when to run up and check the prop
I fly some high performance, complex singles like Saratogas, Lances, C182RG,
C206, and the like. Typical flying days have multiple hops while seeing customers. On one hand I know pilots who say that you should do a full run up and prop check before every take off, because the checklist says to. On the other hand, I know pilots, mostly owners of similar aircraft, who only do a full runup and prop check on the first flight of the day. Their rationale is that doing it four or five times a day is unnecessarily hard on the engine and when its been flown in the last few hours there's no need to cycle the prop more. They argue if there's a new problem during the day like a mag, its easy to detect upon first throttle up as you take off. You would hear and feel the engine roughness and see its not developing full power. Are there any good arguments out there based in science and fact and not old wives tales to support only doing a run up and prop check on the first flight of the day ? I'm talking about a situation where you're flying multiple flights a day and the engine never completely cools off. |
I'd only run up and check the prop when the engine's not running. You can
get hurt otherwise :-) -- Bob (Chief Pilot, White Knuckle Airways) |
Bob Chilcoat wrote: I'd only run up and check the prop when the engine's not running. You can get hurt otherwise :-) -- Bob (Chief Pilot, White Knuckle Airways) sissy \ dan |
Bob Chilcoat wrote:
I'd only run up and check the prop when the engine's not running. You can get hurt otherwise :-) For some corny reason, this made me burst out laughing at work. How embarassing. Charles. -N8385U |
Bob Chilcoat wrote:
I'd only run up and check the prop when the engine's not running. You can get hurt otherwise :-) Booooooo!!!!! George Patterson There's plenty of room for all of God's creatures. Right next to the mashed potatoes. |
"Bob Chilcoat" wrote in message ... I'd only run up and check the prop when the engine's not running. You can get hurt otherwise :-) -- Bob (Chief Pilot, White Knuckle Airways) C'mon, Bob...we're trying to be serious here... |
Are there any good arguments out there based in science and fact and not old wives tales to support only doing a run up and prop check on the first flight of the day ? How about lowering the risk of an engine failure in the air by inducing any impending failures while on the ground? |
Friendly Skies wrote: snip Their rationale is that doing it four or five times a day is unnecessarily hard on the engine and when its been flown in the last few hours there's no need to cycle the prop more. I don't see why a runup or a short prop cycle should be unnecessarily hard on the engine. If they're stopping that many times a day, they'll get the procedure down to a few seconds. In the backcountry, where there is often no place to runup without sucking rocks into the prop, we often do the mag check early in the takeoff roll. It's an extra step during a critical phase, but I always feel more comfortable rolling towards the trees and rocks at the end of the runway when I know all of the plugs are firing on time. John Galban=====N4BQ (PA28-180) |
"John Galban" wrote in message oups.com... Friendly Skies wrote: snip Their rationale is that doing it four or five times a day is unnecessarily hard on the engine and when its been flown in the last few hours there's no need to cycle the prop more. I don't see why a runup or a short prop cycle should be unnecessarily hard on the engine. If they're stopping that many times a day, they'll get the procedure down to a few seconds. In the backcountry, where there is often no place to runup without sucking rocks into the prop, we often do the mag check early in the takeoff roll. It's an extra step during a critical phase, but I always feel more comfortable rolling towards the trees and rocks at the end of the runway when I know all of the plugs are firing on time. Not exactly a match, but http://www.avweb.com/news/columns/182082-1.html offers some good, helpful basics that might answer some peripheral questions. |
same thing happens on floats and a water take off..
"John Galban" wrote in message oups.com... Friendly Skies wrote: snip Their rationale is that doing it four or five times a day is unnecessarily hard on the engine and when its been flown in the last few hours there's no need to cycle the prop more. I don't see why a runup or a short prop cycle should be unnecessarily hard on the engine. If they're stopping that many times a day, they'll get the procedure down to a few seconds. In the backcountry, where there is often no place to runup without sucking rocks into the prop, we often do the mag check early in the takeoff roll. It's an extra step during a critical phase, but I always feel more comfortable rolling towards the trees and rocks at the end of the runway when I know all of the plugs are firing on time. John Galban=====N4BQ (PA28-180) |
Similar Threads | ||||
Changes in Instrument Proficiency Check Requirements | Richard Kaplan | Instrument Flight Rules | 71 | June 10th 04 08:02 PM |
Pitch and Diameter of 3 blade prop for IO-360 200HP | Bart D. Hull | Home Built | 1 | December 11th 03 11:42 PM |
Use of hand-held GPS on FAA check ride | Barry | Rotorcraft | 1 | August 30th 03 01:24 AM |
Use of hand-held GPS on FAA check ride | Barry | Piloting | 3 | August 9th 03 10:14 PM |
Use of hand-held GPS on FAA check ride | Barry | Instrument Flight Rules | 1 | August 9th 03 09:25 PM |
