Proper Std. Cirrus class
Old January 8th 17, 10:26 PM posted to rec.aviation.soaring
Jacopo Romei
Default Proper Std. Cirrus class
Hello everybody,
I need your help.
I am compiling the Std. Cirrus 'GliderReview':
http://www.gliderreview.com/glider/s...tandard-cirrus
AFAIK in standard class "the IGC banned all camber-changing devices" (ref. https://en.wikipedia.org/wiki/Glider...Standard_Class) thus keeping the no camber-changing Cirrus' devices compliant.
So, did I understand well?
Thanks a lot!
Jacopo
Old January 9th 17, 02:48 AM posted to rec.aviation.soaring
Sierra Whiskey
The Standard Cirrus is a Standard Class Aircraft. (15-Meter Wingspan, No Flaps)
Old January 9th 17, 05:57 AM posted to rec.aviation.soaring
For a time flaps were allowed in the standard class as long as they were not interconnected with the ailerons. Non-flapped gliders of 15 meters maximum were still eligible for the standard class during that period. The change to the rules made on behalf of the Standard Cirrus (and the other German gliders of the period) was the removal of the requirement for terminal velocity limiting dive brakes in the standard class when it was discovered none of them met that requirement. It rather annoyed the Schweizers who had spent considerable time and money engineering and testing terminal velocity limiting brakes on the 1-23H15 and 1-34 in good faith. They (as well as Laister and Schreder) were then even more ticked off when after designing ships with flaps to meet the definition of the then current standard class rules saw the rules changed again to disallow flaps. Eventually we got the 15 meter class and the standard class rules we have now out of the whole mess.
Two European gliders built to the flapped standard class rule were the original Pik20 and the single LS-2
Old January 9th 17, 07:34 PM posted to rec.aviation.soaring
SoaringXCellence
and the Glasflugel Hornet
Old January 9th 17, 07:57 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
No. The Hornet has a trailing edge air brake, not a flap.
Cessna 152 (proper) air/fuel ratio... dtvonly General Aviation 3 May 21st 12 05:47 PM
Proper Radio Procedures for Off-Airport Operations Richardfl Piloting 10 April 25th 05 03:33 PM
Proper Torque for Fuel Fittings Steve Waltner Home Built 10 February 20th 05 12:46 AM
Proper yoke calibration Rans Simulators 0 December 1st 04 03:38 PM
Proper stall recovery technique Chris OCallaghan Soaring 0 February 2nd 04 10:33 PM
