Area bombing is not a dirty word.
Old January 21st 04, 02:29 PM
Drazen Kramaric
On Sun, 18 Jan 2004 02:01:50 GMT, "Kevin Brooks"
If we use a SWAG of eight men per heavy gun and four per lighter gun, and
maybe four per searchlight, that gives you some 125,000 personnel *just in
the weapons crews themselves*. Even if you assume that the Flak units
required less service support committment than frontline combat units (where
the teeth-to-tail ratio was probably in the five or six-to-one range at
best) and assumed a one-to-one ratio, you are talking another 125K personnel
right there. That is already 250K personnel tied up in the defense effort
without even starting to consider the Luftwaffe flying assets. I'd be very
surprised if the total number of German personnel tied to the defense effort
against the CBO was not well in excess of 500K personnel...at a time when
Wehrmacht units were furiously disbanding some units in a vain effort to
keep others in a fill-status that *remotely* resembled their TO&E
requirements.
The real question is where would the personelly otherwise tied up in
the AA defense be more useful to the German war effort. Most of the
crews were not fit to serve in the front line units either because
they were in the wrong age or sex group. Some of them weren't even
Germans.
Against one eight man gun crew you'd have one ten man B-17 crew. Which
crew costs its parent country more to sustain in the combat?
Which brings us to the second point--the allies could *afford* to dedicate
personnel and resources to the CBO because we had an over-abundance of
manpower and equipment resources. We were challenged to support the scope of
the force that we DID have fighting on the continent--tossing more manpower
into the equation would just exacerbate the support constraints. OTOH, the
Germans were already short manpower and equipment almost across the
board--keeping tank strength in their panzer units up to minimal levels was
a nightmare, and they were lacking infantry and artillerymen as well. Their
tactical air support efforts were seriously hampered by the need to continue
the defense effort back home. So in the end the CBO, if it accomplished
nothing else, applied additional pressure to the German manning and
equipment shortfalls affecting their frontline units that would not have
been present had the CBO not occured.
This point is valid, with some limits. Indeed, Allies could afford to
send their best human material into strategic bombing. The question is
whether this human material who flew and supported strategic bombing
offensive could have been used more efficiently.
It shouldn't be forgotten that half of the bombs dropped by CBO on
German controlled territory was dropped after September 1944 when
German army and air force were thoroughly defeated and were unlikely
to survive 1945 campaign season even if CBO completely stopped then.
CBO was a consequence of Germany being fully engaged in Soviet Union
with Allies reluctant to risk their ground troops until they became
sure in the victory. If it weren't for collapse of France in 1940, I
doubt British would choose to build Bomber Command on the expense of
increased BEF.
They did? And what were they? The PIAT?
They had antitank guns too. Not too many, but on the other hand, II SS
Panzer corps didn't have that many tanks either.
You are dreaming here--they faced those panzers, and they did NOT
hold out "for a long time".
They were expected to hold for 48 hours. They held out for nine days
and their opponents weren't limited to II SS panzerkorps.
Their AT capabilities were ABYSMAL. And you have again ignored the REAL problems with
Market Garden--the poor and limited capacity axis of advnace given to XXX
Corps, the lack of decent DZ's around Arnhem close enough to the targets,
and that great unknown--the weather.
Allies had a capability to make two drops on the first day. They chose
not to exercise it. It was a mistake. If there were more troops at
Arnhem, Urquhart would have had enough troops to attack towards the
bridge and hold the DZs. With only one drop, he deemed capture of the
bridge more important and sent troops there hoping that XXX corps
would establish the land supply line.
Drax
remove NOSPAM for reply
  #82
Old January 21st 04, 04:01 PM
Kevin Brooks
"Drazen Kramaric" wrote in message
in
(where
personnel
very
effort
requirements.
Germans.
Heck, a significant number of the "front line" Wehrmacht troops in 1944 were
either not Germans or over/underage. The simple fact is that those manpower
resources *were* tied up in the defense effort at a time when their services
were needed over a wide range of areas; the germans were not only lacking
combat infantry troops at this point. They actually had *reduced* the AA
protection afforded their front line units to beef up the AA force in the
Reich--if nothing else (and I strongly suspect this is the most minor of
contributions those folks could have made elsewhere) they could have brought
the forward AA assets back to a point where allied tactical airpower would
have been harder to employ.
