Sukhoi Su-47
https://en.wikipedia.org/wiki/Sukhoi_Su-47
The Sukhoi Su-47 Berkut (Russian: ????? ??-47 ??????, lit. 'Golden Eagle') (NATO reporting name Firkin), also designated S-32 and S-37 (not to be confused with the twin-engined delta canard design offered by Sukhoi in the early 1990s under the designation Su-37) during initial development, was an experimental supersonic jet fighter developed by Sukhoi Aviation Corporation. A distinguishing feature of the aircraft was its forward-swept wing that gave the aircraft excellent agility and maneuverability. While serial production of the type never materialized, the sole aircraft produced served as a technology demonstrator prototype for a number of advanced technologies later used in the 4.5 generation fighter SU-35BM and current fifth-generation jet fighter Sukhoi Su-57. The Su-47 is of similar dimensions to previous large Sukhoi fighters, such as the Su-35. To reduce development costs, the Su-47 borrowed the forward fuselage, vertical tails, and landing gear of the Su-27 family. Nonetheless, the aircraft includes an internal weapons bay, and space set aside for an advanced radar. Though similar in overall concept to the Grumman X-29 research aircraft of the 1980s, the Su-47 is larger and far closer to an actual combat aircraft than its US counterpart. Like its immediate predecessor, the Su-37, the Su-47 is of tandem-triple layout, with canards ahead of wings and tailplanes. Interestingly, the Su-47 has two tailbooms of unequal length outboard of the exhaust nozzles. The shorter boom, on the left-hand side, houses rear-facing radar, while the longer boom houses a brake parachute. Role Experimental/Technology demonstrator Manufacturer Sukhoi First flight 25 September 1997 Status Cancelled Primary user Russian Air Force Number built 1 Maneuverability The Su-47 has extremely high agility at subsonic speeds, enabling the aircraft to alter its angle of attack and its flight path very quickly while retaining maneuverability in supersonic flight. The Su-47 has a maximum speed of Mach 1.6 at high altitudes and a 9g capability. The swept-forward wing, compared to a swept-back wing of the same area, provides a number of advantages: * higher lift-to-drag ratio * better agility in dogfight situations * higher range at subsonic speed * improved stall resistance and anti-spin characteristics * improved stability at high angles of attack * a lower minimum flight speed * a shorter take-off and landing distance The forward-swept midwing gives the Su-47 its unconventional appearance. A substantial part of the lift generated by the forward-swept wing occurs at the inner portion of the wingspan. This inboard lift is not restricted by wingtip stall and the lift-induced wingtip vortex generation is thus reduced. The ailerons—the wing's control surfaces—remain effective at the highest angles of attack, and controllability of the aircraft is retained even in the event of airflow separating from the remainder of the wings' surface. A downside of such a forward-swept wing design is that it geometrically produces wing twisting as it bends under load, resulting in greater stress on the wing than for a similar straight or aft-swept wing. This requires the wing be designed to twist as it bends—opposite to the geometric twisting. This is done by the use of composites wing skins laid-up to twist. The plane was initially limited to Mach 1.6. Specifications (Su-47) General characteristics Crew: 1 Length: 22.6 m (74 ft 2 in) Wingspan: 15.16 m to 16.7 m (49 ft 9 in to 54 ft 9 in) Height: 6.3 m (20 ft 8 in) Wing area: 61.87 m² (666 sq ft) Empty weight: 16,375 kg (36,100 lbs) Loaded weight: 25,000 kg (55,115 lb) Max. takeoff weight: 35,000 kg (77,162 lb) Thrust vectoring: ±20° at 30° per second in pitch and yaw Powerplant: 2 × Aviadvigatel D-30F11 afterburning, thrust vectoring (in PFU modification) turbofans Dry thrust: 83.4 kN (18,700 lbf) each Thrust with afterburner: 142.2 kN (32,000 lbf) each Performance Maximum speed: Mach 1.65 (Achieved in test flights) (1,717 km/h, 1,066 mph) At sea level: Mach 1.16 (1,400 km/h, 870 mph) Range: 3,300 km (2,050 mi) Service ceiling: 18,000 m (59,050 ft) Rate of climb: 233 m/s (46,200 ft/min) Wing loading: 360 kg/m² (79.4 lb/(sq ft)) Thrust/weight: 1.16 (loaded) / 1.77 (empty) * |
Sukhoi Su-47
Miloch wrote in
