Blue Ridge Crash
Can anyone from VA confirm what may have happened to Dr. Schneller,
more than just a "rope break". www2.wsls.com/news/2011/apr/11/virginia-tech-professor-killed-craig- county-glider-ar-964634/ Condolenses and best wishes to all Meir's family and friends. |
Quote:
Condolences to the family. Walt |
Blue Ridge Crash
On Apr 11, 8:19*pm, Karen wrote:
Can anyone from VA confirm what may have happened to Dr. Schneller, more than just a "rope break". Story I got was that the L-33 took off with spoilers open. Glider was wallowing on tow .. rolling left and right.....Rope broke.... glider nose up.....and glider did stall / spin from about 400'. Some say he ws "signalling" for more airspeed, some say just wallowing. L-33 has very powerful spoilers.... Cookie |
Quote:
Walt Walt |
Blue Ridge Crash
On Tue, 12 Apr 2011 19:45:21 +0000, Walt Connelly wrote:
When I am the wing runner, unless a pilot tells me he is taking off with partial spoilers I try to insure that they are closed and that the tail dolly is off among other things. I agree that the tail dolly is easily spottable by wing runner, etc., but this doesn't necessarily apply to airbrakes. If they are unlocked, on many gliders they'll be flush with the wing surface so that neither wing runner or tow pilot can tell whether they are locked or not and will suck open during the launch. In my club we use the CBSIFTCBE check where the Brakes item requires the pilot to open the brakes fully, check for equal extension, do the same for half brake, and then close and lock them. This, by itself, is a pretty good assurance that they'll be locked but the pilot can still get interrupted while he's doing checks and forget 'brakes', so this season the winch cable hooker-onner has instructions not to put the cable on unless the pilot explicitly says "Brakes locked: cable on, please" and to prompt the pilot if he doesn't report brakes locked. This procedure also makes sense for aero tow. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Quote:
Walt |
Blue Ridge Crash
On Apr 13, 7:06*am, Walt Connelly Walt.Connelly.
wrote: 'Martin Gregorie[_5_ Wrote: ;768541']On Tue, 12 Apr 2011 19:45:21 +0000, Walt Connelly wrote: - When I am the wing runner, unless a pilot tells me he is taking off with partial spoilers I try to insure that * they are closed and that the tail dolly is off among other things. - I agree that the tail dolly is easily spottable by wing runner, etc., but this doesn't necessarily apply to airbrakes. If they are unlocked, on many gliders they'll be flush with the wing surface so that neither wing runner or tow pilot can tell whether they are locked or not and will suck open during the launch. In my club we use the CBSIFTCBE check where the Brakes item requires the pilot to open the brakes fully, check for equal extension, do the same for half brake, and then close and lock them. This, by itself, is a pretty good assurance that they'll be locked but the pilot can still get interrupted while he's doing checks and forget 'brakes', so this season the winch cable hooker-onner has instructions not to put the cable on unless the pilot explicitly says "Brakes locked: cable on, please" and to prompt the pilot if he doesn't report brakes locked. This procedure also makes sense for aero tow. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Good point, well taken. *While the brakes can suck open if not locked, the wing runner visual inspection is only part of the safety sequence. Still I have seen people give me the thumbs up while the spoilers were clearly open. The requirement to have the pilot specifically state "brakes locked, cable on please," is a good one. *The more we can do to eliminate errors the better. Walt -- Walt Connelly- Hide quoted text - - Show quoted text - Well I know it's been said many times before but ... Please recognize that many pilots of Std Class gliders will always start takeoff roll with airbrakes open. If you see the brakes moving it's a sign the pilot's hand is on the handle and he knows they are open. If you see the brakes open as the slack comes out, be aware that is a normal event and do not stop the launch. On most modern gliders brakes that are closed but not locked will leave the brake caps slighly above flush. Look for that and if they don't open then consider stopping the launch. At a site where I am not known I'll usually tell the wing runner and the tow pilot that the brakes will be open at the start of takeoff roll. Some pilots cycle the brakes a few times as the slack comes out so the tuggie knows what to expect. Andy |
Blue Ridge Crash
On Apr 13, 5:32*pm, Andy wrote:
