Third "turbine" on top of large Mil helis?
Hi, many of the large Mil helis have what looks like a third turbine
above, and slightly behind the two main turbines. What is it? All of the specs for these helis say they have two turbines. I can see blades in some photos, so it's obviously something like a turbine. Thanks, Justin. http://soupisgoodfood.net/ |
wrote in message oups.com... Hi, many of the large Mil helis . . . . . Got a pic? |
wrote in message oups.com... Hi, many of the large Mil helis have what looks like a third turbine above, and slightly behind the two main turbines. What is it? All of the specs for these helis say they have two turbines. I can see blades in some photos, so it's obviously something like a turbine. Oil Cooler fan Slatts |
That is an auxiliary power unit (APU) for pneumatic main turbine starting.
Required for self-contained operations. At least some models of Mil are equipped with Ivchenko AI-9V APU unit. Use e.g. Vivisimo meta-search engine www.vivisimo.com and type "Mil Mi APU" and you get more information about the subject. JP kirjoitti glegroups.com... Hi, many of the large Mil helis have what looks like a third turbine above, and slightly behind the two main turbines. What is it? All of the specs for these helis say they have two turbines. I can see blades in some photos, so it's obviously something like a turbine. Thanks, Justin. http://soupisgoodfood.net/ |
Oil cooler fan mentioned earlier is not a bad idea after all! Some larger
Mil helos may have a main transmission cooling system located just there. JP "JP" kirjoitti ... That is an auxiliary power unit (APU) for pneumatic main turbine starting. Required for self-contained operations. At least some models of Mil are equipped with Ivchenko AI-9V APU unit. Use e.g. Vivisimo meta-search engine www.vivisimo.com and type "Mil Mi APU" and you get more information about the subject. JP kirjoitti glegroups.com... Hi, many of the large Mil helis have what looks like a third turbine above, and slightly behind the two main turbines. What is it? All of the specs for these helis say they have two turbines. I can see blades in some photos, so it's obviously something like a turbine. Thanks, Justin. http://soupisgoodfood.net/ |
Thanks for that. Mystery solved
Justin, Look at first picture. Left rear of cowling shows small exhaust
for APU (I'd guess about 5 in. compared to larger main engines). Ed R. wrote: Thanks for that. Mystery solved |
"JP" wrote in message ... That is an auxiliary power unit (APU) for pneumatic main turbine starting. Required for self-contained operations. At least some models of Mil are equipped with Ivchenko AI-9V APU unit. Use e.g. Vivisimo meta-search engine www.vivisimo.com and type "Mil Mi APU" The APU is behind the transmission. Slatts |
"Sla#s" kirjoitti
where.com... "JP" wrote in message ... That is an auxiliary power unit (APU) for pneumatic main turbine starting. Required for self-contained operations. At least some models of Mil are equipped with Ivchenko AI-9V APU unit. Use e.g. Vivisimo meta-search engine www.vivisimo.com and type "Mil Mi APU" The APU is behind the transmission. Slatts Yes I agree, it seems to be the case. The APU is behind the main transmission. The "third turbine" has to be an oil cooler fan. JP |
Similar Threads | ||||
STC to Install a Large Baggage Door on a Baron? | JAX | Owning | 1 | November 15th 05 11:41 PM |
FA: Vietnam The Helicopter War Large HC Book 189p | Disgo | Aviation Marketplace | 0 | February 6th 04 05:19 PM |
helis update | jorge | Rotorcraft | 0 | October 19th 03 10:26 PM |
Invest small Earn Large ($20 000+) | promethean | General Aviation | 0 | October 3rd 03 06:08 AM |
