Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Does an "IFR approved" GPS placard require database updates?
Old May 29th 05, 12:27 PM
Charlie Derk
Default Does an "IFR approved" GPS placard require database updates?
During my instrument training I was told that if you have an IFR
certified GPS, it had to be updated if you were using it for IFR Flight.
You can use it VFR even if it hasn't been updated
Charlie
Peter wrote:
I've been told that if one's GPS is an IFR approved unit (KLN94B in my
case) and it's not placarded "VFR only" then I am required to have the
latest database, otherwise I am not complying with the minimum
equipment list (in ANY flight) - is this correct?
If so, what would this mean for the validity of insurance?
Peter.
Return address is invalid to help stop junk mail.
E-mail replies to but remove the X and the Y.
Please do NOT copy usenet posts to email - it is NOT necessary.
Old May 29th 05, 02:54 PM
Ron Natalie
You need to read the flight manual supplement for your aircraft.
Different installations have different reqirements. It's
doubtful that "MEL" applies at all here since your plane most
likely doesn't have one.
As far as non-IFR flight, nobody suggests ripping the alitmeter out
of my plane because my IFR certs have expired.
Old May 31st 05, 01:24 PM
In rec.aviation.misc Charlie Derk wrote:
: During my instrument training I was told that if you have an IFR
: certified GPS, it had to be updated if you were using it for IFR Flight.
: You can use it VFR even if it hasn't been updated
: Charlie
As I've heard it, you can technically fly IFR with an expired database, so
long as you have verified that the data for every piece of information in the database
that you will use is correct.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old May 31st 05, 07:34 PM
jmk
Exactly... Using it for an IFR GPS is all about the POH supplement.
Garmin requires updates. UPSAT did not - just required that you verify
that the approach hasn't changed.
None of this prevents you from using the GPS, of course, for enroute
VFR use.
Now some years ago there was a controversy started by Flying magazine
because of the speculation that an over zealous FAA inspector might
view an out of date database as a violation. But the FAA clarified
that this was not the case. Same deal as with outdated charts in the
plane. Perfectly okay... But you MUST have the current information
you need to complete the flight safely. That same outdated chart (or
database) won't get you out of jail if you violate some airspace (or
worse, violate the terrain).
Old May 31st 05, 10:05 PM
Gord Beaman
"jmk" wrote:
cut
God yes!,,,that last violation is a big no no (the operative word
here being 'last' of course.
-Gord.
"I'm trying to get as old as I can,
and it must be working 'cause I'm
the oldest now that I've ever been"
Do brand new big bore Continentals require top end overhaul at 400 hours? Corky Scott Piloting 12 August 25th 04 02:46 PM
"Proceed on Course" = "Right turn approved"? Bob Chilcoat Piloting 41 July 18th 04 11:48 PM
CAAC in China had approved below 116kg aircraft sold in China without airworthiness cetificate Luo Zheng Home Built 0 June 27th 04 03:50 AM
Is AWC an approved weather source? Andrew Sarangan Piloting 1 June 26th 04 01:01 PM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
