800 number for void time?
Old November 2nd 07, 05:45 PM posted to rec.aviation.ifr
Paul kgyy
Default 800 number for void time?
I've heard some discussion that there is a national number to call for
a void time on filed IFR flight plans.
True? And if so, what's the number?
Old November 2nd 07, 06:54 PM posted to rec.aviation.ifr
Steven P. McNicoll
"paul kgyy" wrote in message
False.
Old November 2nd 07, 07:35 PM posted to rec.aviation.ifr
John Clonts
I saw (I think it was here) that there is a nationwide clearance
delivery number, 1-888-766-8267. Have not tried it yet...
Cheers,
John Clonts
Temple, Texas
N7NZ
Old November 2nd 07, 07:41 PM posted to rec.aviation.ifr
Dave Butler
http://groups.google.com/group/rec.a...65d4248984dd78
Old November 3rd 07, 05:25 PM posted to rec.aviation.ifr
Matt Whiting
Current issue of AOPA mag has a good writeup and a tear-out reference
card for FSS services. It includes the Clearance number.
I guess you can get clearances but not a void time clearance which
presumably requires local ATC contact.
FSS should be able to contact ATC. Was this lost in the transition to
LockMart?
Matt
Old November 4th 07, 12:05 AM posted to rec.aviation.ifr
Dennis Johnson
"Bill Zaleski" wrote
I use this number all the time, and get void times regularily.
Hi Bill,
I can't get my clearance by radio at my home airport. I've been taking off
VFR and remaining VMC until I can get enough altitude to get my IFR
clearance on the radio. However, sooner or later, the weather will be too
bad for that. So I'll start practicing for getting a void time from the 800
number. How long is the void time that you usually get? I'm trying to
decide if I have to be at the end of the runway, ready to go, or can I call
and get the void time, then start the engine, taxi out, etc.?
Thanks,
Dennis
Old November 4th 07, 12:32 AM posted to rec.aviation.ifr
Matt Whiting
Hi Bill,
Thanks,
Dennis
When I get a void time clearance at an uncontrolled field, I tell the
briefer that I need say 10 minutes to get ready for takeoff and then
they give you a clearance that has both a valid time and a void time.
It won't be valid until say 10 minutes in the future and then void 10
minutes after that.
Matt
Old November 4th 07, 12:59 AM posted to rec.aviation.ifr
David Kazdan
I used it about a month ago to depart Cynthiana, Kentucky into IFR.
Worked fine. They actually gave me a longer void time than I requested.
Lexington approach was all ready for me.
David
Old November 4th 07, 04:50 PM posted to rec.aviation.ifr
Dennis Johnson
briefer that I need say 10 minutes to get ready for takeoff and then they
give you a clearance that has both a valid time and a void time. It won't
be valid until say 10 minutes in the future and then void 10 minutes after
that.
Matt
Thanks, Matt. That would work fine for me. I'll give that a try next time
I'm going IFR.
Dennis
Old November 4th 07, 07:47 PM posted to rec.aviation.ifr
Matt Whiting
that.
Matt
I'm going IFR.
I haven't obtained my clearance this way since LockMart took over, in
fact I haven't even obtained a briefing since LockMart took over. DUATS
is just too easy to use compared to calling a briefer who may be 3
states away.
However, this technique worked fine with the old FSS.
Matt
Can a failed Glide Slope also void the Localizer approach? Jim Carter Instrument Flight Rules 17 August 24th 06 09:01 PM
Have you guys ever noticed the void? Stealth Pilot Home Built 32 January 16th 06 12:19 AM
Pitts Number 1 registration number Mirco Aerobatics 3 December 4th 04 11:50 AM
First Time Buyer - High Time Turbo Arrow [email protected] Owning 21 July 6th 04 07:30 PM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