Not the issue. As you note below, the allies had the resources to risk some
waste--the Germans did not.
dedicate
of
manpower
was
Their
continue
I fail to see how, given that the allied forces on the ground in France were
already straining a rather tenuous logistics chain. We had plenty of mediums
to handle the steikes at transportation nets, etc., closer to the FLOT, and
the limiting factor on CAS was more often the weather than it was any lack
of airframes for that mission. The heavies contributions to tying down, and
later eliminating for the most part, the Luftwaffe such that they were never
able to effectively support their own front line forces, and their
contribution to both the deeper transportation disruptions and the vital
petroleum resources available to those forward German forces, outweigh any
likely value to be obtained from "rerolling" them to another task.
It should also be remembered that had the CBO not been underway, the
Luftwaffe would have had a few thousand more aircraft and pilots available
to oppose the allied ground efforts on *both* fronts, meaning that by Sep
1944 the Luftwaffe would *not* have been "thoroughly defeated" (or lacking
seriously in petroleum products), and the ground picture might very well
have been somewhat different as well.
Tell that to the million or more allied troops slogging their way up through
Italy from 1943 onwards. Yes, the CBO did provide a method of striking
Germany while the allies built up their capability to go ashore in France.
IMO, that is a *good* thing, as otherwise the Germans would have had free
reign to reorient their less-plentiful resources away from defending the
Reich to other more dangerous (to the allies) pursuits. Ever wonder what the
impact would have been had the Wehrmacht *just* gained a couple of thousand
more 88mm dual-use guns on each front, guns that instead were dedicated to
that defense against the CBO? How much more effective German defensive
efforts on the ground would have been had they not been short of fuel? What
the effect of a a couple of thousand more German aircraft flying in support
of those German troops would have been?
increased BEF.
The UK had already committed themselves to build a Bomber Command before the
fall of France. In fact, BC had existed before the war even began (founded
in 1937), and the specs for the first modern RAF four-engined bomber were
released in 1936, resulting in the Stirling. I find it hard to believe you
never heard of the pre-war slogan, "The bomber will always get through."
They had a few 6-pounders. But not enough. Nor was their ammo supply that
good. The plain fact of the matter is that airborne troops are not intended
to face significant armored threats (and that has not changed much since
then).
They did not, and indeed could not (not in any way due to any lack of
courage or ingenuity on the part of those poor guys stuck in Arnhem, either)
hold out long enough. Montgomery's plan was fatally flawed from the
outset--it was too ambitious, it did not properly take into account the
effect of the terrain, and it failed to accurately template the enemy force
(despite concrete indications of the presense of that armored corps). It was
born more out of Montgomery's desire to regain the spotlight and acheive a
higher priority for his own force compared to the US elements to his south
than out of solid military planning; exacerbated by the significant pressure
towards using the First Allied Airborne Army in a major way (even George C.
Marshall was apparently urging their use in *some* kind of offensive
thrust). Eliminating the CBO would not have changed any of those facts.
problems with
If the allies already had this capability, why would the elimination of the
CBO have changed the situation? And I differ with you as to holding the
DZ's; they were located in tank country and would have been rolled up rather
quickly, IMO (definitely more quickly than the effort to root out the paras
in the city proper).
Brooks
Drax
  #83
Old February 11th 04, 02:10 PM
Drazen Kramaric
On Wed, 21 Jan 2004 16:01:50 GMT, "Kevin Brooks"
There were no 16 year olds in Wehrmach in 1944, but they did serve in
the AA units. Girls too were not considered for the front line duties.
The simple fact is that those manpower resources *were* tied up in the defense
effort at a time when their services were needed over a wide range of areas
There is nothing simple in this "fact". High school students who
otherwise would do their homeworks or sleep served in the AA units.
Girls who otherwise would stay at home served in German version of
WAAC. The increasing mass of forced and slave labour replaced German
workforce which in turn went to the front.
the germans were not only lacking combat infantry troops at this point. They actually
had *reduced* the AA protection afforded their front line units to beef up the AA force in the
Reich
How many divisions lost their organic AA to supplement the air defense
of the Reich?
