Sailplane cover fabric
Old November 12th 17, 12:27 AM posted to rec.aviation.soaring
Default Sailplane cover fabric
Is Sunbrella marine canvus suitable for sailplane cover? Felt will be added to protect actual canopy from scratches
Old November 12th 17, 04:05 PM posted to rec.aviation.soaring
jfitch
Sunbrella makes a fabric (Sunbrella Supreme) with a soft flocking underside to protect delicate surfaces. One issue you may find with Sunbrella is that it will make a very heavy sailplane cover. The fabrics being used by the various cover manufacturers are much lighter than Sunbrella canvas.
Old November 12th 17, 07:11 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Clouddancers use dual layer covers: the inside layer looks like a cotton
dimpled fabric with a non-woven breathable outer layer for the fuselage,
fin and tops of the wing and tail surfaces and an open mesh material
covering the wing and tail undersurfaces. I got my set in spring, 2010.
They are light and easy to handle and still look good, so should be set
for several years more.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Fabric covering for 2-33 [email protected] Soaring 12 September 10th 17 07:43 AM
For Sale: Used Sailplane Wing & Fuselage Cover Scott Alexander[_2_] Soaring 1 December 11th 09 04:40 AM
Sailplane towed by reindeer - Web Page cover at CISS Newill Soaring 2 November 28th 09 10:37 PM
Futuristic sailplane on December 1967 Soaring cover John White Soaring 3 August 28th 09 01:24 PM
Wax for fabric Jim Martin Restoration 1 November 23rd 03 05:50 AM
