CG hook on aerotows -- the followup
Well, that was certainly an informative and oft entertaining set of replies
from my post a week++ ago. I think the combined experience of everyone who responded would add up to a number even Carl Sagan would admire. I thank everyone who took the time to respond to my original question; all the other stuff was bonus material. A number of pilots, some by direct e-mail, pointed out that when correcting for a dipped wing during the early part of take-off, rudder and not aileron should be used. I fully understand the reason behind this (it wasn't overlooked in my training), however, my question was about the Pilatus B-4 in particular. This glider, unlike the five or six others I've flown since I started (2-33, 1-26, L-33, 1-36, G-103, SK-21, and more than a few chairs), has significant weight on the tail while sitting on the ground, which with my light weight in front requires a fairly good airspeed to pick up off the ground, even with the stick all the way forward. Alas, until the tail is off the ground, full rudder deflection doesn't do squat!!!. I was reminded of this again this last Sunday, when I flew the B-4 with a significant crosswind component. On one particular take-off, I started with the main/tail-wheel line a few degrees off the runway centerline. Sure enough, a wing started dipping, to which I instinctively applied opposite rudder, which didn't do a thing until the tail started to fly, and when that happened, my off-center heading was suddenly a lot worse. The situation described above does not seem to have an unambiguous way to handle it. Am I wrong, or is the best hope to keep the fingers crossed and on the release handle? -ted |
"Ted Wagner" wrote in message .. .
snip The situation described above does not seem to have an unambiguous way to handle it. Am I wrong, or is the best hope to keep the fingers crossed and on the release handle? -ted Many standard class pilots have found that use of partial airbrakes during the early part of the takeoff roll will greatly improve aileron effectiveness and help to prevent wing drop. It's a long time since I flew a B4 and I never used the technique for that type. It may or may not help. BTW it's just about as controversial as aerotow on CG hooks so standby for another long thread. Another factor may be tow plane acceleration. Tow pilots that launch 2-33s all day may not give enough accleration for standard class gliders. I want the tug to be at full power 2-3 seconds from start of roll. I'll let someone else warm up the *fingers on release* topic. Andy |
Ted Wagner wrote:
A number of pilots, some by direct e-mail, pointed out that when correcting for a dipped wing during the early part of take-off, rudder and not aileron should be used. I used to fly a Standard Austria off a "hot & high" airfield with a prevailing cross wind on the narrow take off runway. The Austria was also a bit tricky to control during the early part of the launch. I was not the only pilot to experience some interesting take-offs from this site. I can recall "interesting" takeoffs with Std Cirrus, Elf, Libelle, ASW15 and ASW20's. Even the single Astir could be a handful in certain conditions. We learnt a number of tricks: - Keep your hand very close to the release, and use it at the first sign of trouble. (Pilots who aborted t/o were given special priority to get back in the launch queue to encourage them to release too soon too often rather than too late once too often). - Make sure that the spectators, cars, parked gliders and other hard and/or expensive obstacles are well clear of the side of the runway before you launch. Particularly on the upwind side. Thats where you are going to end up when you ground loop. - Use less than full aleron and/or rudder while the glider is moving slowly. If you put in too much aleron you stall the down aleron wing that you are trying to lift and bang it is hard on the ground! The Austria had an all flying V tail. It was possible with full elevator input to stall the tail and loose rudder control, and vice versa. (Note, all this while rolling down the runway below stalling speed. At flying speed the Austria had excellent elevator and rudder control). - I lined up the Austria pointing at an angle across the runway, away from the cross wind. The weather cock effect would turn the glider into wind and onto the centre line during the initial role. (Other pilots in other ships did the same). - Find an experienced athletic wing runner. As wing runner you should run the downwind wing. It is natural for the wing runner to "hold back" a little when the wind tries to weather cock the glider and swing the wing forward out of your hand. - Tail wheels made life easier than skids. Wheels role in their direction of rotation and resist being pushed sideways. Skids slide in any direction with the same amount of friction. - However, while the tail wheel is on the ground, the rudder has very little effect. Some pilots used full elevator to keep the tail wheel hard on the ground during initial role and let the wheel control the direction of travel. This did not help with the Austria - it just stalled both the elevator and rudders see above. - The 15m pilots used negative flaps on the initial role. This usually worked for them. - Some guys tried using airbrakes during the initial part of the launch. This was said to be effective with the Elf and the LS4. - Of course nose tow hooks helped too, but it was not always enough for the Libelles. - Water ballast makes it worse - but that was not an issue with the Austria. Some how the two seater trainers had no trouble. When I bought into a Nimbus II, I found the launch games a thing of the past! There was a Pilatus B4 the field but I can't remember it having problems. Perhaps because it had a very experienced pilot and it did not fly very often. Have fun Ian |
Similar Threads | ||||
Tow Hook on Cessna 180 - Update | Stuart Grant | Soaring | 13 | April 10th 20 10:48 AM |
Pull plane by tail hook | Tarif Halabi | Owning | 19 | February 24th 04 02:27 PM |
CG hook on aero tows?? | Ted Wagner | Soaring | 130 | January 12th 04 11:04 PM |
Tow Hook on Cessna 180? | Stuart Grant | Soaring | 3 | October 2nd 03 12:50 AM |
CG hook & Low Tow | Ray Lovinggood | Soaring | 2 | July 25th 03 06:20 AM |
