SeeYou - managing waypoints
Old June 16th 16, 04:16 PM posted to rec.aviation.soaring
Default SeeYou - managing waypoints
New SeeYou user with version 8.11.
The default setup loads a huge waypoint database. It appears all waypoints are lumped into one single file. This makes it very tedious to locate and select a desired waypoint.
My preference is to have waypoints organized in site specific sub-folders. Is this possible?
Old June 16th 16, 05:28 PM posted to rec.aviation.soaring
Dan Marotta
I'm not familiar with SeeYou but in XCSoar, the waypoint database is a
text file and can be swapped out on the fly while the program is
running. If such is the same with SeeYou, you could create multiple
smaller databases from your huge database and then use the one that is
best suited for a particular flight and, if necessary, change to a
different database during a flight.
Hope that helps.
Dan, 5J
Old June 16th 16, 05:59 PM posted to rec.aviation.soaring
JS
Yes, you can close that waypoint list and open another, save it as whatever you want to call it.
Should you wish, version 8 allows you to copy waypoints from one database to another.
Old June 16th 16, 07:41 PM posted to rec.aviation.soaring
Thanks JS.
Are contest turnpoints (.cup) files meant to reside in a "library" inside the SeeYou program or should you store them in a site specific file outside the SeeYou program?
Old June 16th 16, 07:48 PM posted to rec.aviation.soaring
JS
On Thursday, June 16, 2016 at 11:41:46 AM UTC-7, wrote:
Thanks JS.
Store the files wherever you want!
For example, all my cup files are in C:\Documents\Aviation. Right now working with one I renamed "Nephi 2016 c6b.cup".
Old June 17th 16, 12:56 AM posted to rec.aviation.soaring
2KA
You can do either. There is a single waypoint database in the program -- you can replace it with anything you want. Or you can keep turnpoints in external .CUP files and open them in a window just when you want them.
When you open a .CUP file the program asks if you want to just open it in a window or put the waypoints into the internal database.
Lynn Alley
"2KA"
(USA only) Managing 911 response to off field landings Jim Beckman[_2_] Soaring 8 August 11th 09 04:23 PM
Software for managing shared or fractional ownership property [email protected] Aviation Marketplace 0 March 17th 09 02:12 PM
Software for managing fractional ownership [email protected] Owning 0 March 17th 09 02:04 PM
Webbased software for managing time of takeoff and landings [email protected] Soaring 0 June 10th 08 02:14 PM
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 11:38 AM
