Garmin GPSIII data output
Evening all,
I'm trying to use a Garmin GPS III to provide the positioning signal for my Cleverbox vario. I've set up the output as NMEA at a baud rate of 4800, no matter what I try, the vario still can't see the signal. I've tried a master reset on the Garmin and my PC can see the unit, upload/download waypoints but still no luck. I spoke to Cleverbox who confirmed the cabling and plugs are correct but still no joy. Any ideas? Cheers Rob |
At 17:20 19 January 2011, Rob Shepherd wrote:
Evening all, I'm trying to use a Garmin GPS III to provide the positioning signal for my Cleverbox vario. I've set up the output as NMEA at a baud rate of 4800, no matter what I try, the vario still can't see the signal. I've tried a master reset on the Garmin and my PC can see the unit, upload/download waypoints but still no luck. I spoke to Cleverbox who confirmed the cabling and plugs are correct but still no joy. Any ideas? Cheers Rob Rob Have you set the interface on the Garmin to NMEA/NMEA. jon |
On Jan 19, 10:20*am, Rob Shepherd wrote:
Evening all, I'm trying to use a Garmin GPS III to provide the positioning signal for my Cleverbox vario. I've set up the output as NMEA at a baud rate of 4800, no matter what I try, the vario still can't see the signal. I've tried a master reset on the Garmin and my PC can see the unit, upload/download waypoints but still no luck. I spoke to Cleverbox who confirmed the cabling and plugs are correct but still no joy. Any ideas? Cheers Rob Since you say you have setup the Garmin output I assume that what you have set is what the Cleverbox requires. It seems the next step would be to verify that the box will receive an input from another GPS and/ or to verify that your GPS will drive another sink. You could perhaps use a PC serial port and a terminal emulator to do this. Checking the Garmin TX pin with a 'scope would tell you if it is transmitting anything at all. I assume you have checked the obvious - Garmin TX connected to box RX, and not TX to TX and RX to RX. The interface should only need 2 wires - TX to RX and GND to GND. Andy |
At 18:03 19 January 2011, Andy wrote:
On Jan 19, 10:20=A0am, Rob Shepherd wrote: Evening all, I'm trying to use a Garmin GPS III to provide the positioning signal for my Cleverbox vario. I've set up the output as NMEA at a baud rate of 4800, no matter what I try, the vario still can't see the signal. I've tried a master reset on the Garmin and my PC can see the unit, upload/download waypoints but still no luck. I spoke to Cleverbox who confirmed the cabling and plugs are correct but still no joy. Any ideas? Cheers Rob Since you say you have setup the Garmin output I assume that what you have set is what the Cleverbox requires. It seems the next step would be to verify that the box will receive an input from another GPS and/ or to verify that your GPS will drive another sink. You could perhaps use a PC serial port and a terminal emulator to do this. Checking the Garmin TX pin with a 'scope would tell you if it is transmitting anything at all. I assume you have checked the obvious - Garmin TX connected to box RX, and not TX to TX and RX to RX. The interface should only need 2 wires - TX to RX and GND to GND. Andy Used the TX from the Garmin to pin no.8 on the RS232 on the Cleverbox side which is GPS input, according to the instructions. Still no joy. GPS set to NMEA out 4800 baud rate. Cheers Rob |
On Jan 19, 3:09*pm, Rob Shepherd wrote:
At 18:03 19 January 2011, Andy wrote: On Jan 19, 10:20=A0am, Rob Shepherd *wrote: Evening all, I'm trying to use a Garmin GPS III to provide the positioning signal for my Cleverbox vario. I've set up the output as NMEA at a baud rate of 4800, no matter what I try, the vario still can't see the signal. I've tried a master reset on the Garmin and my PC can see the unit, upload/download waypoints but still no luck. I spoke to Cleverbox who confirmed the cabling and plugs are correct but still no joy. Any ideas? Cheers Rob Since you say you have setup the Garmin output I assume that what you have set is what the Cleverbox requires. *It seems the next step would be to verify that the box will receive an input from another GPS and/ or to verify that your GPS will drive another sink. *You could perhaps use a PC serial port and a terminal emulator to do this. Checking the Garmin TX pin with a 'scope would tell you if it is transmitting anything at all. I assume you have checked the obvious *- Garmin TX connected to box RX, and not TX to TX and RX to RX. *The interface should only need 2 wires *- TX to RX and GND to GND. Andy Used the TX from the Garmin to pin no.8 on the RS232 on the Cleverbox side which is GPS input, according to the instructions. Still no joy. GPS set to NMEA out 4800 baud rate. Cheers Rob * It's worthwhile to connect to a tty of some sort (e.g. laptop running Hyperterminal) to see if the datastream is showing up. I didn't get output from my eTrex one day and thought I'd cut my cable. Just before slicing into the cable I remembered setting the Garmin data mode instead, which turns off the NMEA stream. -- Matt |
Similar Threads | ||||
FA: Nav Data Card for Garmin 430 / 530 | Adam[_1_] | Aviation Marketplace | 0 | September 15th 07 02:33 PM |
Garmin 296/396 Terrain Data | [email protected] | Instrument Flight Rules | 21 | December 14th 05 02:46 PM |
Garmin Data Cards | Brad Salai | Instrument Flight Rules | 22 | September 3rd 05 12:24 AM |
VOR/LOC data garmin 530 | jaglance | Instrument Flight Rules | 2 | June 12th 05 01:53 AM |
Garmin 430 data chip | PaulaJay1 | Instrument Flight Rules | 6 | December 29th 03 04:43 PM |
