STAR to neighboring airport
Old May 23rd 04, 02:19 PM
Viperdoc
Default STAR to neighboring airport
Recently I was arriving from the southwest to my home base of UES (Waukesha,
WI), and was given the Veena arrival.
However, the Veena arrival is not listed as a STAR to Waukesha, but is under
the section for Milwaukee, which is around 20 miles away (in the Jepp
charts). Waukesha is not under the class C area of MKE. On the chart there
is no listed transition to Waukesha. However, one of the fixes on the star
is the Badger VOR, which is the IAF for several approaches into Waukesha.
There is also a nearby class C, which is Madison.
If unfamiliar, issuing a clearance with a STAR to a nearby airport might be
confusing. If suddenly going nordo where should one land- at the original
airport or follow the complete transition into the class C? (I know this is
a somewhat academic question)
Is this a common practice for controllers? I could see it producing some
confusion by pilots if unfamiliar with the area. Using NACO charts it is
easy to look up, but in the Jepps it could be very difficult to find.
Old May 23rd 04, 03:41 PM
Ron Rosenfeld
On Sun, 23 May 2004 13:19:12 GMT, "Viperdoc"
Academically, I would follow the note on the STAR chart (at least on the
Jepp chart): "LOST COMMUNICATIONS PROCEDURE ONLY From Veena Int proceed
direct IAF for the destination airport."
The STAR only has one name. In this case it has several transitions.
I could see it producing some confusion by pilots if unfamiliar with the area. Using NACO charts it is
Well, I use JeppView and the VEENA ONE Arrival popped up when I selected
your airport. There is a list on the STAR of the airports to which the
STAR applies. But if you have a problem in the air, you can query ATC as
to the primary airport for the STAR, or tell him you don't have the chart
available.
Old May 23rd 04, 07:10 PM
Steven P. McNicoll
"Viperdoc" wrote in message
UES (Waukesha, WI), and was given the Veena arrival.
is under the section for Milwaukee, which is around 20 miles away (in
the Jepp charts).
The Veena One arrival is listed as a STAR to Waukesha in the NACO plates.
Perhaps you should complain to Jeppesen.
But Waukesha is depicted on the STAR, as are Timmerman, Racine, and Kenosha.
Airspace delegated to an approach control facility tends to be considerably
larger than any Class C airspace it may contain.
Yes, but UES is in controlled airspace delegated to Milwaukee approach.
might be confusing. If suddenly going nordo where should one land- at
the original airport or follow the complete transition into the class C?
(I
know this is a somewhat academic question)
The VEENA 1 says you "From VEENA INT proceed direct IAF for destination
airport" in the event of lost communications.
Yup.
Well, that's a shortcoming of Jeppesen.
SWRFI update... Moving again (argghh!!)... Dave S Home Built 14 October 15th 04 03:34 AM
Please help -- It's down to the wire Jay Honeck Home Built 12 July 14th 04 06:05 PM
STAR to nearby airport Viperdoc Instrument Flight Rules 33 May 13th 04 10:48 PM
The battle for Arlington Airport begins? Paul Adriance Home Built 45 March 30th 04 11:41 PM
Here's the Recompiled List of 82 Aircraft Accessible Aviation Museums! Jay Honeck Home Built 18 January 20th 04 04:02 PM
