IPC questions?
Old May 31st 04, 10:39 PM
Ron Rosenfeld
On 29 May 2004 23:24:50 GMT, Stan Gosnell me@work wrote:
(Teacherjh) wrote in
Please forgive my ignorance, but what exactly is ODP?
Obstacle Departure Procedure.
Seems to me that's redundant. The purpose of a departure
procedure is to provide obstacle clearance.
Perhaps, but that's the nomenclature used by the FAA in the AIM to
differentiate them from SID's.
And, although SID's do provide obstacle clearance, that may not necessarily
be their primary purpose.
Old June 1st 04, 03:34 AM
Andrew Sarangan
Ron Rosenfeld wrote in
necessarily be their primary purpose.
OK, so why do you think the distinction is so important in the context of
an IPC?
Old June 1st 04, 10:40 AM
Ron Rosenfeld
an IPC?
Look at the differences. They are pretty clear in the AIM.
For one thing, SID's are explicitly assigned by ATC. So when they are
assigned, the instrument pilot has an immediate heads-up as to how to fly.
For Part 91 flights, ODP's may not be explicitly assigned, and are optional
for the pilot (if not assigned)! They do NOT require ATC clearance (or
even require that you inform ATC if you choose to fly the ODP). You may
have to review the chart to even know that there is an ODP (or non-standard
departure minima).
And, most importantly, there have been a number of accidents due to pilots
not flying a published ODP that was their option to fly.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 December 2nd 04 07:00 AM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
