LORAN antenna difference?
Old December 22nd 04, 11:00 PM
JFLEISC
Default LORAN antenna difference?
Can someone tell me the differences between a loran antenna and a comm or VOR
nav antenna? I guess what I'm looking for is why they would not be
interchangable, i. e. is the loran signal totally incompatible with others? is
it an absolute necessity for a preamp in the loran antenna (I would assume that
would eliminate the possibility of using that antenna to transmit, for
instance)? can a loran signal be received off of a dipole nav antenna? I'm
basically trying to be a little more knowledgable on the subject.
Old December 23rd 04, 02:57 AM
Jerry J. Wass
LOran is very low frequency, follows the earth curvature--originally used for ships
& submarines..--Best results with a roll-out trailing antennae, but will work with
a cabin to rudder antenna--longer the better. jerry
Old December 23rd 04, 05:25 AM
John_F
Both antennas look the same on the outside but on the inside they are
totally different.
The loran works at 0.1 MHz, the com works at 130 Mhz.
The com antenna is resonant at near 1/4 wavelength and has an
impedance near 50 ohms.
Since the loran antenna is electrally short at 0.1% of a wavelength
the matching impedance is very high ( about 50,000 ohms ) hence this
is why the preamp is in the antenna with zero coax length to the
preamp. The preamp built into the antenna matches the 50K ohm antenna
impedance to the 50 ohm coax. You can get away from using a pre amp
but you must use a MUCH longer antenna feeding the coax or you will
not have any signal left by the time it gets to the receiver because
of the antenna to coax impedance mismatch.
The preamp power is fed down the signal coax from the loran receiver.
Due to this if you connect a grounded com antenna to the loran
receiver you will fry the power feed coupler in the loran receiver.
You can hook up a length of wire that is not grounded to see what
signal strength you get. You may be surprised at how long a wire it
takes to get the same signal strength as the amplified antenna.
If you transmit into a electrically short loran antenna you can kiss
it good bye because you just fried the preamp.
John
Old December 23rd 04, 01:26 PM
JFLEISC
Thanks folks, this does answer a lot of questions.
Old December 24th 04, 02:15 AM
w
Yeah, like why is there smoke coming out the back or your loran unit..
Old December 24th 04, 04:47 PM
RST Engineering
I am not aware of any LORAN designs that did not use a preamp. Some of them
have the preamp buried in the base of the antenna, and some of them use a
short (24" or so) wire whip with the preamp box bolted onto the airframe
very near the bottom of the antenna. II Morrow old designs, for instance,
provide a 6" length of coax to go from the base of the antenna to the preamp
connector. As the author says, much more coax than this and the antenna
signal approaches zero.
"John_F" wrote in message
.. You can get away from using a pre amp
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 06:59 PM
Another antenna question David Wilson Home Built 7 August 12th 04 10:04 PM
Antenna ground plane and coax grounding G. Fred McCutchen Home Built 2 August 8th 04 12:27 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
comm's RX antenna acepilot Home Built 5 March 3rd 04 05:34 PM
