Engines and Reliability
Old June 29th 04, 07:39 PM
On 29 Jun 2004 10:21:23 -0700, (Michael) wrote:
Homebuilders have been adapting automotive engines for years. The
safety record has been abysmal. Oddly enough, it's never the engine
core that fails. It's always fuel systems, ignition systems,
reduction drives - all the stuff it takes to make the conversion. In
other words, all the stuff that is amateur-designed rather than
professionally engineered. That's why I'm not a great fan of auto
conversions. It's not that there's anything wrong with the engines -
despite being suboptimal for aviation, they're way out in front of the
crap Lycoming and Continental are selling, even for aviation
applications. The problem is that adapting the engine for aviation
use is a major task, and not something to be done by a garage mechanic
on the cheap.
Michael
Yep, true words, I ought to know, it's what I'm working on. I'm doing
what I can for redundancy (two completely independent electronic
ignition systems) and using good aviation practices (every bolt and
nut on the outside of the engine and some on the inside are drilled
and safety wired), but it's taking a long time to assemble properly.
Another thing I will be doing is testing testing testing. I've
fabricated an engine test stand and will be breaking in the engine on
it and running it with the prop for extended periods. I'll have to
adjust the prop to a pitch that allows the engine to reach the proper
rpm limit. This will not be the same pitch the airplane will fly with
though, as the engine will over-rev I'll keep records of the testing
and the Hobbs meter time for the DAR, when the time comes.
The plan is to winch it into the pickup and drive it into the woods
around the house so I can run it for extended periods without causing
the few neighbors to show up with shotguns. ;-)
Corky Scott
Old June 29th 04, 09:14 PM
On Tue, 29 Jun 2004 21:10:02 +0200 (CEST), Nomen Nescio
] wrote:
We're only talking a 400 rpm difference, here, but unless the power curve
goes flat from 5600 to 6000, it ain't "pulling 215 HP'. I doubt a competent
engineer would write it like that since any engineering student who wrote
that would be torn to shreads.
To paraphrase: "never ascribe to malice that which can be explained by
stupidity". It could be a typo.
Corky Scott
Old June 30th 04, 04:24 AM
TD
Tell us what happened when you had an engine failure. I am interested to
know.
Tien.
"Michael" wrote in message
om...
Dylan Smith wrote
The accepted wisdom is that aviation engines are tough, because they can
be run at full rated power for hours on end, and auto engines are
fragile, and must not be thrashed or they won't last very long. It was
even mentioned in a thread in the last couple of weeks - I don't
remember who said it, but they said "operate your car engine like that
and it wouldn't last half an hour".
In reality, that's nonsense and everyone knows it. The standards of
testing used by Detroit (never mind the Japanese) are way tougher than
anything the FAA ever thought about doing. This has been discussed
extensively on rec.aviation groups. Check out this link, or just
google it yourself:
http://groups.google.com/groups?hl=e...lur%24mg8%242%
40merrimack.Dartmouth.EDU&rnum=1&prev=/groups%3Fas_q%3Dauto%2520engine%2520t
est%26safe%3Dimages%26ie%3DUTF-8%26as_ugroup%3Drec.aviation.*%26lr%3D%26num%
3D30%26hl%3Den
I've never really thought about it, but this weekend I learned how to
drive the winch at the glider club. After a few launches it got me
thinking - this thing about aero engines vs car engines is probably an
old wives tale, possibly promulgated so people don't feel so bad about
spending so much money on aircraft engine parts when yet another
cylinder is cracked.
That's basically it. The aviation engines we use are obsolete. Sure,
they're more reliable and have better power-to-weight ratios than auto
engines - as long as you compare them to contemporary auto engines.
That's contemporary to the design age - meaning somewhere in the
1950's-1960's. At that point, real aviation went to gas turbines, the
designs of aviation piston engines were basically frozen, the
engineering talent went away, and no further progress was made.
When was the last time you heard of a modern (made in the last 10
years) auto engine that just died without giving weeks (or months, or
years) of warning? Not got stalled by a ham-fisted shifter or run out
of gas, but actually died? I'm sure it's happened, but it's a huge
rarity (whereas in 1955 it wasn't). On the other hand, I don't know
ANYONE with more than 2000 hours in piston GA who hasn't had an engine
failure. These things eat valves, they crack jugs, they throw rods,
their carb floats sink - you name it.
The truth is that aviation and auomotive use are very, very different.
They have very different duty cycles, cooling requirements, and
performance requirements. It really should not be a viable
proposition to adapt automotive engines to airplanes - you will wind
up with engines that are overdesigned in some areas and underdesigned
in others. However, automotive engines have advanced tremendously in
the past half century; piston aviation engines have not. Now we even
have manufacturers actually using autmotive cores (which are optimized
for a completely difference application), dressing them up for
aviation, and selling them - that's how Thielert works. It's very
much suboptimal - but the existing engines from Lycoming and
Continental are such disasters that even this is a viable business
plan.
on the cheap.
Michael
Old June 30th 04, 03:27 PM
Michael
know.
My engines use RSA fuel injection assemblies. These assemblies are
mostly Aluminum - but the plug that you unscrew to remove and
inspect/clean the fuel strainer is steel. There is also a spring of
some other sort of steel that keeps the filter in place - one end of
it pushes against this plug. This is a godawful design.
You see, steel eventually rusts. The rust eventually flakes off,
especially with engine vibration and a spring rubbing the area to
help. The plug is installed AFTER the filter - meaning that there is
nothing to filter out this rust. So the rust goes into the fuel
system.
I got unlucky. A large chunk of rust let go and clogged my fuel
injectors (two of them, but on the same side of the engine). The
vibration was horrible. I had to pull the power way back, and was
only able to get about 20% power out of the engine. I was in visual
conditions, but only about 500 ft above a solid overcase (I was IFR).
Fortunately, I was in a twin. The other engine carried me to the
airport, where I was able to land and repair the damage.
Were it up to me, I would replace the steel plug with brass, and
install a disposable inline automotive fuel filter. But of course
that would not be legal.
Michael
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
