#61
Rob wrote: RST Engineering wrote: Then you clearly have not the vaguest concept of what 91.3 means. Oh. O.K. Sorry. Perhaps you could clarify the concept for me then, Jim. Rob Disregard. Part of 91.3 means that a pilot may deviate from FARs if necessary to deal with an emergency. Technically, that's a lot of leeway. Point taken. -R |
#62
91.3 says in no uncertain terms (a) The pilot in command of an aircraft is
directly responsible for, and is the FINAL AUTHORITY as to the operation of that aircraft." (emphasis author) It doesn't say that the inspector can over-ride the PIC's assessment of the situation, does it? Jim "Rob" wrote in message oups.com... RST Engineering wrote: Then you clearly have not the vaguest concept of what 91.3 means. Oh. O.K. Sorry. Perhaps you could clarify the concept for me then, Jim. Rob |
Similar Threads | ||||
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 03:03 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
