to be an eligible operational purpose under the air racing category. A certificate for experimental air racing must only be issued when an aircraft is to be used for valid air racing purposes. The duration of an airworthiness certificate for air racing is unlimited. Group I and ALL apply throughout the order. Post moratorium aircraft require new operating limitations upon change of owner or FSDO, but the airworthy should travel, except in some cases where the prior owner neglected to sign off Phase 1;^) Frank Whiteley |
On Jun 30, 1:15*pm, wrote:
On Jun 30, 3:28*pm, PS wrote: On Jun 30, 1:10*pm, wrote: On Jun 30, 12:13*am, PS wrote: I just purchased a glider that has a Special Airworthiness Cert., Experimental Category, Exhibition and Racing. The "Date of Issuance" was 5/6/1983, as was the Operating Limitations and log entry. To the right of the Issuance date on the certificate is the "Expiry" which shows one year later as 5/5/1984. The operating limitations makes no mention of an expiration, in fact it has the paragraph stating that "no person shall operate...unless condition inspections are done in the preceding 12 months" (which would be for the second and future years), and it mentions condition inspections (plural) are to be recorded. The entry in the log by the same FAA Rep. makes no mention of an expiration. This would have me think that the intent of the FAA representative was to make the certificate of unlimited duration as I would expect. The FAA database also shows no problems that I can tell, such as an expired airworthiness certificate. Is this typical to have an "Expiry" date on the cert. or do I have an issue? I hate to lose my loose operating limitations by having to apply again. Can anyone explain? Reading of text will probably show that this date is 12 months to the day from issuance. This requires condition inspection after which it would be good for 12 months to the day. read the paragrapg related to condition inspection. Duration, other than that condition, was unlimited and none had geographical limitations, to my knowledge. All of that changed when new rules were published effective 7/9/97. After that time, the current requirements to be controlled by your local district office, area limitatiions, etc., went into effect. DON'T lose your old limitations, you likely would not get them again. That said, read what the text says and comply. Good luck UH- Hide quoted text - - Show quoted text - Thanks UH, I like your interpretation best. I would feel more comfortable with this if the operating limitations more clearly stated that a condition inspection would extend the special airworthiness cert. for another 12 months. Are you saying that since the operating limitations do not state an expiration, but instead state that condition inspections are required every 12 months, that this supersedes the expiration date shown on the airworthiness certificate (which was one year from the issue date)?? Is there an FAA Order or an FAA rep. that can clarify this?- Hide quoted text - - Show quoted text - To be safe, you could take your docs to your local district office for interpretation. That said, you might not like what they say. These days they really want to control activity on Experimental- Exhibition and Air Racing licensed ships. I would be surprised if you certificate is not unlimited, subject to condition inspections. UH I- Hide quoted text - - Show quoted text - I don't know a lot about Experimental Limitations. Mine is an old 1974 version. But rather than walking into the FSDO cold I would ask around the local glider pilots or experimental amaetur builders about who to talk to. Perhaps a DAR ( I forget exactly what it stands for other than it is Designated (not FAA employee) person who can issue a new registration) would be a better option than just walking into the FSDO. Find someone that has a history of being reasonable to work with. Some FSDO's are very good some are less so. So do you homework about what works best in you local area. Brian CFIIG/ASEL |
Similar Threads | ||||
FAA Airworthiness *grumbles* | noel.wade | Soaring | 19 | March 12th 08 04:54 PM |
TBO and airworthiness | Jim Stewart | Owning | 26 | April 17th 07 05:05 PM |
USA Glider Experimental Airworthiness Certificate | charlie foxtrot | Soaring | 4 | April 15th 06 05:04 AM |
Teaching airworthiness | Roger Long | Piloting | 28 | October 2nd 03 09:08 PM |
Airworthiness certification of an experimental | Ace Pilot | Home Built | 0 | July 16th 03 03:26 PM |
