#21
Plane 172 fun video
On Feb 1, 10:31*am, wrote:
* * * * *As an instructor, I couldn't help noticing the length of the float on landing, and the tiny pitch change after landing. I think, based on the little I could see, that the approach was very fast, the pilot flared very close to the surface and floated in ground effect for a thousand feet and touched down still fast and therefore flat. It's a common problem in flight training, and often the instructors just let it happen. Many of them do the same thing. And the ditches or fences at the end of the runways continue to claim airplanes. Dan, Not mentioned in the video, this was a "no flaps landing". Sitting in the back seat, I couldn't see over the glareshield myself, so I know he had a **reasonablly** good flare. Hopefully this clears up the higher speed over the runway and account for the longer float over the runway. I am NOT a CFI, but from my observations, I thought he did a good job keeping the nose off and not rushing the plane to ground. (I.E. allow the plane to settle on it's own while bleeding the speed off) As the video does indicate, the stall horn was sounding when the wheel did touch terra firma. Allen |
Plane 172 fun video
On Feb 1, 4:03 pm, " wrote:
On Feb 1, 10:31 am, wrote: As an instructor, I couldn't help noticing the length of the float on landing, and the tiny pitch change after landing. I think, based on the little I could see, that the approach was very fast, the pilot flared very close to the surface and floated in ground effect for a thousand feet and touched down still fast and therefore flat. It's a common problem in flight training, and often the instructors just let it happen. Many of them do the same thing. And the ditches or fences at the end of the runways continue to claim airplanes. Dan, Not mentioned in the video, this was a "no flaps landing". Sitting in the back seat, I couldn't see over the glareshield myself, so I know he had a **reasonablly** good flare. Hopefully this clears up the higher speed over the runway and account for the longer float over the runway. I am NOT a CFI, but from my observations, I thought he did a good job keeping the nose off and not rushing the plane to ground. (I.E. allow the plane to settle on it's own while bleeding the speed off) As the video does indicate, the stall horn was sounding when the wheel did touch terra firma. Allen OK. I was using the available information. But the float was still really long, and even with no flaps it could be shortened considerably. Maybe when the student gets into commercial training, if he decides to do that. I'm an instructor as well as a mechanic, and see first hand the damage that sloppy landing technique does to the tires, brakes and nosegear. Much of it is due to approaching too fast for the configuration, not flaring until in ground effect instead of getting the power off and lifting the nose to kill excess speed before reaching ground effect, and then allowing the airplane to land very flat, often on all three wheels at the same time. The high speed can bring on nosewheel shimmy, which tears things up (including nosegear linkage, radios and instruments), and if the student is doing short- field landings he'll drag the tires trying to get stopped. There's still way too much lift at those speeds and no weight on the mains. I often have the stall horn sounding while still at five feet above the surface. It'll sound at 5 to 10 knots above the stall, and that's a stall speed out of ground effect. Stall speed drops a little near the surface, so there's still some safety. Dan |
Plane 172 fun video
On Jan 31, 5:33*pm, " wrote:
On Jan 31, 10:01*am, "gatt" wrote: Nice. What do you think of this one? http://www.youtube.com/watch?v=R_8KnBStSoM Seems crazy. -c Not seems..... Is..... Like one of the comments left by somebody else, if he isn't dead already, he will be..... Allen lol, we all will die sonner or later. Wil |
#24
Plane 172 fun video
On Feb 1, 5:46*pm, wrote:
* * * *OK. I was using the available information. But the float was still really long, and even with no flaps it could be shortened considerably. Maybe when the student gets into commercial training, if he decides to do that. *smile* for experienced pilots, absolutely agree, but for a precheckride pilot, my opinion that was pretty durn good. Based on your input, I have updated the video information so others know. * * * * I often have the stall horn sounding while still at five feet above the surface. It'll sound at 5 to 10 knots above the stall, and that's a stall speed out of ground effect. Stall speed drops a little near the surface, so there's still some safety. Yep, agree, my kind of landings.(plenty on my You Tube channel) but a random sample below. http://www.youtube.com/watch?v=rh05cgtBtSY stall horn on for 4 seconds http://www.youtube.com/watch?v=7nuoH7QasqA stall horn on solid for 7 seconds http://www.youtube.com/watch?v=HR_CN8112J8 stall horn going for 5 seconds. IFR is a different beast of course asn 90 knots down to DH and losing that speed will cause more float as I trim to lose speed with one notch flaps on landing. My flights are in a 1976 Beech Sundowner. Allen |
Similar Threads | ||||
Video of plane landing on highway in Wisconsin | C J Campbell[_1_] | Piloting | 4 | July 30th 07 10:03 PM |
Video of building a plane in the air | Jim Logajan | Home Built | 1 | November 20th 06 10:43 PM |
Jay's "Plane Crash Video Ubersite" | Peter Duniho | Piloting | 18 | August 14th 06 05:45 AM |
Video from the plane | Jacob Olsen | Soaring | 6 | December 16th 05 05:23 PM |
A Plane is Born Video | FLYWITHJAY | Home Built | 0 | July 17th 04 02:27 PM |
