lsa license and experimental classified aircraft
Old November 4th 12, 12:21 AM
matterson rusyn matterson rusyn is offline
Junior Member
First recorded activity by AviationBanter: Dec 2011
Default lsa license and experimental classified aircraft
building a warinc bf-109 with retracks ,can i fly it with lsa.license.
Old November 4th 12, 03:01 AM posted to rec.aviation.homebuilt
Orval Fairbairn
No -- LSA is limited to:
1. fixed gear
2. fixed pitch prop
3. stall speed 50 mph
4. gross weight 1350 lb.
Old November 9th 12, 08:50 PM posted to rec.aviation.homebuilt
Roberto Waltman[_2_]
Close. 1320 lb. (600Kg x 2.2 lb/Kg)
Roberto Waltman
[ Please reply to the group,
return address is invalid ]
Old July 2nd 13, 02:23 PM posted to rec.aviation.homebuilt
Brake Dive, Acceleration Squat and Body Roll Bros Suspension Works
Default [OT] lsa license and experimental classified aircraft
why did germans switch to the wooden blades on Focke Wulf Fw 190 A-8???
surely not to save the weight?
Old July 2nd 13, 06:20 PM posted to rec.aviation.homebuilt
Orval Fairbairn
"Brake Dive, Acceleration Squat and Body Roll Bros Suspension Works"
The British used wooden blades on their Spitfires an Hurricanes, also.
Wood is a good material (a naturally-occurring composite) and is easy to
fabricate. In addition, it will shatter when it strikes solid objects
(such as the ground in a gear-up) and will not damage engine components
when it does.
Aircraft FCC license B. Jensen Home Built 3 October 15th 05 06:05 AM
How to License Your Homebuilt Aircraft [email protected] Home Built 0 January 26th 05 04:11 PM
Financing for Experimental Aircraft James Keane Owning 2 September 1st 04 02:18 AM
"Classified" supersonic aircraft? Scott Ferrin Military Aviation 25 January 24th 04 09:33 AM
Experimental Aircraft Pictures Jay Honeck Piloting 0 December 5th 03 10:12 PM