On Apr 13, 7:06*am, Walt Connelly Walt.Connelly. wrote: 'Martin Gregorie[_5_ Wrote: ;768541']On Tue, 12 Apr 2011 19:45:21 +0000, Walt Connelly wrote: - When I am the wing runner, unless a pilot tells me he is taking off with partial spoilers I try to insure that * they are closed and that the tail dolly is off among other things. - I agree that the tail dolly is easily spottable by wing runner, etc., but this doesn't necessarily apply to airbrakes. If they are unlocked, on many gliders they'll be flush with the wing surface so that neither wing runner or tow pilot can tell whether they are locked or not and will suck open during the launch. In my club we use the CBSIFTCBE check where the Brakes item requires the pilot to open the brakes fully, check for equal extension, do the same for half brake, and then close and lock them. This, by itself, is a pretty good assurance that they'll be locked but the pilot can still get interrupted while he's doing checks and forget 'brakes', so this season the winch cable hooker-onner has instructions not to put the cable on unless the pilot explicitly says "Brakes locked: cable on, please" and to prompt the pilot if he doesn't report brakes locked. This procedure also makes sense for aero tow. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Good point, well taken. *While the brakes can suck open if not locked, the wing runner visual inspection is only part of the safety sequence. Still I have seen people give me the thumbs up while the spoilers were clearly open. The requirement to have the pilot specifically state "brakes locked, cable on please," is a good one. *The more we can do to eliminate errors the better. Walt -- Walt Connelly- Hide quoted text - - Show quoted text - Well I know it's been said many times before but ... Please recognize that many pilots of Std Class gliders will always start takeoff roll with airbrakes open. If you see the brakes moving it's a sign the pilot's hand is on the handle and he knows they are open. *If you see the brakes open as the slack comes out, be aware that is a normal event and do not stop the launch. On most modern gliders brakes that are closed but not locked will leave the brake caps slighly above flush. Look for that and if they don't open then consider stopping the launch. At a site where I am not known I'll usually tell the wing runner and the tow pilot that the brakes will be open at the start of takeoff roll. *Some pilots cycle the brakes a few times as the slack comes out so the tuggie knows what to expect. Andy- Hide quoted text - - Show quoted text - Around here, we teach our pilots to keep the left hand lightly "on" or near the spoiler handle. If the spoilers open up, you know right away. I always questioned the idea of starting the ground roll with the spoilers open...but at least the guys who do that have their left hand on the spoiler handle. The pre take off checklist is 100% the responsibility of the pilot.......the status of the spoilers (whether closed and locked, or open for take off roll) should be on this checklist. Spoilers opening on tow can only be the fault of one person, the PIC. The ground crew is in no way responsible for the pilot's peflight duties or pre take off duties. If the ground crew does notice a problem, of course they should speak up, but I would rather see the ground crew concentration on their own important responsibilties. Cookie |
Blue Ridge Crash
On Apr 13, 6:59*pm, "
wrote: I always questioned the idea of starting the ground roll with the spoilers open...but at least the guys who do that have their left hand on the spoiler handle. 15m guys do it too. It's basic survival in some std class ships, but it also aids start of launch roll control in my ASW-20, and I've seen plenty of 27 guys do this as well. Various aerodynamic "theories" as to why this is effective are not very satisfying, but it's clear the technique is effective. -Evan Ludeman / T8 |
Blue Ridge Crash
that many pilots of Std Class gliders will always start takeoff roll with airbrakes open. Having owned and flown an L-33 (glider type cited by Cookie), I never needed to use spoilers for takeoff because the ailerons were so effective at very low speeds. So was the intentional use of spoilers confirmed or is this just another theoretical discussion? Horst |
Similar Threads | ||||
Blue Angels 1973 Lakehurst Crash | ramrod48 | Naval Aviation | 3 | March 2nd 13 02:08 PM |
Scuttlebutt on the Blue Angel crash?? | Charlie Wolf | Naval Aviation | 11 | May 7th 07 11:45 PM |
Blue Angels Crash | MWB[_2_] | Aviation Photos | 15 | April 25th 07 06:50 PM |
Blue Angels Crash | RAP Flashnet | Aviation Photos | 0 | April 24th 07 04:55 PM |
A fine ridge day in PA - the Ridge Soaring Irregulars ride again | QT | Soaring | 0 | April 6th 06 04:01 PM |
