#31
When to descend
On Tue, 09 Oct 2007 18:14:12 -0700, Bee wrote:
I guess the AIM and the IPH need to state "A TAA straight-in, left base, or right base area is the regulatory equivalent of a published approach It's in the PC/G: TERMINAL ARRIVAL AREA (TAA)- The TAA is controlled airspace established in conjunction with the Standard or Modified T and I RNAV approach configurations. In the standard TAA, there are three areas: straight-in, left base, and right base. The arc boundaries of the three areas of the TAA **are published portions of the approach** and allow aircraft to transition from the en route structure direct to the nearest IAF. TAAs will also eliminate or reduce feeder routes, departure extensions, and procedure turns or course reversal. (emphasis mine) Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#32
When to descend
"Bee" wrote in message ... Newps wrote: Dan Luke wrote: You are coming from northeast of SFB. ATC says "Cleared direct UDUZI, maintain 4000' until established, cleared RNAV 9L approach." http://www.naco.faa.gov/d-tpp/0710/00917R9L.PDF When do you descend below 4,000 Anytime after UDUZI. and to what altitude? At or above 2000 wrong You want to expand on that a bit, bucko? Al G |
#33
When to descend
Al G wrote:
"Bee" wrote in message ... Newps wrote: Dan Luke wrote: You are coming from northeast of SFB. ATC says "Cleared direct UDUZI, maintain 4000' until established, cleared RNAV 9L approach." http://www.naco.faa.gov/d-tpp/0710/00917R9L.PDF When do you descend below 4,000 Anytime after UDUZI. and to what altitude? At or above 2000 wrong You want to expand on that a bit, bucko? Al G I already did. You descend to 2700 once inside the TAA. Like Steve said, you guys need to read the AIM and the PC/G. ALo |
#34
When to descend
Ron Rosenfeld wrote:
On Tue, 09 Oct 2007 18:14:12 -0700, Bee wrote: I guess the AIM and the IPH need to state "A TAA straight-in, left base, or right base area is the regulatory equivalent of a published approach It's in the PC/G: TERMINAL ARRIVAL AREA (TAA)- The TAA is controlled airspace established in conjunction with the Standard or Modified T and I RNAV approach configurations. In the standard TAA, there are three areas: straight-in, left base, and right base. The arc boundaries of the three areas of the TAA **are published portions of the approach** and allow aircraft to transition from the en route structure direct to the nearest IAF. TAAs will also eliminate or reduce feeder routes, departure extensions, and procedure turns or course reversal. (emphasis mine) Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) Great cite. Too bad most of the folks here cannot figure out how to find this stuff. |
#35
When to descend
Bee wrote:
Great cite. Too bad most of the folks here cannot figure out how to find this stuff. Great cite of a pretty good site. True enough, but if everyone just looked everything up and found the answers and interpreted everything correctly, we wouldn't have much to talk about here. Anyway, I certainly wouldn't fault the OP for raising the question here. It provoked an interesting discussion and I learned from it. Dave |
#36
When to descend
Dave Butler wrote:
Bee wrote: Great cite. Too bad most of the folks here cannot figure out how to find this stuff. Great cite of a pretty good site. True enough, but if everyone just looked everything up and found the answers and interpreted everything correctly, we wouldn't have much to talk about here. Anyway, I certainly wouldn't fault the OP for raising the question here. It provoked an interesting discussion and I learned from it. Dave The NACO TAA charts are also covered in great detail in the NACO IAP chart legend, which appears everytime someone downloads NACO approach charts: http://www.naco.faa.gov/content/naco..._IAP_Intro.pdf |
#37
When to descend
"Dave Butler" wrote in message ... Bee wrote: Great cite. Too bad most of the folks here cannot figure out how to find this stuff. Great cite of a pretty good site. True enough, but if everyone just looked everything up and found the answers and interpreted everything correctly, we wouldn't have much to talk about here. Anyway, I certainly wouldn't fault the OP for raising the question here. It provoked an interesting discussion and I learned from it. Dave Me too. Al G |
#38
When to descend
On Wed, 10 Oct 2007 18:26:42 -0700, Bee wrote:
Great cite. Too bad most of the folks here cannot figure out how to find this stuff. At least the question is asked and, in the various answers, these sorts of things become known. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#39
When to descend
On Wed, 10 Oct 2007 18:26:42 -0700, Bee wrote: Great cite. Too bad most of the folks here cannot figure out how to find this stuff. At least the question is asked and, in the various answers, these sorts of things become known. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) It didn't help that NACO chose to use the MSA box for the TAA area minimum altitudes rather than the underscore as they have always used for all other minimum alitudes and as illustrated in the AIM. They also claim that the TAA area minimum altitudes replace MSAs for these IAPs. That is incorrect. They make MSAs unnecessay but they do not replace them. MSAs are not IFR altitudes in this country. |
#40
When to descend
On Fri, 12 Oct 2007 01:13:00 -0700, Bee wrote:
They also claim that the TAA area minimum altitudes replace MSAs for these IAPs. That is incorrect. They make MSAs unnecessay but they do not replace them. MSAs are not IFR altitudes in this country. Although the TAA minimum altitude, and MSA have different definitions, I never had a problem with the concept of them being the same value when there is a TAA published. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