I am pointing it out that Germans used many resources in AAA that
otherwise wouldn't have been used in the war effort.
The size of the Allied tactical air forces was getting bigger as the
war went on. So, if instead of heavies, Allies concentrated on light
and medium bombers they could have had more tactical aircraft
available for the given logistical capabilities in UK and
Mediterranean.
What is the difference between shooting down Luftwaffe near the front
and above Germany? If the whole point of the war is to park your tanks
on the enemy airfield (the ultimate air defense), isn't it logical to
concentrate on the support for the army? Unlike Russia, there was no
large strategic depth for Wehrmach to use in the defense of Ruhr. Once
Allies were in France, Wehrmacht (inluding Luftwaffe) had to fight and
win to prevent the invasion of Germany, i.e. Luftwaffe has to come up
and fight.
The history of air war in the Mediterraean gives a clear picture of
the capabilities of Luftwaffe to interfere with Allied operations
performed under the fighter umbrella. Whereever Luftwaffe rose to
fight it was defeated with heavy losses. Without significant CBO,
German planes were going to be shot down by Allied and Soviet fighters
just as well.
The number of Allied and German troops deployed against each other in
1943 was miniscule in comparison to Eastern front.
Yes, the CBO did provide a method of striking Germany while the allies built up
First, they would have to train real soldiers to man them, second,
they would have to create a logistical base to support them, third,
they were going to face the increased number of tactical air that was
built instead of heavies.
How much more effective German defensive efforts on the ground would have been
As long as Germans held Ploesti there was little air forces were going
to do about it. Only when Soviets overran the place, Germans felt the
real shortages. Anyway, Allies invasion of Normandy did not succeed
because of any shortage of oil and once Allies established themselves
in France, Germany was incapable of manning two fronts.
What the effect of a a couple of thousand more German aircraft flying in support
None. They would have been shot down by the proportionally stronger
Allied air forces.
I heard it. Fortunately, there was a man in RAF who didn't believe it,
Hugh Dowding.
Anyway, in 1940 RAF did not posses the means for the substantial
strategic bombing campaign against Germany. So, the force that
eventually burnt Hamburg to the ground did not exist prior to the fall
of France.
In the case of fortunate event of France holding against German
onslaught, I'd expect for British to expand the BEF and its tactical
component, rather than leave the ground fighting to French alone and
proceed with the building a historical sized Bomber Command. In 1940,
there was no Eastern front and France itself was incapable of waging
an offensive ground war against Germany. No ammount of 1940 bombers
was going to compensate for the disadvantage at the front.
It was the lack of ground front that left British with no valid
alternative than pursuing strategic bombing on the large scale.
Montgomery was hardly the only one to blame for the failure of
Market-Garden. His plan was approved by Eisenhower and the alternative
plans offered no substantial advantage over the Market Garden.
The presence of _remnants_ of II SS Panzerkorps was not the fatal drop
that killed the Market Garden. The bulk of troops that slowed down
British 2nd army (don't forget that M-G wasn't a XXX corps operation
only) came from German 15th and 1st Parachute armies, not from the SS.
The "division" that fought British at Arnhem was division in name
only, its strength was closer to the regimental "kampfgruppe"
commanded by highest ranking officer in the division, Lt. Colonel.
Harzer. King Tigers that eventually reached the battlefield came from
Germany.
I don't even know who originally tied M-G with CBO, but it wasn't my.
I only replied to specific issues tied to the M-G.
As far as I know, the original plan included the capture of nearby
airfield to enable British 51st airlanding division to take part in
the combat. The dual task presented to the 1st Airborne division
(taking the bridge and securing the DZ) made Urquhart replacement
dividing the forces which in turn were too weak to accomplish any of
the missions.
Drax
AOPA Sells-Out California Pilots in Military Airspace Grab? Larry Dighera Instrument Flight Rules 12 April 26th 04 06:12 PM
ILS Critical Area signage: Localizer or Glideslope? Adam K. Instrument Flight Rules 4 October 30th 03 10:09 PM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
Patrick AFB Area Log, Monday 30 June 2003 AllanStern Military Aviation 0 July 1st 03 06:37 AM