news https://en.wikipedia.org/wiki/Sukhoi_Su-47 The Sukhoi Su-47 Berkut (Russian: ????? ??-47 ??????, lit. 'Golden Eagle') (NATO reporting name Firkin), also designated S-32 and S-37 (not to be confused with the twin-engined delta canard design offered by Sukhoi in the early 1990s under the designation Su-37) during initial development, was an experimental supersonic jet fighter developed by Sukhoi Aviation Corporation. A distinguishing feature of the aircraft was its forward-swept wing that gave the aircraft excellent agility and maneuverability. While serial production of the type never materialized, the sole aircraft produced served as a technology demonstrator prototype for a number of advanced technologies later used in the 4.5 generation fighter SU-35BM and current fifth-generation jet fighter Sukhoi Su-57. The Su-47 is of similar dimensions to previous large Sukhoi fighters, such as the Su-35. To reduce development costs, the Su-47 borrowed the forward fuselage, vertical tails, and landing gear of the Su-27 family. Nonetheless, the aircraft includes an internal weapons bay, and space set aside for an advanced radar. Though similar in overall concept to the Grumman X-29 research aircraft of the 1980s, the Su-47 is larger and far closer to an actual combat aircraft than its US counterpart. Like its immediate predecessor, the Su-37, the Su-47 is of tandem-triple layout, with canards ahead of wings and tailplanes. Interestingly, the Su-47 has two tailbooms of unequal length outboard of the exhaust nozzles. The shorter boom, on the left-hand side, houses rear-facing radar, while the longer boom houses a brake parachute. Role Experimental/Technology demonstrator Manufacturer Sukhoi First flight 25 September 1997 Status Cancelled Primary user Russian Air Force Number built 1 Maneuverability The Su-47 has extremely high agility at subsonic speeds, enabling the aircraft to alter its angle of attack and its flight path very quickly while retaining maneuverability in supersonic flight. The Su-47 has a maximum speed of Mach 1.6 at high altitudes and a 9g capability. The swept-forward wing, compared to a swept-back wing of the same area, provides a number of advantages: * higher lift-to-drag ratio * better agility in dogfight situations * higher range at subsonic speed * improved stall resistance and anti-spin characteristics * improved stability at high angles of attack * a lower minimum flight speed * a shorter take-off and landing distance The forward-swept midwing gives the Su-47 its unconventional appearance. A substantial part of the lift generated by the forward-swept wing occurs at the inner portion of the wingspan. This inboard lift is not restricted by wingtip stall and the lift-induced wingtip vortex generation is thus reduced. The ailerons—the wing's control surfaces—remain effective at the highest angles of attack, and controllability of the aircraft is retained even in the event of airflow separating from the remainder of the wings' surface. A downside of such a forward-swept wing design is that it geometrically produces wing twisting as it bends under load, resulting in greater stress on the wing than for a similar straight or aft-swept wing. This requires the wing be designed to twist as it bends—opposite to the geometric twisting. This is done by the use of composites wing skins laid-up to twist. The plane was initially limited to Mach 1.6. Specifications (Su-47) General characteristics Crew: 1 Length: 22.6 m (74 ft 2 in) Wingspan: 15.16 m to 16.7 m (49 ft 9 in to 54 ft 9 in) Height: 6.3 m (20 ft 8 in) Wing area: 61.87 m² (666 sq ft) Empty weight: 16,375 kg (36,100 lbs) Loaded weight: 25,000 kg (55,115 lb) Max. takeoff weight: 35,000 kg (77,162 lb) Thrust vectoring: ±20° at 30° per second in pitch and yaw Powerplant: 2 × Aviadvigatel D-30F11 afterburning, thrust vectoring (in PFU modification) turbofans Dry thrust: 83.4 kN (18,700 lbf) each Thrust with afterburner: 142.2 kN (32,000 lbf) each Performance Maximum speed: Mach 1.65 (Achieved in test flights) (1,717 km/h, 1,066 mph) At sea level: Mach 1.16 (1,400 km/h, 870 mph) Range: 3,300 km (2,050 mi) Service ceiling: 18,000 m (59,050 ft) Rate of climb: 233 m/s (46,200 ft/min) Wing loading: 360 kg/m² (79.4 lb/(sq ft)) Thrust/weight: 1.16 (loaded) / 1.77 (empty) * Just for what it is worth, "Berkut" is better translated to "Falcon." Makes you wonder about the NATO name of Firkin. And no. That didn't come from Google Translate, though I will now go and check! It came from a native Russkie. |
Similar Threads | ||||
Sukhoi Su-24 pics 2 [8/9] - Sukhoi Su-24M2 - Russia - Air Force.jpg (1/1) | Miloch | Aviation Photos | 0 | April 25th 18 10:25 AM |
Sukhoi Su-24 pics 2 [6/9] - Sukhoi Su-24M - Russia - Air Force 2192038.jpg (1/1) | Miloch | Aviation Photos | 0 | April 25th 18 10:25 AM |
Sukhoi Su-25 pics [2/8] - A Sukhoi Su-25SM at the Celebration of the 100th anniversary of Russian Air Force.jpg (1/1) | Miloch | Aviation Photos | 0 | January 21st 18 11:02 AM |
Sukhoi Su-57 pics 2 [05/10] - Sukhoi T-50 in flight with landing gear deployed, 2010.jpg (1/1) | Miloch | Aviation Photos | 0 | October 9th 17 03:09 PM |
Sukhoi Su-57 pics 1 [10/11] - Sukhoi PAK-FA T-50 views. Derived from patent picture..png (1/1) | Miloch | Aviation Photos | 0 | October 9th 17 03:08 PM |
